    Turn off scene thumbnail generation
    7 Posts 6 Posters 2.5k Views 6 Watching
      danbig
      Hi -
      When I'm renaming scenes, it tells me that I can disable thumbnail generation for the model. But when I check the box to disable thumbnails, it doesn't seem to stop future thumbnails from generating, or updating (and I still get the same message, giving me the option to disable). I've disabled many times over in the same model, but no luck.
        Jim
        This is getting quite annoying when I do not want to generate Scene Tumbnails but SketchUp won't remember my preferences after restarting.
        I didn't see an obvious way to disable via the API, hopefully I just overlooked it?
        • spenceS
          spence
          Under the Scenes window, look under menu and uncheck the "Use Scene Thumbnails"! Hope this helps!
          I tried it and I had to create a scene before I could uncheck "Use Scene Thumbnail", then it never created another thumbnail after that.
          Spence
            Jim
            Ugh, it's getting turned back on whenever I add a scene via Ruby.
            • G
              glro
              @danbig said:
              Hi -
              i have the same problem, and i don't see anything about the ruby code that would create a page with thumbnails disabled
              any idea?
              • pbacotP
                THIS STUPID "FEATURE"!
                  driven
                  see that on mac, as well...
                  turn them off
                  add a page
                  seems to work
                  until the page 'refresh'
