    [code] Win32 Moving/Showing/Hiding Toolbars and Dialogs
    91 Posts 8 Posters 26.8k Views 8 Watching
      @driven said:
      [attachment=0:4644llpu]<!-- ia0 -->reports_Mac_SU_UI-Elements.zip<!-- ia0 -->[/attachment:4644llpu]
      I get errors when I try to unzip that file. Both Windows and WinRar reports errors.
        driven
        @thomthom said:
        1 Change the window frame style to toolwindow]
        you can see in the reports that there's more than one version of 'toolwindow'
        @thomthom said:
        2 Allow the user to only click once to activate the UI elements in the webdialog (as oppose to click to give focus, click again to activate UI element)
        some of the native toolwindows require this, sometimes??? model info for example
        @thomthom said:
        3 Be able to activate by click the UI elements in the webdialog without taking focus from the SU window.
        Can be achieved on all by holding down cmd key, so I'm looking for adding an applescript to do that on hover/mouseover
        try this zip...stuffit or I'll pm a link
          I still get errors.
            I think the files extracted after all, despite the errors.
              driven
              so you have them? do they make sense...
              I did some more and now I'm trying to work out if I can make changes...
              I've got apple script launching things from inside SU so now I need to see if it can modify window element attributes or something...
                I'm not entirely sure I know what I'm looking at. Where does this data come from?
                  driven
                  http://pfiddlesoft.com/uibrowser/
                  it scans all UI elements in a targeted app, in this case SU, writes reports and allows some level of modification, unfortunately my trials has runout,
                  so I haven't been able fully explore it,
                  however the information can be used to find the real differences...
                  • Dan RathbunD
                    Dan Rathbun
                    @thomthom said:
                    I've been searching for ways to manipulate windows under OSX like one can do under Windows with the Win32 API - but I never find anything.
                    Just wondering...
                    ref: [window.opener()](http://msdn.microsoft.com/en-us/library/ms534309(v)
                    When a WebDialog has the focus... does this JS in the dialog:
                    %(#8000BF)[window.opener.focus()]
                    cause the Sketchup window to receive the focus ...
                    (1) on PC/IE ??
                    (2) on Mac/Safari ??
                    I'm not here much anymore.
                      Jim
                      .blur() ing a WebDialog seems to focus the main SU window on Mac.
                      <body onMouseOut ="window.blur()">
                      On Windows, it sends the main SU window and everything else to the back.
                      • Dan RathbunD
                        Dan Rathbun
                        How the Paint.NET programmer enabled Mouse ClickThrough for Paint.NET's various ToolWindows.
                        Page not found
                        (blogs.msdn.com)
                        • Dan RathbunD
                          Dan Rathbun
                          (1) on PC/IE 7 : We get an error popup that states:
                          "window.opener is null or not an object."
                          So apparently if the owner is not a browser window (ie: an application,) the function returns null.
                          Bummer.
                            http://blogs.msdn.com/b/rickbrew/archive/2006/01/09/511003.aspx
                            Fortunately webdialogs under windows are click-through. But OSX remains a problem. I'm not happy with having the user remembering to press Ctrl every time they want to interact with the window.
                            • Dan RathbunD
                              Dan Rathbun
                              @John (driven) & ThomThom
                              Try the events in the code below for Safari toolbar WebDialogs.
                              • if the ctrlKey event doesn't work for Safari, perhaps try setting the altKey event to true onMouseIn and false onMouseOut.
                              You may need a onMouseOver="window.focus();" attribute within the body tag, in order for document.activeElement (see body tag's onClick event,) to return the control that is set active by each control's onmouseover event. If you DO, then you'll definately need the window.blur() statement within the body tag's onMouseOut event (otherwise you may not.)
                              <html>
                              <body onMouseIn="window.event.ctrlKey=true";
                               onMouseOut="window.event.ctrlKey=false; window.blur();"
                               onClick="document.activeElement.click();">
                              <img class="imgbutton" onmouseover="this.setActive" src="SketchupIcon.png"
                               onClick="callSomeJsFunctionToRubyCallback('params');">
                              ... the rest of your webpage ...
                              The idea step by step:
                              1. Sketchup Application Window has focus
                              2. mouse moves into toolbar webdialog setting window.event.ctrlKey=true (and possibly dialog focus via body onMouseOver.
                              3. as the mouse moves over controls, each control has a onmouseover="this.setActive" event.
                              4. when a click occurs anywhere on the page, the body tag's onClick event uses document.activeElement.click to cause active control's onClick event to fire.
                              5. when the mouse moves out of the toolbar dialog, the body tag's onMouseOut event resets the key event to false, and optionally calls window.blur
                              The <IMG> tags are given a class "imgbutton" so they can have styles set for borderstyle, etc.
                                @dan rathbun said:
                                1. mouse moves into toolbar webdialog setting window.event.ctrlKey=true (and possibly dialog focus via body onMouseOver.
                                Will the mouse event trigger when the webdialog haven't got focus?
                                  How odd...
                                  • Dan RathbunD
                                    Dan Rathbun
                                    it DOES on Win32 w/ IE 7
                                      driven
                                      hi Dan, Thom, Jim, all
                                      I've been trying all sorts of things to 'avoid' giving the WebDialog 'focus' while still having it send actions.
                                      this is what happens with SU native NSPanels (used for SU toolbars) and also for some of the NSWindows used for different preferences and the NS(WebView)Window used by Instructor, but not the NS(WebView)Window used by WebDialog.
                                      holding down the "cmd"(apple) key, invokes this behavior (no focus, but active) on any window/panel inside
                                      so far the best/simplest way I've come up with is add to an 'aid memoir', using background colours and text..... but I'll keep trying
                                      for now??
                                      • Dan RathbunD
                                        Dan Rathbun
                                        How odd...
                                        yea I tried with a modified test dialog John sent me (I added buttons and some key displays.)
                                        SelectionInfo.zip
                                        • Dan RathbunD
                                          Dan Rathbun
                                          Hey John ... you talk about NS windows made me think of the 9th arg to WebDialog.new
                                          :mac_only_use_nswindow
                                          You might need to use a settings Hash to use it. If you do, the key for the 3rd arg is :preferences_key not 'key'
                                          You should also use Symbol keys not String keys, as the Hash argument is cranky.
                                            Yea but windows doesn't have the click-through issue. I was thinking since click events would not register under OSX until the window had gotten focus, then maybe mouse events would not trigger either.
                                            ...I really need to find that box with my Mac... ...ugh, the hurdles of moving...
                                            • 4 / 5
