    Ordering 3dpoints ?
    36 Posts 8 Posters 5.6k Views 8 Watching
      @didier bur said:
      Anyone knows a way to order 4 points in a clockwise or ccw manner, given the 4 points and assuming their are coplanar ?
      I'm actually generating faces that are "butterfly shaped", and the only way I've found to detect these sort of face is to test if two of its edges intersect. 😳
      Yoy should find that faces.outer_loop.vertices always return ccwise [about face.normal] and all other (face.loops-[face.outer_loop]).each{loop|loop.vertices} [holes etc] are cwise. If they are loop vertices they must be coplanar... Why not quickly make a grouped face using the points and get the vertices back to points ?
      I deduce you want to take any 4 coplanar points and make a face from them that's NOT a 'bow-tie' ?
      Think of it another way...
      Work inside a group's entities.
      If the points are coplanar any three can define a plane.
      Join three with edges.
      Take the last point and add edges from it to the three other points that are the nearest.
      Now find faces for all of these 6 edges.
      Now two of these edges has two faces - erase them.
      You now have a quad that's not 'bow-tied' ?
      • fredo6F Offline
        @didier bur said:
        Anyone knows a way to order 4 points in a clockwise or ccw manner, given the 4 points and assuming they are coplanar ?
        Didier,
        If points P1, P2, P3, P4 are coplanar, then, I think you can
        • compute the barycenter G of the 4 points
        • sort the points P2, P3, P4 by the angle between G->P1 and G->Pi
          Cleverbeans
          First it's important to note that such a face may not be unique. Say for example if you take the points (0,0),(1,1),(-1,1) and (0,-1) then every ordering that starts with (0,0) will either be clockwise or counter-clockwise but depending on way you put the other points in will get a different face. If you can always count on the face being convex however I believe this ambiguity vanishes.
          To order them appropriately, you can first choose any three points, and just put them in any order, which will either be clockwise or counter-clockwise. Now you want to add the fourth point into the order at the correct spot so that you don't get that intersection issue. You can convince yourself pretty easily that if you draw a triangle, and take a point outside that triangle you basically want to connect it to two points without crossing any of the existing lines on the triangle. From here, it's easy to see that you want to connect it to the two points which are closest to it. Here is some code which will return the points in the desired order under the conditions given.
          def order_points(points)
             #Given an array of four coplanar, convex point3d objects,  returns the points in convex order
             pt = points[0]
             triangle = points[1..-1] #the triangle which is already either clockwise or counter-clockwise
             distances = points.map{|x| pt.distance_to(x)}
             i = distances.index(distances.max()) #this finds the index of the point which is furthest away in the points array
             if i == 0 then
                 return triangle[0..1] + [pt] + triangle[2]
             elsif i==1 then
                 return triangle + [pt]
             else
                 return [pt] + triangle
          I think that should do the trick. 😄
          • Didier BurD Offline
            Didier Bur
            Me again,
            Thanks all for your answers,
            @TIG: I'd better use a 'theoric' way, instead of using SketchUp (that slows down the computation too much)
            @Fredo6: why didn't I thought of that 😳
            Cleverbeans has a clever solution too 👍
            DB
              Didier Bur
              I've implemented CleverBeans solution to order the points but found that it does not work:
              elsif i==1 then
                     else
              two cases that creates exactly the same quad face is not cool 😉
              Here is my slightly different coding:
              # Given a set of 4 coplanar 3dPoints, returns the points in convex order
                  def quadOrderPoints(pArray)
              		pt = pArray[0]
              		triangle = pArray[1..-1] #the triangle which is already either clockwise or counter-clockwise
              		distances =triangle.map{ |x| pt.distance(x) }
              		#Find the index of the point which is furthest away in the points array
              		case i
              			when 0
              				return [pArray[1],pArray[2],pArray[0],pArray[3]]
              			when 1
              				return [pArray[1],pArray[2],pArray[3],pArray[0]]
              			when 2
              				return [pArray[0],pArray[1],pArray[2],pArray[3]]
              Why it doesn't work: here on the image, triangle is p1,p2,p3, and p0 is the first point in the array to order.
