    Co-work on a same file, possible?
    15 Posts 10 Posters 2.6k Views 10 Watching
    • mitcorbM
      mitcorb
      Someone asked a similar question just yesterday. Let me see if I can plant the link here: http://www.forums.sketchucation.com/viewtopic.php?f=15&t=30933.
      Just info, maybe not answers.
      • KrisidiousK
        Krisidious
        SketchUp does allow co working on a file to an extent. if one file is open in two instances SU will tell the second program that it needs to be read-only and then it will warn that program when changes are saved in the first program. I'm not sure if this works across internet networks... as long as the two individuals knew what the other was working on... this could work.
        another way to co work on a file is to use components... ie if we both worked on a development of houses and I worked on one component and you worked on another and both of these were part of a larger file... that file could be updated and reflect the changes when the components were updated.
        By: Kristoff Rand
        • majidM
          majid
          tahnx mates/Kristoff 😄
          it seems the nested components is a good trick to solve the question 👍 very smart, and pure su solution.
          • majidM
            majid
            what about desctop sharing apps? is there anyone who could prepasre a full controll over my office network pcs?
            • GaieusG
              Hi Majid,
              There are several desktop sharing applications (some even allow you to model on others' computers). Note hoewver that none of them are perfect and as there are sometimes performance issues on a single computer with SU as well, there are definitely lags and delays refreshing the screen while doing this.
              So far I have tried two of them more in the depths: YuuGuu and CrossLoop. Both allows interaction on the other computer - as well as webconferencing (with a number of participants depending on your account but both has a free version, too).
              If you only want to share your screen and let others see what's going on, you can even use Skype. In may experience that is the fastest although with awful antialiasing but one can of course live with that.
              • simon le bonS
                simon le bon
                Hi guys,
                I'm very interested with co-working.
                But havn't yet tried no solution..
                Here is one more interesting link I had bookmarked relative to this question:
                sthgrau _ Multi-user collaboration
                *simon
                • majidM
                  majid
                  thanx again mates, will try 😄
                  • majidM
                    majid
                    has anyone tested this?:
                    http://www.filehippo.com/download_ultravnc/
                    http://www.uvnc.com/index.html
                    any feedback?
                    • GaieusG
                      Looks interesting, Majid. Have you tried it?
                      I have tried some other solutions yet I have never found a "perfect" one. Typical issues are.
                      • slow performance (even a 1-2 second delay can be confusing)
                      • lack of voice support
                      • awful antialiasing (well, one can live with that)
                      • lack of SU cursor display (this is a major problem however)
                      • security issues...
                        any feedback?
                        I've used UltraVNC to control my Mac Mini from my Windows computer. 👍
                        • tpstigersT
                          tpstigers
                          Wouldn't you only need to have a file that each computer can access? If so, Dropbox should do the trick (watch the video). As an added bonus, Dropbox is cross-platform.
                          “I have an existential map; it has 'you are here' written all over it”
                          • honoluludesktopH
                            honoluludesktop
                            Typically, networking applications can lock or unlock access to a single file (even across the internet) in order to assure its integrity. For the sketchup model's database to be accessed by more then one person, and maintain its data integrity, an "access to entities locking system" needs to be a part of the application. It would basically lock editing access to "the set of entities" that is currently being edited by one user from another. Sketchup doesn't come with these kinds of functions built in.
                            Just think of the kind of problem for users this might bring. User one is editing a component, thus locking all users from that component, and its sub-components until he is done. Of course, user two, can "make unique" then gain edit access to that unique component's entities, but not its sub-components. However desirable it may be, revisions to make unique components will not affect its parent component.
                            Free entities have other kinds of problems. if user one accesses (thus "locks assess to") a model's edge, at a minimum the connected edge, and faces will have to be "locked". If it isn't different users can edit adjoining entities causing the model to lose its integrity.
                            Placing a experienced, and inexperienced model builders on the same model could result in other kinds of problems. Still, this kind of interface is a must for very complicated projects.
                              dmatho
                              For what it's worth, number of years ago I saw at SIGGraph (possibly 2006, in Boston) a development from Caligary's trueSpace, a 3D modeler (http://www.caligari.com/), that allowed people to work synchronously and simultaneously yet remotely on models that lived in a shared 3D space, without recurring to any 'baton-passing'. This shared space was called truePlay and though it didn't have A/V/chat for communication, coordination and collaboration, I saw them using it with NetMeeting - http://www.letsgodigital.org/en/news/articles/story_7710.html.
                              Caligari was later bought by Microsoft and then... who knows but at the very least this proves a point, namely that co-working on a same file was and moreover should be today perfectly possible at least so, with the right tools and in an appropriate environment 😉
                              Cheers,
                              . Diego .
