    Problem with the Autosave in SU8
    5 Posts 3 Posters 1.6k Views 3 Watching
    • david_hD Offline
      david_h
      I am posting this for a friend who is using SU8 (im still on 7). I don't know if this issue is "8" related or not, but i had never seen it so I din't know how to respond.apparently when he autosaves he gets an updated SKB file but the SKP itself doesn't update so that when he closes and reopens it reverts to the previous session. That means he has to rename and open the latest SKB in order to get his latest generation. Is this a settings thing? anybody else run into this?
      THx
      David
      • jgbJ Offline
        jgb
        As far as I can understand the perceived problem, it's not a bug.
        AUTOSAVE never did update the .SKP file. Only the .SKB file (B for Backup).
        You can only update the .SKP with a manual SAVE.
        Trying to close a model session after any changes since the last true SAVE should result in a dialog asking if you want to exit or save & exit. Exit without save will result in SU asking to open the .SKB file next time you call it up.
        jgb
          Autosave generates Autosave_sketchupfilename.skp given that your working file is sketchupfilename.skp. sketchupfilename.skb (skb) files are generates when you manually save, it takes your existing sketchupfilename.skp and make a copy to sketchupfilename.skb before it overwrites sketchupfilename.skp.
          • jgbJ Offline
            jgb
            I stand corrected. 😳 (And I think you told me this before as well 😳 😳 )
            So that means the .SKB file is the file from the PREVIOUS manual save. ❓
            Then howcum my SU directory does not contain an .SKB file for each of the .SKP files??
            They are there for many, but not all, and I don't delete files (which I should).
            jgb
              Correct.
              Maybe you unticked "Create Backup" from Preferences > General ?