              Greatest distance from p0 to one of the triangle vertices is shown in red.
              Left figure shows, as 'distances.max' index will be 0, that quad will be (according to the algorithm): p1,p2,p0,p3
              Right figure shows that 'distances.max index will be 1, so the quad will be (according to the algorithm): p1,p2,p3,P0, or p0,p1,p2,p3.
              BUT both figures suggest that the quad has to be p0,p1,p2,p3.
              I've tested it and about half of the quads are wrong.
              DB
              • Dan RathbunD Offline
                Dan Rathbun
                What about about using a temporary BouningBox around the 4 pts.
                Each pt would lie on one of the BB's planes. 2 of the BB's planes would not have a point.
                Either the vertical planes will have the pts, or the top and bottom and 2 side planes will have the points.
                I'm not here much anymore.
                • Chris FullmerC Offline
                  I can only manage to describe this in 2d, so you get to implement it onto any 3d plane. I tihnk it is similar to what Fredo suggested - his is probably faster. Mine requires re-calculating on each point. But mine works to find the convex face that bounds MANY points if needed.
                  Get the point in the most negative x location. Then get the angle between the vector -1,0,0 and the vector from your point to all other points. The smallest angle is the next point in the convex face. You have to make sure you are always getting the angle going in the correct direction (clockwise or counter-clockwise). Then use the previous vector as the new base vector when you go to test for the next point.
                  I made a video that shows it. Think of the protractor as doing the testing. It rotates until it finds the next point to use - it is the point with the smallest angle.
                  There is no sound.
                  [flash=638,509:26c6u44v]http://www.chrisfullmer.com/forums/convex_face_finder.swf[/flash:26c6u44v]
                    Jim
                    Start by looking at the cross product of each vertex's edge vectors.
                    model = Sketchup.active_model
                    entities = model.entities
                    selection = model.selection
                    pts = [  [0, 0], [0, 1], [1, 1], [1, 0] ]
                    pts2 = [ pts[0], pts[2], pts[1], pts[3] ]
                    g1 = entities.add_group
                    g1.entities.add_face pts
                    pts.each_with_index{|pt, i| g1.entities.add_text((i+1).to_s, pt)}
                    g1.name = "Normal"
                    g2 = entities.add_group
                    g2.entities.add_face pts2
                    g2.name = "Swapped"
                    pts2.each_with_index{|pt, i| g2.entities.add_text((i+1).to_s, pt)}
                    def show_cross(ents, ary)
                      p1, p2, p3, p4 = ary
                      n1 = ((p1.vector_to p4) * (p1.vector_to p2)).normalize
                      n2 = ((p2.vector_to p1) * (p2.vector_to p3)).normalize
                      n3 = ((p3.vector_to p2) * (p3.vector_to p4)).normalize
                      n4 = ((p4.vector_to p3) * (p4.vector_to p1)).normalize
                      ents.add_line(p1, p1.offset(n1))
                      ents.add_line(p2, p2.offset(n2))
                      ents.add_line(p3, p3.offset(n3))
                      ents.add_line(p4, p4.offset(n4))
                    show_cross(g1.entities, pts)
                    show_cross(g2.entities, pts2)
                      http://en.wikipedia.org/wiki/Graham_scan ?
                      Ensures 'convex' shapes...
