    Center point of ARC?
    5 Posts 5 Posters 3.8k Views 5 Watching
      lapx
      Is there a ruby to find center point of selected arc? I know there is center point of circle and Chris's center point of explode arc by select two segnments but I want something that does not require exploding the arc or tracing segments.
      edit:Found It!
      http://forums.sketchucation.com/viewtopic.php?f=323&t=30506
      • simon le bonS Offline
        simon le bon
        And if you just need this single tool,
        There is the simple to use Jim's plugin Arc Centerpoint
        Select your curve, right clic, arc centerpoint.
        • mitcorbM Offline
          mitcorb
          If the arc is one item, select it, right click fly out menu has Point at Center and will place a cpoint at the center of the arc.
            Jim
            This depends on having the "Ruby Script Example" Extension enabled, which also turns on some other menus I didn't want. I write my version before I realized this. 😄
            (Link was broke now fixed - thanks Simon.)
            • jeff hammondJ Offline
              @lapx said:
              edit:Found It!
              yeah, that's the best one nowadays (imo)..
              it deals with all the different variations (arcs,circles,exploded, etc) + other cpoint tools all in one package.
