    [Plugin] Proper Animation V1.08 Beta(Updated 14/11/10)
    246 Posts 108 Posters 241.6k Views 108 Watching
    • charly2008C
      charly2008
      Before i was loading the wrong script. When i loaded the correct script it tooks about 1 and 1/2 hour to render. Below the result no animation!
      Charly
      • T
        tomasz
        Excellent update Morris!
        I do like Fletch's animation πŸ˜„
        Charly
        I don't want to hijack the thread so please join the Kerkythea thread or PM me with questions.
        The important things:
        • enable Proper Animation observers
        • export animation using: Full model per frame
          Your animation will be stored in the export folder as jpgs. Use VirtualDub or similar software to build an animation file from them.
        ... now .. where is that animation feature in SU2Thea ... πŸ˜„
          danbig
          Hi Morisdov -
          Thank you for the incredible tool.
          Is there any limit on the number of positions that can be set?
            danbig
            Also -
            How does the linking of positions and scenes work if you rename your scenes?
            Does the Position 3 always link to the third scene that was created?
              akobunge
              hi to all.. i used this plugin. but once i save the animation in video file.. i cannot see the object move..please help...
                rachmatrf
                Thank you for this valuable tool...
                  rickymon
                  I solved the proper animation export issue by using another free RB plugin:
                  SmoothStepAnim.rb (Smooth Step Animation)
                  This plugin has its own export window and it recognizes all Properanimation modifications
                  AND it helps you to get smooth scenes transitions just in case u dont like the native scenes transitions from SU.
                  utube test here
                  http://www.youtube.com/watch?v=UL6tnTvphAE
                  Regards
                  Note: U can always use Twilight too...!
                  Images compiled using Sony Vegas 8
                  • F
                    Funerall
                    Twilight does fine with animated scenes. I'm using it too. After rendering images, than I combine them with VirtualDub. Works great but takes long πŸ˜„
                    But I have some problems with Proper Animation 1.08B. I'm doing everything as I should (I think), but while moving objects with scenes, linear objects become unlinear πŸ˜„ I mean some part of the object disappears and then returns back. While rendering the same thing happens. Will there be any final version of 1.08B or a new version?
                    Thanks again for the wonderful plug-in Morisdov...
                    • ashscottA
                      ashscott
                      Can anyone explain why the traditional exporter won't recognize the proper animation moving objects?
                      I'm having to export through twilight as smoothstep forces me to cut out small pauses in the animation that need to be there. However, leaving my machine for 8 hours to render an animation only to come back and find that something has been mis-interpreted or I haven't set up properly is a bit of a pain.
                      Just some stuff I do with Sketchup.
                        Jim
                        Exporting the object animations is just not something SketchUp does natively.
                        You could try the Key Frame plugin - it currently costs $19 but has a 10-day trial. It can export the animation to Scenes which can them be exported using SketchUp's built-in export options, or allow anyone to view the animation in SketchUp.
                        http://regularpolygon.blogspot.com/
                        • ashscottA
                          ashscott
                          Ok, but will that give a 'clean' export of animated objects to an AVI? Sounds like it just gives me scenes....within which SU's exporter still wont recognize animated objects.....
                          Thanks for the reponse
                          • ashscottA
                            ashscott
                            I get the gist of your keyframe tool now, very clever, currently exporting the animation, will give an update.
                            I'm surprised there isn't a simple ruby exporter based (perhaps) on add_frame_change_observer that would allow you to export an image stream of exactly what is seen in SU......Google Earth has this kind of functionality; in fact it appears to be the most robust hi res export option in Google Earth.....
                            Excuse me if this is a poor suggestion as I don't understand ruby well.
                            • ashscottA
                              ashscott
                              So if I am going to use keyframes animation the whole animation needs to be done with the plugin.....
                              It looks like a nice bit of gear but I have three models in sequence which will be edited together to make a movie and all the models have been prepared with proper_animation.rb
                              Looks like I will have to use fraps (high res screen capture) for this one.
