Center point of ARC?
Is there a ruby to find center point of selected arc? I know there is center point of circle and Chris's center point of explode arc by select two segnments but I want something that does not require exploding the arc or tracing segments.
edit:Found It!
http://forums.sketchucation.com/viewtopic.php?f=323&t=30506Thanks!
And if you just need this single tool,
There is the simple to use Jim's plugin Arc Centerpoint
Select your curve, right clic, arc centerpoint. -
If the arc is one item, select it, right click fly out menu has Point at Center and will place a cpoint at the center of the arc.
This depends on having the "Ruby Script Example" Extension enabled, which also turns on some other menus I didn't want. I write my version before I realized this.
(Link was broke now fixed - thanks Simon.)
@lapx said:
edit:Found It!
yeah, that's the best one nowadays (imo)..
it deals with all the different variations (arcs,circles,exploded, etc) + other cpoint tools all in one package.