                        I got an implementation of Grahams Scan in TT_Lib (version 1)
                        From geom2d.rb
                        <span class="syntaxdefault"><br /></span><span class="syntaxcomment"># Graham's Scan<br /># Computational Geometry Algorythms and Appliations (ISBN-10; 3540779736)<br /># Chapter 1.1<br />#<br /># @param [Array<Geom;;Point3d>] points<br /># @return [Array<Geom;;Point3d>]<br /># @since 1.1.0<br /></span><span class="syntaxdefault">def self</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">convex_hull</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">points</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">  return nil if points</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">length </span><span class="syntaxkeyword"><</span><span class="syntaxdefault"> 2<br />  <br />  points </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> self</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">sort_points_by_x_y</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">points</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">  <br />  l_upper </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">[</span><span class="syntaxdefault"> points</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">0</span><span class="syntaxkeyword">],</span><span class="syntaxdefault"> points</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">1</span><span class="syntaxkeyword">]</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">]<br /></span><span class="syntaxdefault">  2</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">upto</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">points</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">length </span><span class="syntaxkeyword">-</span><span class="syntaxdefault"> 1</span><span class="syntaxkeyword">)</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">{</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">|</span><span class="syntaxdefault">i</span><span class="syntaxkeyword">|<br /></span><span class="syntaxdefault">    l_upper </span><span class="syntaxkeyword"><<</span><span class="syntaxdefault"> points</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">i</span><span class="syntaxkeyword">]<br /></span><span class="syntaxdefault">    while l_upper</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">length </span><span class="syntaxkeyword">></span><span class="syntaxdefault"> 2 </span><span class="syntaxkeyword">&&</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">!</span><span class="syntaxdefault">self</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">right_turn</span><span class="syntaxkeyword">?(</span><span class="syntaxdefault">l_upper</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">last</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">3</span><span class="syntaxkeyword">))<br /></span><span class="syntaxdefault">      l_upper</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">delete_at</span><span class="syntaxkeyword">(-</span><span class="syntaxdefault">2</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">    end<br />  </span><span class="syntaxkeyword">}<br /></span><span class="syntaxdefault">  <br />  l_lower </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">[</span><span class="syntaxdefault"> points</span><span class="syntaxkeyword">[-</span><span class="syntaxdefault">1</span><span class="syntaxkeyword">],</span><span class="syntaxdefault"> points</span><span class="syntaxkeyword">[-</span><span class="syntaxdefault">2</span><span class="syntaxkeyword">]</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">]<br /></span><span class="syntaxdefault">  </span><span class="syntaxkeyword">(</span><span class="syntaxdefault">points</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">length </span><span class="syntaxkeyword">-</span><span class="syntaxdefault"> 3</span><span class="syntaxkeyword">).</span><span class="syntaxdefault">downto</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">0</span><span class="syntaxkeyword">)</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">{</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">|</span><span class="syntaxdefault">i</span><span class="syntaxkeyword">|<br /></span><span class="syntaxdefault">    l_lower </span><span class="syntaxkeyword"><<</span><span class="syntaxdefault"> points</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">i</span><span class="syntaxkeyword">]<br /></span><span class="syntaxdefault">    while l_lower</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">length </span><span class="syntaxkeyword">></span><span class="syntaxdefault"> 2 </span><span class="syntaxkeyword">&&</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">!</span><span class="syntaxdefault">self</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">right_turn</span><span class="syntaxkeyword">?(</span><span class="syntaxdefault">l_lower</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">last</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">3</span><span class="syntaxkeyword">))<br /></span><span class="syntaxdefault">      l_lower</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">delete_at</span><span class="syntaxkeyword">(-</span><span class="syntaxdefault">2</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">    end<br />  </span><span class="syntaxkeyword">}<br /></span><span class="syntaxdefault">  l_lower</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">delete_at</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">0</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">  l_lower</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">delete_at</span><span class="syntaxkeyword">(-</span><span class="syntaxdefault">1</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">  <br />  return l_upper </span><span class="syntaxkeyword">+</span><span class="syntaxdefault"> l_lower<br />end<br /><br /><br /></span><span class="syntaxcomment"># Lexicographic order x, y<br />#<br /># @param [Array<Geom;;Point3d>] points<br /># @return [Array<Geom;;Point3d>]<br /># @since 1.1.0<br /></span><span class="syntaxdefault">def self</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">sort_points_by_x_y</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">points</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">  return points</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">sort </span><span class="syntaxkeyword">{</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">|</span><span class="syntaxdefault">a</span><span class="syntaxkeyword">,</span><span class="syntaxdefault">b</span><span class="syntaxkeyword">|</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">(</span><span class="syntaxdefault">a</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">x</span><span class="syntaxkeyword">==</span><span class="syntaxdefault">b</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">x</span><span class="syntaxkeyword">)</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">?</span><span class="syntaxdefault"> a</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">y </span><span class="syntaxkeyword"><=></span><span class="syntaxdefault"> b</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">y </span><span class="syntaxkeyword">;</span><span class="syntaxdefault"> a</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">x </span><span class="syntaxkeyword"><=></span><span class="syntaxdefault"> b</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">x </span><span class="syntaxkeyword">}<br /></span><span class="syntaxdefault">end<br /></span>
                          Didier Bur
                          Thanks TIG and TT, I was just starting coding Graham's scan, this will save me time.
