    Snap points when moving components
    4 Posts 3 Posters 704 Views 3 Watching
    • Z Offline
      Zacchia
      When i move a group then sometimes i wish to move it exactly from the middle, like for example a line from the middle. Is there a way to have such a snap point in a group?
      • mitcorbM Offline
        mitcorb
        Activate Move, hover over the approximate middle of the grouped selection, and you should see a tooltip popup saying "midpoint in group". The only difference is that it will not be the aqua colored inference dot that you would see in ungrouped geometry.
        If you meant something having to do with the Centroid, or Center of Gravity of a volumetric selection, there is are plugins involving this as a possible snap point. I think TIG did something on this.
        • TIGT Online
          There are several tools available to add a cpoint at the geometric center of an instance's bounding-box, or a faces 'centroid' or [like mine] an instance's center-of-gravity...
          • Z Offline
            Zacchia
            Thanks for fast answers like allways!! I study this!
