    [code] Win32 Moving/Showing/Hiding Toolbars and Dialogs
    91 Posts 8 Posters 23.7k Views 8 Watching
      driven
      http://pfiddlesoft.com/uibrowser/
      it scans all UI elements in a targeted app, in this case SU, writes reports and allows some level of modification, unfortunately my trials has runout,
      so I haven't been able fully explore it,
      however the information can be used to find the real differences...
      • Dan RathbunD
        Dan Rathbun
        @thomthom said:
        I've been searching for ways to manipulate windows under OSX like one can do under Windows with the Win32 API - but I never find anything.
        Just wondering...
        ref: [window.opener()](http://msdn.microsoft.com/en-us/library/ms534309(v)
        When a WebDialog has the focus... does this JS in the dialog:
        %(#8000BF)[window.opener.focus()]
        cause the Sketchup window to receive the focus ...
        (1) on PC/IE ??
        (2) on Mac/Safari ??
        I'm not here much anymore.
          Jim
          .blur() ing a WebDialog seems to focus the main SU window on Mac.
          <body onMouseOut ="window.blur()">
          On Windows, it sends the main SU window and everything else to the back.
          • Dan RathbunD
            Dan Rathbun
            How the Paint.NET programmer enabled Mouse ClickThrough for Paint.NET's various ToolWindows.
            Page not found
            (blogs.msdn.com)
            • Dan RathbunD
              Dan Rathbun
              (1) on PC/IE 7 : We get an error popup that states:
              "window.opener is null or not an object."
              So apparently if the owner is not a browser window (ie: an application,) the function returns null.
              Bummer.
                http://blogs.msdn.com/b/rickbrew/archive/2006/01/09/511003.aspx
                Fortunately webdialogs under windows are click-through. But OSX remains a problem. I'm not happy with having the user remembering to press Ctrl every time they want to interact with the window.
                • Dan RathbunD
                  Dan Rathbun
                  @John (driven) & ThomThom
                  Try the events in the code below for Safari toolbar WebDialogs.
                  • if the ctrlKey event doesn't work for Safari, perhaps try setting the altKey event to true onMouseIn and false onMouseOut.
                  You may need a onMouseOver="window.focus();" attribute within the body tag, in order for document.activeElement (see body tag's onClick event,) to return the control that is set active by each control's onmouseover event. If you DO, then you'll definately need the window.blur() statement within the body tag's onMouseOut event (otherwise you may not.)
                  <html>
                  <body onMouseIn="window.event.ctrlKey=true";
                   onMouseOut="window.event.ctrlKey=false; window.blur();"
                   onClick="document.activeElement.click();">
                  <img class="imgbutton" onmouseover="this.setActive" src="SketchupIcon.png"
                   onClick="callSomeJsFunctionToRubyCallback('params');">
                  ... the rest of your webpage ...
                  The idea step by step:
                  1. Sketchup Application Window has focus
                  2. mouse moves into toolbar webdialog setting window.event.ctrlKey=true (and possibly dialog focus via body onMouseOver.
                  3. as the mouse moves over controls, each control has a onmouseover="this.setActive" event.
                  4. when a click occurs anywhere on the page, the body tag's onClick event uses document.activeElement.click to cause active control's onClick event to fire.
                  5. when the mouse moves out of the toolbar dialog, the body tag's onMouseOut event resets the key event to false, and optionally calls window.blur
                  The <IMG> tags are given a class "imgbutton" so they can have styles set for borderstyle, etc.
                    @dan rathbun said:
                    1. mouse moves into toolbar webdialog setting window.event.ctrlKey=true (and possibly dialog focus via body onMouseOver.
                    Will the mouse event trigger when the webdialog haven't got focus?
                      How odd...
                      • Dan RathbunD
                        Dan Rathbun
                        it DOES on Win32 w/ IE 7
                          driven
                          hi Dan, Thom, Jim, all
                          I've been trying all sorts of things to 'avoid' giving the WebDialog 'focus' while still having it send actions.