                          Left turn/right turn and cross products will do the trick I presume.
                          What's all that for: I'm working on subdivision curves and surfaces: Catmull-Clark, Loop, Doo-Sabin, Peters-Reif, Kobbelt, Chaikin, and others. Peters-Reif seemed too me the simplest algorithm but turned out to be one of the most complex, comparing to Catmull which I have coded in an hour or so.
                          I'm facing the CW/CCW and ordering problem, and the 'correctly orienting faces' problem. That's fun 😄
                          @TT: didn't you encounter problems with == method when comparing Floats (in (a.x==b.x) for instance) ?
                          I've come across this:
                          plane1=Geom.fit_plane_to_points(pArray[0],pArray[1],pArray[2])
                          plane2=(Geom.fit_plane_to_points(pArray[0],pArray[1],pArray[3]))
                          return plane1==plane2
                          Assuming the 4 3dPoints are coplanar, this always return false. I had to code another method 'isEqual?' for the Float class that compares with a tolerance of 1 to the power of -10 to get correct results when comparing such arrays of floats.
                          DB
                            Good point. I haven't tested it that much, I just ported some pseudo code which I read in a book.
                            One should probably do a tolerance comparison.
                            [quote="Didier Bur"]
                            <span class="syntaxdefault"><br /></span><span class="syntaxcomment">#&nbsp;Check&nbsp;if&nbsp;all&nbsp;points&nbsp;in&nbsp;the&nbsp;array&nbsp;are&nbsp;on&nbsp;the&nbsp;same&nbsp;plane.<br />#<br />#&nbsp;@todo&nbsp;Ensure&nbsp;that&nbsp;the&nbsp;first&nbsp;three&nbsp;points&nbsp;are&nbsp;not&nbsp;co-linear.<br />#<br />#&nbsp;@param&nbsp;[Array<Geom;;Point3d>]&nbsp;points<br />#<br />#&nbsp;@since&nbsp;2.0.0<br /></span><span class="syntaxdefault">def&nbsp;self</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">planar_points</span><span class="syntaxkeyword">?(</span><span class="syntaxdefault">points</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;return&nbsp;</span><span class="syntaxdefault">false&nbsp;</span><span class="syntaxkeyword">if&nbsp;</span><span class="syntaxdefault">points</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">length&nbsp;</span><span class="syntaxkeyword"><&nbsp;</span><span class="syntaxdefault">3<br />&nbsp;&nbsp;v1&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">points</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">0</span><span class="syntaxkeyword">].</span><span class="syntaxdefault">vector_to</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">points</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">1</span><span class="syntaxkeyword">])<br />&nbsp;&nbsp;</span><span class="syntaxdefault">v2&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">points</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">0</span><span class="syntaxkeyword">].</span><span class="syntaxdefault">vector_to</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">points</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">2</span><span class="syntaxkeyword">])<br />&nbsp;&nbsp;return&nbsp;</span><span class="syntaxdefault">false&nbsp;unless&nbsp;v1</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">valid</span><span class="syntaxkeyword">?&nbsp;&&&nbsp;</span><span class="syntaxdefault">v2</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">valid</span><span class="syntaxkeyword">?<br />&nbsp;&nbsp;</span><span class="syntaxdefault">vector&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">v1&nbsp;</span><span class="syntaxkeyword">*&nbsp;</span><span class="syntaxdefault">v2<br />&nbsp;&nbsp;plane&nbsp;</span><span class="syntaxkeyword">=&nbsp;[&nbsp;</span><span class="syntaxdefault">points</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">0</span><span class="syntaxkeyword">],&nbsp;</span><span class="syntaxdefault">vector&nbsp;</span><span class="syntaxkeyword">]<br />&nbsp;&nbsp;</span><span class="syntaxdefault">3.upto</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">points</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">length</span><span class="syntaxkeyword">-</span><span class="syntaxdefault">1</span><span class="syntaxkeyword">)&nbsp;{&nbsp;|</span><span class="syntaxdefault">i</span><span class="syntaxkeyword">|<br />&nbsp;&nbsp;&nbsp;&nbsp;return&nbsp;</span><span class="syntaxdefault">false&nbsp;unless&nbsp;points</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">i</span><span class="syntaxkeyword">].</span><span class="syntaxdefault">on_plane</span><span class="syntaxkeyword">?(</span><span class="syntaxdefault">plane</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;}<br />&nbsp;&nbsp;return&nbsp;</span><span class="syntaxdefault">true<br />end<br /></span>
                              I wish I could understand algorithm formulas. I always need to search up a pseudo code version, or an implementation in another language to work it out. 😞
                                Actually, Point3d.x, Point3d.y and Point3d.z return Length objects. They have built in tolerances - same as SU's.
