    [plugin] realSection v0.6 Béta (Updated 9/8/2014)
    87 Posts 37 Posters 70.6k Views 37 Watching
      Jim
      @simon le bon said:
      This reminds me that I think there is a plugin to pick in our "library" only the plugins we want to open in our session of SketchUp ??? May be a plug by Jim !?
      I may have posted some thoughts, but I do not have a good solution. 😢
      • plot-parisP Offline
        plot-paris
        Hi GWydouw,
        first of all: fantastic plugin! I like it a lot.
        playing around with this tool instantly got me dreaming... so I've got some ideas / wishes:
        1. Nested Group Support: as mentioned before, the ability to process nested groups is of vital importance for this plugin to become a mighty tool (most models in SketchUp (definitely all of mine) heavily rely on nested grouping)
        2. Components Support: components need to work as well (again, i've got lots of them in my models 😉 ). ideally one would define one component and your plugin then would apply the section-material to all component-instances in the model.
        3. Texture-Linking: another great feature would be to link section-materials to materials used to paint the model. so for example I draw a building with concrete walls and timber floor boards and use textures to paint these object accordingly. now, when creating the realSection, I link section-materials to these textures. as a result all objects textured with a concrete texture will be sectioned with the linked section-material, objects painted with the timber floor boards will get the section-material linked to this texture and so on.
          (I know, this might be quite tricky. but should you decide to give it a try, please remember, that sometimes objects can have several materials applied to them (one material on the raw geometry, another applied to the group itself. and it gets even messier, when you have nested groups). in such a case its probably best to give the innermost material the highest priority (cause thats how SketchUp itself treats materials)).
          interface-wise it would probably be most comfortable to have a dialog window where you have pairs of materials; the texture-material on the left, the associated section-material on the right. you can then choose from a dropdown-list.
          to keep the interface clean, you would only have one pair of textures at first. as soon as you choose your first texture, a new blank set is added. thus keep the size of the window small without limiting the number of textures...
        4. Interactive Section-Texturing: first of all you would have to close all groups that haven't been assigned a section-material with a default material. and then you make the texture-selection process interactive. the workflow would be the following: you right-click a group (or it's section-cut face) and define a section-material. when you now hit the OK button, the section gets updated, letting you see the results instantly.
        5. Linking Cut-Faces to Section Planes: and finally a really tricky, but clever idea 😉 Imagine it was possible to link the layer-visibility to a section plane. so when a certain section plane is active, the layer with the associated section-faces is made visible. when you switch off the section plane, the section-faces layer automatically is made invisible. when you activate another section plane, it's dedicated section-faces layer gets activated and so on...
          so no manual showing / hiding of layers. everything is done automatically. what a wonderful prospect!
        Ok, that was quite a lot of ideas. and I have no idea how realistic they are. but anyway, what do you think? 😕
        • simon le bonS Offline
          simon le bon
          Hi Dear Jim, 😉
          In fact I was thinking of one of your plugs I have still never tried: a plug to assemble family of commands in our own toolbars
          SketchUp Custom Toolbars
          http://2.bp.blogspot.com/_ogonR-k5OoM/SFQzmxh8aeI/AAAAAAAAHXQ/pifUCnbkhf8/s400/toolbar_commands.jpg
          Custom Tollbars described in Pushpullbar
          But its purpose is not what I was remembering. Because it only gather the native commands of Sketchup and not the external plugins..
          ++simon.
          %(#800000)[________
          Retroperspectively I'm very sorry Dear GWydouw to bump this way your thread.
          In fact I haven't yet tried your tool. I love already Tig's SectionCutFace and I know your tool is going to give more. So I love it without knowing it 😄
          I see that Plot Paris reloads the thread in it good way with his following post.] 👍 👍
            troyhome
            I can't use the plugin...this is all i get. I'm on a Mac and use SU8
            IOviz.com
            SU Pro 2024 PC
            • I Offline
              ivreich
              Hi GWydouw
              Ok i don't know what is happening but i can't get this plugin to work even in the demo file. The preset sections work fine, but when i set my own section nothing happens.
              I've followed every step you outlined, defining real section etc but still doesnt work for me. I have the latest version (0.6) of your plugin and am using SU 7.1 Pro.
              I have attached two images showing how your sections work but mine don't, including the error message that pops up on the ruby console. i'm stumped. HELP!
              Joel
              My section with error message
              error message
              your section
              • majidM Offline
                majid
                must be amazing... gonna tet it
                  troyhome
                  if only it worked...maybe it's only for the pc?
                  IOviz.com
                  SU Pro 2024 PC
                    RHPLUS
                    I have the same problem on PC.
                    What should we do to run this great plugin?
                      paddyclown
                      hello
                      now we are after the 31/1/2011 what happens next ?
                      as it states that realsection beta expired yesterday & using it really doesnt work now (message pops up saying it's expiresd) ???
                      thanks
                        spruzza
                        My plugin is expired 😞
                        Is there a new one coming out soon?
                        thanks
                          archigrafix
                          I get the same problem: It says plugin has expired!
                          I am on PC XP SU8in EVAL mode.
                          thanx to help. This plug seems so interesting!
                          Agir comme un homme de pensée, et penser comme un homme d'action...
                            barsaglini
                            when Define realSection Material
                            realSection is expired!
                            I really have to change the date to 2010 from my computer?
                            thks
                            • V Offline
                              vgt19
                              just curious, is access to the plugin over? I'd like to try but doesn't seem like there is anyway to get it now that it has expired.
                                archigrafix
                                I also posted a few days ago about that expired plug but not lot of moves there on the subject..?
                                Please make a sign to us all, very interested in your plugin
                                  Guy has not logged in since February 3 so must be busy with something else ATM (hopefully everything is okay with him).
                                  You guys can try to send a PM to him and if his preferences are set so, he will be notified by email.
                                    gillesalvarenga
                                    I have installed it today but it has already expired
                                    do you know where can I download a version which is not expired yet or where can I buy this plugin?
                                    thanks,
                                    • V Offline
                                      vinagre85
                                      hi! i think it's a REALLY useful plugin...
                                      BUT...mine says that is expired! and i just installed it! what should i do?
                                      i would appreciate if you could help me.
                                      thank you
                                      • F Offline
                                        finearc
                                        anybody knows where to get the up to date version of realSection? this one has expired
                                          amores
                                          Any time i wont select Define realSectionmaterial a window apear sing real section is expired.
                                          Can someone help me?
                                          • EdsonE Offline
                                            Edson
                                            perhaps we should remove from the index any plugins that are no longer functional. this one has not been working for anyone and the author seems to have deserted the forum.
                                            http://www.mahfuz.arq.br
                                            • 4 / 5
