    1.5k Posts 477 Posters 4.2m Views 477 Watching
    • Bob JamesB
      Bob James
      @frommer1 said:
      i need help loading the plugin i downloaded everything as stated, but when i open sketchup, nothing is there how do i load the plugin?
      See the directions on page 1 of this post: welcome to SketchUcation 😄
      • F
        Frommer1
        i am trying to round over the edges of a circle that is through a rectangle, as if you cut a hole in a piece of wood and then rounded the edges over. How do i do it. evertime i try it just closes the circle
        • F
          Frommer1
          I did and it still doesnt work on my laptop. I even erased the files and tried again. Any ideas. i was able to sucessfully load the plugin on a different computer however.
          • GaieusG
            Since it creates new geometry, I can imagine that those faces also are created automatically. What happens if you delete the circle(s)? Is the rounded edge there underneath?
            • F
              Frommer1
              it appears to go away completely, as if it were never there
              • GaieusG
                Could you attach the file,please? (Maybe a "before" and an "after" version of the same geometry in it)
                • mitcorbM
                  mitcorb
                  Could it be automatically re-skinning? Perhaps select the closed surface face and press Delete? Or turn on xray to see if the rounding has actually been done. I am guessing here.
                  • W
                    watkins
                    Has anyone had any problems running Round Corners under SU8. The icons are showing, but I cannot seem to get it working. Which version is now considered SU8 friendly? I am building up my SU8 plugin folder slowly, and so I have very few plugins loaded, and mostly those of Fredo6.
                    • Bob JamesB
                      Bob James
                      I use this quite often to round the edges of holes. It is normal for the hole to be "filled", but when you delete the new "filled" area, your are left with the hole with rounded edges.
                      • GaieusG
                        Yes, that's what I'd expect, too. Unless the hole is too tiny and the edges of the rounded corner would be less that that 1 mm / 1/16" limit (in which case they might be simply gone and you need to use the scale-up workaround)
                        • F
                          Frommer1
                          Here is is. i tried rounding the corners on the left hole and it is gone. the hole on the right is untouched. Please help! i tried erasing the center and the only way it shows up is if i delete some lines on the roundover
                          test hole.skp
                          • Bob JamesB
                            Bob James
                            I clicked on the area where the left hole should be. It was "filled in" as evidenced by the blue dots. I then deleted the "blue dot" area and was left with a rounded edge hole as expected.
                            • GaieusG
                              Yeah, it just fills the hole but you can delete the fill easily.
                              However in the file, the round radius was set to 7' 7/8". I figured that about 3/8" is the max "desired" radius so you may want to revise that.
                              delete this
                              end up with this
                              • fredo6F
                                @frommer1 said:
                                I tried rounding the corners on the left hole and it is gone. the hole on the right is untouched. Please help! i tried erasing the center and the only way it shows up is if i delete some lines on the roundover
                                As pointed out by Bob James and Gaieus, the rounding took place, but Sketchup automatically created a face when RoundCorner build the edges of the rounding.
                                This may happen in those situations, and actually not easy to detect and correct.
                                • F
                                  Frommer1
                                  Thanks a lot. i did what you said and got the required result. I am new to Sketchup and am still learning!
                                  • N
                                    nalkhayat
                                    I hope you can help me out with my error message? I posted a screenshot (above).
                                    • fredo6F
                                      I don't see the screenshot anywhere.
                                      Can you open the Ruby console, and check if there is anything displayed when you click on one of the RoundCorner icon.
                                      • GaieusG
                                        Here is the post with the ruby console error and the screenshot:
                                        http://forums.sketchucation.com/viewtopic.php?f=323&t=20485&p=303719#p303719
                                        • fredo6F
                                          @Gaieus: thanks for the information
                                          @Frommer1: I think I know what the issue is.
                                          On RoundCorner, there is a trace file created for Mac, because some Mac users have signaled problems with performance. See that post http://forums.sketchucation.com/viewtopic.php?f=323&t=33021#p291152
                                          The problem comes from the fact that the setup of the Mac system prevents to create files in the Sketchup Plugins directory and sub-directories from a program. This is where RoundCorner stops working.
                                          I would suggest that you try to change the security settings of the the SU Plugins folder, because anyway, you'll get the same problem when the script saves the parameters for further reuse.
                                            Really? ... I think I have to check my plugins. Think Selection Toys tries to do this.
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 20
                                            • 74
                                            • 75
                                            • 18 / 75