                                You can easily get in trouble with unpredictable results if you're not 100% sure if you're dealing with Floats or Lengths.
                                  Didier Bur
                                  Me too. When I speak of 'algorithm' I mean pseudo-code or (even better) natural language 😄
                                  Here is my snippet for coplanarity test of 4 points (can be extended to any number of points):
                                  # Given a set of 4 3dPoints, return true if coplanar, or false
                                  	def quadPointsCoplanar?(pArray)
                                  		return (Geom.fit_plane_to_points(pArray[0],pArray[1],pArray[2]).isEqual?(Geom.fit_plane_to_points(pArray[0],pArray[1],pArray[3])))
                                  Where Array of floats comparison method must be 'aliased' with isEqual?
                                  class Array
                                  	def isEqual?(otherArray)
                                  		self.each_index { |i| return false if self[i].isNotEqual(otherArray[i]) }
                                  		return true
                                  and where == method for floats must be aliased with isNotEqual()
                                  class Float
                                  	def isNotEqual(value)
                                  		delta = self - value
                                  		return ((delta > Math;;EPSILON) or (delta < -Math;;EPSILON))
                                  and finaly requires a constant
                                  Math.const_set("EPSILON", 1.0e-10)
                                  DB
                                    I came across a very good site on the topic of floating precision: http://floating-point-gui.de/
                                    Comparison with tolerance is a bit more complex in order to account for the various pit-falls.
                                    http://floating-point-gui.de/errors/comparison/
                                      Ooops! Seems that I forgot to post all required methods:
                                      <span class="syntaxdefault"><br />module TT_Lib<br /> module Geom2D<br />  <br />  </span><span class="syntaxcomment"># Graham's Scan<br /></span><span class="syntaxdefault">  </span><span class="syntaxcomment"># Computational Geometry Algorythms and Appliations (ISBN-10; 3540779736)<br /></span><span class="syntaxdefault">  </span><span class="syntaxcomment"># Chapter 1.1<br /></span><span class="syntaxdefault">  </span><span class="syntaxcomment">#<br /></span><span class="syntaxdefault">  </span><span class="syntaxcomment"># @param [Array<Geom;;Point3d>] points<br /></span><span class="syntaxdefault">  </span><span class="syntaxcomment"># @return [Array<Geom;;Point3d>]<br /></span><span class="syntaxdefault">  </span><span class="syntaxcomment"># @since 1.1.0<br /></span><span class="syntaxdefault">  def self</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">convex_hull</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">points</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">    return nil if points</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">length </span><span class="syntaxkeyword"><</span><span class="syntaxdefault"> 2<br />    <br />    points </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> self</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">sort_points_by_x_y</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">points</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">    <br />    l_upper </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">[</span><span class="syntaxdefault"> points</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">0</span><span class="syntaxkeyword">],</span><span class="syntaxdefault"> points</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">1</span><span class="syntaxkeyword">]</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">]<br /></span><span class="syntaxdefault">    2</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">upto</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">points</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">length </span><span class="syntaxkeyword">-</span><span class="syntaxdefault"> 1</span><span class="syntaxkeyword">)</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">{</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">|</span><span class="syntaxdefault">i</span><span class="syntaxkeyword">|<br /></span><span class="syntaxdefault">      l_upper </span><span class="syntaxkeyword"><<</span><span class="syntaxdefault"> points</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">i</span><span class="syntaxkeyword">]<br /></span><span class="syntaxdefault">      while l_upper</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">length </span><span class="syntaxkeyword">></span><span class="syntaxdefault"> 2 </span><span class="syntaxkeyword">&&</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">!