                              Thanks for your help.
                              • ashscottA
                                ashscott
                                Anyone else noticed that object transitions cease to work after 25 scenes?
                                • ashscottA
                                  ashscott
                                  Morisdov,
                                  not sure if you know, although I'm sure you do, but the longer a scene transition is the further "out of sync" the animation easing settings become. That is, if the scene transition time is set to a longer period (say 10 seconds), in proper animation, then the default animation easing settings (0.3 - whatever that means!) will cause the transition to occur too quickly (IE the object will animate in 6 seconds and sit idle for 4). Yet if the object's transition time is very short - say 0.5 seconds - the animation easing settings will often need to be increased to stop the object animating too slowly and 'jumping' to position at the end of the scene.
                                  This is all supposing that the goal is to get objects to animate for the whole scene transition time and no more resulting in the smoothest animation possible.
                                  It appears, after many hours using your wonderful plugin, that the correlation between the animation easing requirement and the scene transition time setting is linear. But I haven't tested that theory. If the correlation is linear then it would be easy to have the animation easing settings automatically set themselves in relation to the scene transition time that the user selects.....
                                  Perhaps this is all hogwash but it seemed logical to me so thought I would contribute it if it will help this wonderful plugin become even better.
                                  Have created a very large animation (have used 5 different models with 25 scenes in each as there appears to be issues after scene 25) and am very grateful for your work. Please keep it up.
                                  Regards
                                  Ash
                                  • FletchF
                                    Fletch
                                    Morisdov, just wanted to let you know, we just put this vid. up on youtube - keep up the great work. πŸ‘
                                    http://www.youtube.com/watch?v=JKLp1q4b3YU
                                    [youtube]JKLp1q4b3YU[/youtube] <-- how to embed youtube video?
                                    Fletch
                                    • GaieusG
                                      YouTube - Twilight Render SketchUp Animation - Building Progress
                                      [flash=480,385:232rymld]http://www.youtube.com/v/JKLp1q4b3YU?fs=1&hl=en_US[/flash:232rymld]
                                      [url=http://www.youtube.com/watch?v=JKLp1q4b3YU]YouTube - Twilight Render SketchUp Animation - Building Progress[/url]
                                      [flash=480,385]http://www.youtube.com/v/JKLp1q4b3YU?fs=1&hl=en_US[/flash]
                                      • ashscottA
                                        ashscott
                                        Fletch,
                                        Thats awesome! Very nice work
                                        If it's useful to anyone, turning off Vsync on your graphics card improves the 'smoothness' of animations recorded with fraps.
                                        This isn't a problem if you use rendering software that exports to image stream......A render tool called 'Twilight' comes to mind. πŸ˜‰
                                        • O
                                          otb designworks
                                          I am experiencing a SU crash every time I open a file and attempt to get a previously set position.
                                          Almost always on the first attempt and, rarely, on the second attempt. I have never been able to get 3 positions without a crash.
                                          It doesn't matter if I attempt to get a position for a single component or different ones.
                                          Mac 10.5.8 and SU 8
                                          I am attaching one of Google's crash logs, if that helps.
                                          EFF94107-F3E1-42A2-A8A7-EFB34A8829FE.dmp.zip
                                          Cheers, Chuck
                                          OTB Designworks is on Youtube
                                          • L
                                            lampliter
                                            I just used this plugin for the first time. It is the coolest thing since su.However I had a huge problem. It seems the objects disappear in the animation. It occured to me the objects only render as long as they are with in the thickness of the geometry itself. So I put some stationary geometry out side the paramerters of my animation and everything works fine. I just wanted to share this incase someone else has the same problem. Sorry if this is already well known, but I couldn`t find a fix other than this. Thanks again for the plugin.
                                            • 11
                                            • 12
                                            • 13
                                            • 9 / 13
