    Snowy Pinecone - Christmas Challenge Tut
    23 Posts 13 Posters 6.2k Views 13 Watching
    • boofredlayB Offline
      boofredlay
      Hey all.
      As promised here is a tutorial on how to make the Snowy Pinecone I created
      for the Christmas Decorations 2010 modeling challenge.
      Let me know what you think.
      Edit: I reworked the tutorial into one video with tool tips and added it to Youtube.
      Have fun watching the Operator Error at 2:34 - 2:50
      πŸ‘Š
      [flash=853,505:1pd8blxd]http://www.youtube.com/v/BbcycONsjNs&fs=1[/flash:1pd8blxd]
      http://forums.sketchucation.com/download/file.php?id=60022&t=1
        Thnks Eric πŸ‘
        Excellent approach
        • daleD Offline
          dale
          Thanks for coming thru with this. It is a really great little tut.
          • david_hD Offline
            david_h
            very beautiful and elegant model. Nicely done.
            I hate you. . . . πŸ’š
            Jus Kiddin' !!!!
            • BoxB Offline
              Very nice to watch, just one small question.
              You appeared to turn the surfaces inside out, the silver gray colour as your working surface rather than the white, I have always thought the white side was the outside.
              Am I wrong and it doesn't matter, or is it only relevant when rendering or something else?
                boofredlay
                You are right on both accounts. The blue in my model is the back side. It does not matter which color you make the front or back, that is user preference. However if you are going to use a rendering software it is good practice to always have the front face oriented correctly, facing outward.
                In this example however I was actually showing how each skin was a different group. Yes I should have just reversed the bottom left one.
                Now for the third step, arranging the cone scales, you will notice the faces are correct. I actually exploded all of the skins into one component.
                • BoxB Offline
                  Thanks Eric,
                  I still haven't done any rendering, but it's good to know I am thinking the right way.
                  • david_hD Offline
                    david_h
                    @box said:
                    I still haven't done any rendering. . .
                    Good thing. .. .You just don't wanna go there. Rendering Software is like the mob. . .Once you're in .. . You can never get out. πŸ’š
                      arklandesign
                      Thank you so much for taking the time to explain how you did this.... it was a real eye opener for me. I tried doing this myself...and just have to laugh at my attempts now having seen your way of doing this...Amazing and thanks again.
                        Does it possible to have movies in reduction? (or a trick)
                        Original is too big for my screen and seems there is not possible to reduce it 😒
                          boofredlay
                          Not unless I do it again with a smaller screen grab window, sorry. 😳
                          • Jean-FrancoJ Offline
                            Jean-Franco
                            Very nice tutorial Eric, thanks !
                            Jean-Franco
                            • N Offline
                              nomeradona
                              bravo...
                                sorry.
                                No problem, i will use scroll bars πŸ˜‰
                                • mitcorbM Offline
                                  mitcorb
                                  In WindowsXP and Firefox, usually you can Ctrl+Scroll, but this does not affect the clip window, as you have already discovered.
                                    pankaj_tamore
                                    By looking at your snowy pinecones only one question making rounds in mind how you have achieved this incredible shape? hats off!
                                      boofredlay
                                      Thanks Pankaj.
                                      Unfortunately the videos I made were disabled because it was a free Jing account and the bandwidth has been used up.
                                      I will have to remake the tutorial at some time as those are now lost.
                                      I will tell you however that I used the Curviloft plugin to create the shape then copied and rotated it many times.
                                      • dereiD Offline
                                        derei
                                        Thanks Pankaj.
                                        can you upload on youtube? πŸ˜„ It seems a simple process, but I'd like to see it in action; I'm sure I'll learn something.
                                        Thank you.
                                          boofredlay
                                          I will when I get the chance to remake the tutorial. The Jing content was disabled when my bandwidth ran out and I don't even have access to it. 😒
                                          • dereiD Offline
                                            derei
                                            (kinda off-topic) good to know. I was tempted to use Jing some time ago (i like the way it looks). Now I'll know to listen to my instinct all the time (the instinct told me not to) πŸ˜‰
                                            (now back) Thank you Boofredlay, I appreciate your (soon to be) effort ! πŸ‘