</span><span class="syntaxdefault">self</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">right_turn</span><span class="syntaxkeyword">?(</span><span class="syntaxdefault">l_upper</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">last</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">3</span><span class="syntaxkeyword">))<br /></span><span class="syntaxdefault">        l_upper</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">delete_at</span><span class="syntaxkeyword">(-</span><span class="syntaxdefault">2</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">      end<br />    </span><span class="syntaxkeyword">}<br /></span><span class="syntaxdefault">    <br />    l_lower </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">[</span><span class="syntaxdefault"> points</span><span class="syntaxkeyword">[-</span><span class="syntaxdefault">1</span><span class="syntaxkeyword">],</span><span class="syntaxdefault"> points</span><span class="syntaxkeyword">[-</span><span class="syntaxdefault">2</span><span class="syntaxkeyword">]</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">]<br /></span><span class="syntaxdefault">    </span><span class="syntaxkeyword">(</span><span class="syntaxdefault">points</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">length </span><span class="syntaxkeyword">-</span><span class="syntaxdefault"> 3</span><span class="syntaxkeyword">).</span><span class="syntaxdefault">downto</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">0</span><span class="syntaxkeyword">)</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">{</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">|</span><span class="syntaxdefault">i</span><span class="syntaxkeyword">|<br /></span><span class="syntaxdefault">      l_lower </span><span class="syntaxkeyword"><<</span><span class="syntaxdefault"> points</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">i</span><span class="syntaxkeyword">]<br /></span><span class="syntaxdefault">      while l_lower</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">length </span><span class="syntaxkeyword">></span><span class="syntaxdefault"> 2 </span><span class="syntaxkeyword">&&</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">!</span><span class="syntaxdefault">self</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">right_turn</span><span class="syntaxkeyword">?(</span><span class="syntaxdefault">l_lower</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">last</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">3</span><span class="syntaxkeyword">))<br /></span><span class="syntaxdefault">        l_lower</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">delete_at</span><span class="syntaxkeyword">(-</span><span class="syntaxdefault">2</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">      end<br />    </span><span class="syntaxkeyword">}<br /></span><span class="syntaxdefault">    l_lower</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">delete_at</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">0</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">    l_lower</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">delete_at</span><span class="syntaxkeyword">(-</span><span class="syntaxdefault">1</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">    <br />    return l_upper </span><span class="syntaxkeyword">+</span><span class="syntaxdefault"> l_lower<br />  end<br />  <br />  <br />  </span><span class="syntaxcomment"># @param [Array<Geom;;Point3d>] points<br /></span><span class="syntaxdefault">  </span><span class="syntaxcomment"># @return [Array<Geom;;Point3d>]<br /></span><span class="syntaxdefault">  </span><span class="syntaxcomment"># @since 1.1.0<br /></span><span class="syntaxdefault">  def self</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">sort_points_by_x</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">points</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">    return points</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">sort </span><span class="syntaxkeyword">{</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">|</span><span class="syntaxdefault">a</span><span class="syntaxkeyword">,</span><span class="syntaxdefault">b</span><span class="syntaxkeyword">|</span><span class="syntaxdefault"> a</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">x </span><span class="syntaxkeyword"><=></span><span class="syntaxdefault"> b</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">x </span><span class="syntaxkeyword">}<br /></span><span class="syntaxdefault">  end<br />  <br />  <br />  </span><span class="syntaxcomment"># Lexicographic order x, y<br /></span><span class="syntaxdefault">  </span><span class="syntaxcomment">#<br /></span><span class="syntaxdefault">  </span><span class="syntaxcomment"># @param [Array<Geom;;Point3d>] points<br /></span><span class="syntaxdefault">  </span><span class="syntaxcomment"># @return [Array<Geom;;Point3d>]<br /></span><span class="syntaxdefault">  </span><span class="syntaxcomment"># @since 1.1.0<br /></span><span class="syntaxdefault">  