    [Plugin] Axo + Iso View v1.2 20101117
    84 Posts 34 Posters 218.7k Views 34 Watching
      To save your shadow settings use a new Scene tab that retains the shadows as set in your Style.
      Make a copy of the Style with those shadows set and nothing else.
      Then you should be able to click the Shadows Scene tab and then nothing else changes except the shadows swap to your settings.
      You can export a Style and re-import it into another model OR have it set as one of the styles in your normal template, so all new models get that style as one of the available ones...Capture.PNG
        Gutz
        Maybe I'm doing something wrong , But it saves the "Shadow settings" ( time , date etc. ) and not the shadow itself
        So I'm only getting the direction of the shadow and not the actual shadow from the unscaled model
          You can only save 'the shadows' as an exported image, the 'shadow-settings' are remembered with the style...
            Gutz
            Sorry but I don't understand how to do it
            Can you make an example?
              Gutz
              Sorry for the bump
              But I still can't figure out how to get this to work with shadows correctly shown..
                @gutz said:
                Sorry for the bump
                I don't know how to get the shadows to look right either... that's up to you by adjusting location, north, date time etc.
                Once you have that save a scene with the only thing fixed as the shadows [as explained].
                Then later you can use that tab to reset shadows to those values again...
                  Gutz
                  I think we are not on the same page here , Lets make it a simple question :
                  Is it possible to show the model ( even just exporting an image it doesn't matter) with axo_scale , but with shadows shown correctly as if it wasn't scaled?
                  If so , can you please make an example?
                  Thanks in advance
                    If so, can you please make an example?
                    Thanks in advance
                    No.
                    Shadows come from the geometry, if you've scaled it the shadows won't be the same.
                    You could make the axo, export an image with shadows then.
                    Switch off shadows.
                    Now Scale the axo and re-export an image.
                    Use an image editor like Gimp to overlay the scaled image over the [now incorrect] shadows???
                    I fail to see how how the 'wrong shadows' will look right on the scaled skp's image.
                    Can you explain why you need to do this?
                    If you want shadows then shading the scaled version will look right... IF you set the location/date/time appropriately...
                      Gutz
                      Thanks for the answer , I'll deal with that
                      Its for school ( uni. ) assignment ( 1st year architecture ) , will be pretty hard to explain hehe.. πŸ˜„
                      But thanks again πŸ˜„
                        krit.ja
                        I need to produce axon45/45 drawings of the Casa Bianchi.
                        But it doesn't work. I typed axo4545 and it said
                        Error: #<NameError: undefined local variable or method `axo4545' for main:Object>
                        (eval)
                        I have both 7Pro and 8pro licensed on mac and pc
                        Please help..
                          (eval)
                          Please help..
                          The version shouldn't be an issue.
                          Have you definitely got a file called ' axo+iso.rb' in the ../Plugins/ folder ?
                          To see where your ../Plugins/ folder is copy paste this line into the Ruby Console + <enter>
                          Sketchup.find_support_file('Plugins')
                          That is the correct folder...
                          You should be able to type in the Ruby Console any of these commands...
                          axo3060 which sets the camera to a 30/60 axonometric view and zooms extents
                          axo6030 which sets the camera to a 60/30 axonometric view and zooms extents
                          axo4545 which sets the camera to a 45/45 axonometric view and zooms extents
                          iso3030 which sets the camera to a 30/60 isometric view and zooms extents
                          The current view changes to the axo/iso format desired and model-extents
                          are zoomed, now zoom in/out and pan BUT DON'T orbit - that would loose the
                          axo/iso-ness; then save that view to a Scene-tab.
                          If you have a 3d axo it needs 'distorting' so that it prints or exports as an image and looks correct.
                          The whole model needs scaling - particularly in the Z axis.
                          There are two tools to do this for you.
                          Use with care and remember to undo the temporary scaling to continue modeling.
                          After setting an axo view type in the Ruby Console + <enter>:
                          axo_scale
                          to scale the whole model, so it is distorted but looks correct.
                          axo_scale_restore
                            krit.ja
                            Thank you for your fast response!
                            /Users/ja/Library/Application Support/Google SketchUp 7/SketchUp/Plugins
                            But it still say the same when I type axo4545...
                            Anyway, I copy my model and paste it in your example.skp and use the saved scene
                            and then scale it blue/red/green as suggested in
                            @lersince1991 said:
                            A script would be great.
                            heres the final values, I've done them to a bit more of an accuracy, accurate to more than 1mm for models under 100,000m so yeh pretty solid figures.
                            I would scale all axis to get them accurate,
                            blue (z) axis scale value = 9.068228873
                            red axis scale value = 1.003053768
                            green axis scale value = 1.003054401
                            see what script you can do, typing that in every time gets boring lol
                            Luke
                            and it works!
                            the scale is super correct when I export .pdf to adjust lineweight in Illustrator.
                            So, Thank you very much TIG and Luke for including the example file and amazing info! πŸ‘ πŸ‘
                            • I Offline
                              ivreich
                              Hi TIG
                              I can't get the axo_scale command to work for me. My sketchup just bug splats after i hit enter. I'm using Sketchup pro 7.1....
                              any ideas what might be going wrong?
                              Cheers
                              Joel
                                Any error messages in the Ruby Console ?
                                It should work in all versions of Sketchup... πŸ˜•
                                How complex is your model ?
                                Are you in the model's active_entities rather than inside an 'edit' context ??
                                Puzzling............
                                • I Offline
                                  ivreich
                                  No error message. just instant bug splat.
                                  The model isn't complex, just a box.
                                  Joel
                                    Joel
                                    Can you post your problem SKP... πŸ˜•
                                      troyhome
                                      This is absolutely brilliant!! thanks for this!!
                                      IOviz.com
                                      SU Pro 2024 PC
                                        molex7
                                        Hello TIG,
                                        found the script late last year. It's really great - thanks! I've been using it occasionally, and it worked fine until last night - the axo_scale command suddenly went rogue. Everything works fine until i type that command, and then nothing else works - I can't change the axo views, I can't use axo_scale_restore. and if I try to restore the scale by using ctrl-z, sketchup will encounter a bug splat. As long as i don't use that scale command, switching between views work fine.
                                        So what I've been doing is save file -> get axo view -> export image -> let it crash -> reopen saved file to continue modeling, but as you can imagine it's not exactly efficient. I'm just wondering if you have any ideas why this happens or have encountered this problem before?
                                        I'm using Version 8.0.3117 if that makes any difference.
                                          Unknown problem πŸ˜•
                                          Is there anything weird about your model if you zoom extents etc ?
                                          Is it a long way off the origin ?
                                          Have you run Model > Statistics > Fix... etc ?
                                          πŸ˜’
                                            molex7
                                            To answer your questions...
                                            1. nothing weird 😎
                                            2. no...
                                            3. Yes...
                                            The only thing I can think of is that it's really huge... (its a model of a city)
                                            Anyway, some updates... in the exact same skp model, it sometimes work and it sometimes doesn't. I've tried to discover what is it that makes it work and what makes it not work, but so far it just seems completely random. There must be something though...
                                            anyway all it really does is to make me save more often which is a good thing i guess πŸ˜„
                                            • 2 / 5
