    [Plugin] Axo + Iso View v1.2 20101117
    84 Posts 34 Posters 228.1k Views 34 Watching
    • L
      Lersince1991
      Sure, thanks for the quick response.
      its the same on every system and model isn't it? no need to change the factor every time, just need to tweak it slightly πŸ˜„
      Heres some data for you based on a cube 3500x3500x3500mm
      (scale factor) = (45 degree line) & (90 degree line)
      9.476104 = 3489.3444 & 3657.4247
      9.5724 = 3489.3444 & 3675.9107
      10.002924 = 3489.3444 & 3860.7576
      Ideal is of course...
      (x) = 3500 & 3500
      Cheers,
      Luke.
      • L
        Lersince1991
        Got a final figure for you, pretty accurate but will update if I find the need to go more decimal places, for now I dont know how to see the exact figure from autocad.
        basically the cal is.
        3500mm (actual height) / 385.9629 (exported height from axo4545) = transform scale
        Working between autocad and sketchup pro 8
        should be the same for all though
        Luke.
        • L
          Lersince1991
          sorry forgot to add the actual z scale factor = 9.068229097
          this produces 3500.0001 in autocad πŸ˜„
          but the 45 degree angled lines aren't quite there with a dimension of 3489.3444mm instead of 3500. although they are at the correct angles (45 and 315 or... -45)
          Luke Riggall
          • L
            Lersince1991
            and...
            scale factor for the x and y sides (proportionate) is 1.003053754
            can anyone confirm both of these?
            if so could these be made into actions (scripts?) in order to prevent all this decimal typing lol.
            Good stuff πŸ˜„
            Luke
              So can we agree on a final vertical scaling factor, to export the perfect 2D Axo and I think about a script to do it...
              πŸ˜•
              • L
                Lersince1991
                A script would be great.
                heres the final values, I've done them to a bit more of an accuracy, accurate to more than 1mm for models under 100,000m so yeh pretty solid figures.
                I would scale all axis to get them accurate,
                blue (z) axis scale value = 9.068228873
                red axis scale value = 1.003053768
                green axis scale value = 1.003054401
                see what script you can do, typing that in every time gets boring lol
                Luke
                  Thanks... I'll cogitate over an automation...
                    Here's an update - v1.2 http://forums.sketchucation.com/viewtopic.php?p=252273#p252273
                    It now auto scales the whole model to distort it so that 3d axos will look right - using:
                    axo_scale
                    and undoes that scaling with:
                    axo_restore_scale
                    Use these tools with care!
                    • G
                      Gutz
                      Great plugin TIG!
                      A few suggestions/requests/bugs from a test I did with 2 cubes:
                      1.If you run axo4545 and then axo_scale - it cuts the top of the cubes. only if you run axo4545 again it works out for some reson...
                      2.Axo_restore_scale gives me the following error :
                      axo_restore_scale
                      Error: #<NameError: (eval):149: undefined local variable or method `axo_restore_scale' for main:Object>
                      (eval):149
                      3.Is it possible to show shadows correctly after you run axo_scale?
                      4.Is it possible to change the axis of alignment? the reason is because I need the shadows to be to the right , at normal usage I just orbit to bring the red axis down , but here I can't of course
                      for now I just do an horizontal flip on photoshop but just wondering if it's possible to setup easily
                      Thanks again for making such a great plugin
                        @gutz said:
                        Great plugin TIG!
                        1.If you run axo4545 and then axo_scale - it cuts the top of the cubes. only if you run axo4545 again it works out for some reason...
                        axo_restore_scale
                        (eval):149
                        1. Sound like the notorious 'clipping issue' is your model very big, very small or far away from the origin ?
                        2. 'axo_restore_scale' should be axo_scale_restore - my typo in the help section 😳
                        3. The shadows will become distorted by the vertical scaling factor - if you want '45 degree' shadows I suppose we just need to find a long/lat/date/time where the 'scale' objects cast shadows that look as desired ? Set it as a Style that only retains those changes... If you play around with the shadow settings and advise what you'd like to do I can see if it's scriptable...
                        4. I can't see how to have other axes [easily] - rotating the exported image in PS or Gimp is probably the easiest solution...
                        • G
                          Gutz
                          @tig said:
                          @gutz said:
                          Great plugin TIG!
                          axo_restore_scale
                          (eval):149
                          Wow that was fast respone πŸ˜„
                          1.Ok , It's happening only on rare occasions with v8 ( last time I tried it with v6 ) so it's really minor
                          2.Working great!
                          3.How do I set it as a Style? ( I'm new with sketchup so sorry if it's a dumb question , but I couldn't find it also in the help section.. )
                          4.Will do , Thanks πŸ˜„
                          I've attached the example i'm working with
                          The image is flipped horizontally and thats what i need to accomplish eventually ( of course with the z factor correctly )
                          Thanks again for all the help
                          Gutz
                          Axo Test.skp
                            To save your shadow settings use a new Scene tab that retains the shadows as set in your Style.
                            Make a copy of the Style with those shadows set and nothing else.
                            Then you should be able to click the Shadows Scene tab and then nothing else changes except the shadows swap to your settings.
                            You can export a Style and re-import it into another model OR have it set as one of the styles in your normal template, so all new models get that style as one of the available ones...Capture.PNG
                            • G
                              Gutz
                              Maybe I'm doing something wrong , But it saves the "Shadow settings" ( time , date etc. ) and not the shadow itself
                              So I'm only getting the direction of the shadow and not the actual shadow from the unscaled model
                                You can only save 'the shadows' as an exported image, the 'shadow-settings' are remembered with the style...
                                • G
                                  Gutz
                                  Sorry but I don't understand how to do it
                                  Can you make an example?
                                  • G
                                    Gutz
                                    Sorry for the bump
                                    But I still can't figure out how to get this to work with shadows correctly shown..
                                      @gutz said:
                                      Sorry for the bump
                                      I don't know how to get the shadows to look right either... that's up to you by adjusting location, north, date time etc.
                                      Once you have that save a scene with the only thing fixed as the shadows [as explained].
                                      Then later you can use that tab to reset shadows to those values again...
                                      • G
                                        Gutz
                                        I think we are not on the same page here , Lets make it a simple question :
                                        Is it possible to show the model ( even just exporting an image it doesn't matter) with axo_scale , but with shadows shown correctly as if it wasn't scaled?
                                        If so , can you please make an example?
                                        Thanks in advance
                                          If so, can you please make an example?
                                          Thanks in advance
                                          No.
                                          Shadows come from the geometry, if you've scaled it the shadows won't be the same.
                                          You could make the axo, export an image with shadows then.
                                          Switch off shadows.
                                          Now Scale the axo and re-export an image.
                                          Use an image editor like Gimp to overlay the scaled image over the [now incorrect] shadows???
                                          I fail to see how how the 'wrong shadows' will look right on the scaled skp's image.
                                          Can you explain why you need to do this?
                                          If you want shadows then shading the scaled version will look right... IF you set the location/date/time appropriately...
                                          • G
                                            Gutz
                                            Thanks for the answer , I'll deal with that
                                            Its for school ( uni. ) assignment ( 1st year architecture ) , will be pretty hard to explain hehe.. πŸ˜„
                                            But thanks again πŸ˜„
                                            • 2 / 5