def self</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">sort_points_by_x_y</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">points</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">    return points</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">sort </span><span class="syntaxkeyword">{</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">|</span><span class="syntaxdefault">a</span><span class="syntaxkeyword">,</span><span class="syntaxdefault">b</span><span class="syntaxkeyword">|</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">(</span><span class="syntaxdefault">a</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">x</span><span class="syntaxkeyword">==</span><span class="syntaxdefault">b</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">x</span><span class="syntaxkeyword">)</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">?</span><span class="syntaxdefault"> a</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">y </span><span class="syntaxkeyword"><=></span><span class="syntaxdefault"> b</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">y </span><span class="syntaxkeyword">;</span><span class="syntaxdefault"> a</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">x </span><span class="syntaxkeyword"><=></span><span class="syntaxdefault"> b</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">x </span><span class="syntaxkeyword">}<br /></span><span class="syntaxdefault">  end<br />  <br />  <br />  </span><span class="syntaxcomment"># @param [Array<Geom;;Point3d>] points array of 3 +Geom;;Point3d+ objects.<br /></span><span class="syntaxdefault">  </span><span class="syntaxcomment"># @since 1.1.0 - Renamed from +.right_turn+ to +.right_turn?+ at version 1.2.0<br /></span><span class="syntaxdefault">  def self</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">right_turn</span><span class="syntaxkeyword">?(</span><span class="syntaxdefault">points</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">    p</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> q</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> r </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> points<br />    array </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">[</span><span class="syntaxdefault"> 1</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> p</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">x</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> p</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">y</span><span class="syntaxkeyword">,<br /></span><span class="syntaxdefault">          1</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> q</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">x</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> q</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">y</span><span class="syntaxkeyword">,<br /></span><span class="syntaxdefault">          1</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> r</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">x</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> r</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">y </span><span class="syntaxkeyword">]<br /></span><span class="syntaxdefault">    return self</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">determinant_3x3</span><span class="syntaxkeyword">(array)</span><span class="syntaxdefault"> </span><span class="syntaxkeyword"><</span><span class="syntaxdefault"> 0.0<br />  end<br />  <br />  </span><span class="syntaxcomment"># @param [Array<Number>] array<br /></span><span class="syntaxdefault">  </span><span class="syntaxcomment"># @return [Number]<br /></span><span class="syntaxdefault">  </span><span class="syntaxcomment"># @since 1.1.0<br /></span><span class="syntaxdefault">  def self</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">determinant_3x3</span><span class="syntaxkeyword">(array)<br /></span><span class="syntaxdefault">    a</span><span class="syntaxkeyword">,</span><span class="syntaxdefault">b</span><span class="syntaxkeyword">,</span><span class="syntaxdefault">c</span><span class="syntaxkeyword">,</span><span class="syntaxdefault">d</span><span class="syntaxkeyword">,</span><span class="syntaxdefault">e</span><span class="syntaxkeyword">,</span><span class="syntaxdefault">f</span><span class="syntaxkeyword">,</span><span class="syntaxdefault">g</span><span class="syntaxkeyword">,</span><span class="syntaxdefault">h</span><span class="syntaxkeyword">,</span><span class="syntaxdefault">i </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> array<br />    return a</span><span class="syntaxkeyword">*</span><span class="syntaxdefault">e</span><span class="syntaxkeyword">*</span><span class="syntaxdefault">i </span><span class="syntaxkeyword">-</span><span class="syntaxdefault"> a</span><span class="syntaxkeyword">*</span><span class="syntaxdefault">f</span><span class="syntaxkeyword">*</span><span class="syntaxdefault">h </span><span class="syntaxkeyword">+</span><span class="syntaxdefault"> b</span><span