    Import .eps File for Use with Push-Pull Tool?
    40 Posts 3 Posters 4.8k Views 3 Watching
    • V
      VikR
      I wanted to see if I could rule out Mac vs. PC issues, so I launched Windows in Parallels, a Windows emulator for Mac. I installed Sketchup on Windows and the SKMTools plugin. I moved the Article_1.skp file to My Documents, and ran ImageTrimmer. Here is the output from the Ruby Console:
      Error; #<Errno;;ENOENT; No such file or directory - C;\Users\Administrator\Documents\TrimmedImages\Article_I[Edges].dat>
      C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/SKMtools/ImageTrimmer.rb;233;in `readlines'
      C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/SKMtools/ImageTrimmer.rb;233;in `make_edges'
      C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/SKMtools/ImageTrimmer.rb;186;in `process_image'
        So for some reason you aren't getting the jar file to fire and make the Article_I[Edges].dat file ??? Is there a Article_I[Edges].dpng file getting made ????
        Did you check access rights to the ../Plugins/SKMtools folder and its contents were set as I explained ? πŸ˜•
        • V
          VikR
          Yes - when I run ImageTrimmer from inside SU, it appears the jar file doesn't fire. As I noted in the post before last, there is no [Edges] file in the TrimmedImages folder after running ImageTrimmer. However, if I double-click the EdgeDetector.jar file, it works correctly, and the following two files are created:
          C__Users_TIG_Desktop_Article_I[Edges].dat
          I have checked the access rights per your post.
            This a MAC OS issue... can you check your Java settings [Control Panel] so they allow 'jar' files to be executed as well as double-clicked... Sorry I can't be too helpful as I don't have access to a MAC...
            • V
              VikR
              Okay. I will run it on my wife's Windows computer.
              • V
                VikR
                I installed SU and SKMTools on my wife's Toshiba laptop running Windows 7. Running ImageTrimmer, I get the same error message in the Ruby Console:
                Error; #<Errno;;ENOENT; No such file or directory - I;\imagesToProcess\TrimmedImages\Article_I[Edges].dat>
                C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/SKMtools/ImageTrimmer.rb;163;in `initialize'
                C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/SKMtools/ImageTrimmer.rb;760;in `new'
                C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/SKMtools/ImageTrimmer.rb;233;in `call'
                As I mentioned, I'm a programmer too (although not in Ruby) and I'm used to working with error messages. Is there anything I can change here?
                  The computer's Java settings must allow jar files to run when called from a cmd/command terminal...
                  Most do... I'm no sure why both your PC and MAC don't πŸ˜• πŸ˜• πŸ˜•
                  • V
                    VikR
                    Is there a setting on my wife's Windows machine I can change to allow it to execute .jar files?
                      Is there a Java Control Panel ?
                      If not try installing Sun Java ?
                        Here are my own Java CP settings that work [I haven't changed them πŸ˜• ]...javaCP1.pngjavaCP2.pngjavaCP3.png
                        • V
                          VikR
                          I looked for the Java CP, didn't find it, and realized Java wasn't installed on the Windows machine! I installed Java, and ImageTrimmer worked perfectly.
                            Doh! πŸ˜‰
                            • V
                              VikR
                              I really appreciate all your help.
                              • 2 / 2