                          this is what happens with SU native NSPanels (used for SU toolbars) and also for some of the NSWindows used for different preferences and the NS(WebView)Window used by Instructor, but not the NS(WebView)Window used by WebDialog.
                          holding down the "cmd"(apple) key, invokes this behavior (no focus, but active) on any window/panel inside
                          so far the best/simplest way I've come up with is add to an 'aid memoir', using background colours and text..... but I'll keep trying
                          for now??
                          • Dan RathbunD
                            Dan Rathbun
                            How odd...
                            yea I tried with a modified test dialog John sent me (I added buttons and some key displays.)
                            SelectionInfo.zip
                            • Dan RathbunD
                              Dan Rathbun
                              Hey John ... you talk about NS windows made me think of the 9th arg to WebDialog.new
                              :mac_only_use_nswindow
                              You might need to use a settings Hash to use it. If you do, the key for the 3rd arg is :preferences_key not 'key'
                              You should also use Symbol keys not String keys, as the Hash argument is cranky.
                                Yea but windows doesn't have the click-through issue. I was thinking since click events would not register under OSX until the window had gotten focus, then maybe mouse events would not trigger either.
                                ...I really need to find that box with my Mac... ...ugh, the hurdles of moving...
                                  driven
                                  an update,
                                  holding the cmb key down is great for tool swaps and input button clicks, but locking it down means you can't use numerical input boxes...
                                  I didn't realise that cmd 1,2,3,4,5,6,7,8,9,0 are all shortcut keys, so holding down the key manually is the best option....
                                  • Dan RathbunD
                                    Dan Rathbun
                                    @thomthom said:
                                    I've been searching for ways to manipulate windows under OSX like one can do under Windows with the Win32 API - but I never find anything. 😞
                                    RubyCocoa
                                    it's included with OSX since v10.5 “Leopard” ??
                                    EDIT: Here's the RubyCocoa SourceForge page.
                                    I've seen Ruby scripts that had: require 'Cocoa' or similar at the top.
                                    There is a potential pitfall looming for Sketchup cross-platform scripting, in that Apple intends to replace MRI Ruby, with MacRuby. It would not be bad if we had all the same UI classes in a "WinRuby" that MacRuby has.
                                      Ok - something to look into. I hope that allows you to modify existing windows, not sure create your own. (Though creating your own would be cool too.)
                                        mhm - some wrapper to bridge it all.
                                        • Dan RathbunD
                                          Dan Rathbun
                                          Yes the 'wrappings' would need to follow (as closely as possible,) those defined in HotCocoa for MacRuby.
                                          Note that in the example on the HotCocoa introduction page, they are showing the use of a window() constructor method. What they don't actually show is that farther up at the beginning of the Ruby module block, is that there must be an include HotCocoa (or some other mixin module,) that brings that window() method into the current namespace. I usually don't like to do this, instead prefering to call the method using fullnamespace qualification. Less chance then of an accidental override of methods that are imported into your namespace. In this example, I would probably wish to have a window() method in my namespace that returns the instance handle to the window object (@win,) so I'd think most times it's not really that convenient to include entire complex libraries, into a custom namespace.
                                          • P
                                            pcarret
                                            Everything is fine under MS-Windows, but :
                                            Is it possible to do hide minimize, maximize andclose buttonon Mac OS ?
                                            I found NSMiniaturizableWindowMaskbut I don't know how to access system API under Mac OS
                                            Remark under windows : WS_MINIMIZEBOX and WS_MAXIMIZEBOX can't work separately
                                            simplified working code is (must have hwnd handle, constant and win32 method declaration) :
                                            style = GetWindowLong.call(hwnd, GWL_STYLE)
                                            style = style & ~WS_MINIMIZEBOX
                                            style = style & ~WS_MAXIMIZEBOX
                                            result = SetWindowLong.call(hwnd, GWL_STYLE,  style)
                                            Thanks for any answer.
                                            Philippe
                                            • 4 / 5