class="syntaxkeyword">*</span><span class="syntaxdefault">f</span><span class="syntaxkeyword">*</span><span class="syntaxdefault">g </span><span class="syntaxkeyword">-</span><span class="syntaxdefault"> b</span><span class="syntaxkeyword">*</span><span class="syntaxdefault">d</span><span class="syntaxkeyword">*</span><span class="syntaxdefault">i </span><span class="syntaxkeyword">+</span><span class="syntaxdefault"> c</span><span class="syntaxkeyword">*</span><span class="syntaxdefault">d</span><span class="syntaxkeyword">*</span><span class="syntaxdefault">h </span><span class="syntaxkeyword">-</span><span class="syntaxdefault"> c</span><span class="syntaxkeyword">*</span><span class="syntaxdefault">e</span><span class="syntaxkeyword">*</span><span class="syntaxdefault">g<br />  end<br />  <br /> end </span><span class="syntaxcomment"># module Geom2D<br /></span><span class="syntaxdefault">end </span><span class="syntaxcomment"># module TT_Lib<br /></span><span class="syntaxdefault"> </span>
                                      • fredo6F Offline
                                        > 	end
                                        I had a method for that in LibFredo6. Here is the code (slightly modified in order to return the plane or nil)
                                        #Check if a set of points are coplanar
                                        #  --> Return the plane or nil
                                        def G6.points_coplanar?(pts)
                                        	n = pts.length
                                        	return nil if n < 3
                                        	return Geom.fit_plane_to_points(pts) if n == 3
                                        	n1 = [n / 2, 3].max
                                        	n2 = [n - n1, 3].max
                                        	plane1 = Geom.fit_plane_to_points *(pts[0..n1-1])
                                        	plane2 = Geom.fit_plane_to_points *(pts[n-n2..n-1])
                                        	normal1 = Geom;;Vector3d.new *plane1[0..2]
                                        	normal2 = Geom;;Vector3d.new *plane2[0..2]
                                        	(normal1.parallel?(normal2) && pts[0].on_plane?(plane2)) ? plane1 ; nil
                                        PS: I don't think it is a good idea to extend the Array and Float ruby classes. Better used a specific private method
                                        def compare_float_arrays(array1, array2, epsilon)
                                           for i in 0..array1.length
                                               return false if (array1[i] - array2[i]).abs > epsilon
                                           true
                                          Ditto. Any Ruby and Sketchup base classes. There's been a few cases with clashes over methods like this.
                                            Dan Rathbun
                                            And I was going to say the same... and also suggest a compare method with multiple arguemnts.
                                            1) Never extend Ruby base classes, solely to solve one coding challenge that only applies to your project. Use a custom subclass and extend that subclass.
                                            IF you absolutely must have an instance method that acts on the object... then you should create a custom Array subclass and/or a custom Float subclass, and then add your custom methods to those custom classes.
                                            2) Custom classes are never defined at the top level (only Ruby base classes are.) Just because someone else does it, does not mean you should.
                                            Just as Google defined their custom classes inside the modules (Sketchup, UI, Geom,) you should define any custom classes inside your Toplevel module (but they can be nested inside submodules if you wish.)
                                            3) There is an alternative to extending base classes or creating a custom subclass. It's called extending an object. You create a mixin module that has your custom method(s) in it, written as instance methods (not module methods.) Then when you have an INSTANCE object, you extend that specific object via:
                                            require 'epsilon_compare.rb' my_array.extend(EpsilonCompare)
                                            Then that specific array (and only that array,) will have your custom method(s). This way you do not interfere with the rest of the Ruby world's use of the Array class.
                                            4) Sometimes it is necessary to extend or fix a base class for everyone, but this should be done with community approval... and likely for temporary use only, until either the SU API or the Ruby Core can be updated to include the fix or feature. (I'm actually working on such a global fix right now.. but I will post it in the SKX forum for comment and testing. I will not just release it to the Sketchup world, unitl it's tested, proven and approved.)
