    [plugin] realSection v0.6 Béta (Updated 9/8/2014)
    87 Posts 37 Posters 70.3k Views 37 Watching
      GWD
      @ladcwei said:
      I really like this plugs,however,it can't work at 7or8,waiting for its rebirth... 🎉
      please give me some feedback why it's not working? It should work a SketchUp 8 english.
      • E Offline
        errror404
        @errror404 said:
        hello,
        I'm trying to test this great plugin, but I'm having some dificulties:
        1- I created a group (a simple solid object)
        2- Then I created a texture that started with "_"
        3- I assigned the material to the object using "Define realSection material"
        4- I created a section plane
        5- pressed "Make realSection" and gave it a name
        but nothing happens... and no new layers are created?!
        I'm using SketchUp 8 (free) on a windows machine (XP)
        Can you send me the model?
        It was just a box...
        It didn't work on your example model either (if I tried to make a new section)
        I would try later at my home computer (SketchUp Pro)
        Now, after looking at the video I did notice something diferent... when I make a section my model shows up hallow inside (before and after I pressed "Make realSection" )
        http://img843.imageshack.us/img843/2551/sectionf.jpg
        do I need to change some type of option in sketchup?
        thanks!
          Any chance you could actually tell us what you are doing in the video. It's difficult to read the menu items and so on due to the compression of the video.
          I'm trying to follow your PDF instructions. When I choose Make realSection, I can give the section a name but there's no new layer created as stated in the instructions. I think there are enough folks having difficulty getting this to work that there must be a defect that needs to be fixed.
            GWD
            what's in the video:
            make a solid
            right click at select 'Define realSection material'
            cancel the define realSection material
            create a new SU material named '_newmaterial'
            right click at select 'define realSection material'
            select the new created material 'newmaterial'
            define a sectionplane
            right click selectionplane and select 'Make realSection'
            realSection is created
            select solid again and define an other material
            show sectionplanes
            select sectionplane
            right click and select 'Update realSection'
            realSection is updated
            edit solid
            show sectionplanes
            select sectionplane
              GWD
              If I know what's going wrong then I can fix it. Can you open your ruby console when you are trying to run realSection and give me the errors that show up.
              regards,
              Guy
              • E Offline
                errror404
                regards,
                Guy
                748115
                748123
                Error; #<NoMethodError; undefined method `hide_Outliner_MI' for RealSections;Module>
                (eval);614;in `updaterealSection'
                (eval);774
                  At Define Material
                  748115
                  748123
                  At Make realSection
                  (eval);1722;in `updaterealSection'
                  (eval);1882
                  (eval);1722;in `call'
                  (eval);1722
                  At Show realSection
                  748115
                  748123
                  At Update realSection
                  748115
                  748123
                  (eval);1894
                  (eval);1722
                  FWIW, the Outliner wasn't open to begin with.
                    GWD
                    @dave r said:
                    At Define Material
                    748115
                    > 748123
                    At Make realSection
                    > (eval);1882
                    > (eval);1722
                    At Show realSection
                    748115
                    > 748123
                    748115
                    > 748123
                    > (eval);1894
                    > (eval);1722
                    Thanks I try to fix it asap
                      GWD
                      There was a small problem with version 0.3. This is now solved in realSection v0.4. I hope you will still enjoy realSection!
                      I tested it on SU7 en SU8 and it should work on both version without a problem.
                        Jim
                        Is the problem because the plugin relies on Windows-specific libraries (Win32API.so) which are incompatible with Mac OS?
                          GWD
                          No plugin check if it's a PC or a MAC. But the problem should be fixed.
                            That seems to work now although, curiously, the faces don't align accurately with the section cut. See the attached model and zoom in close to the corners. And it seems the materials must already be defined in the model before starting to create the realSections. Is that right? I added the material called _Blue after creating the realSections. The name shows up in the list for defining materials but after selecting it for one group and updating the realSections the face disappeared. When I set it back to the brownish color, the face was recreated.
                            Section.skp
                              GWD
                              That the section faces don't align is normal, because i place the faces a little before and a little behind the sectionplane. But because you work in other units the gap is to big. I try to solve the unit problem asap.
                                GWD
                                Problem solved in v0.5
                                There will always be a very little displacement because it's impossible to put a face on the sectionplane without display problems.
                                  Thanks. I'll give it a try.
                                  I wonder why it isn't possible for your script to put the face on the section plane in exactly the right spot. TIG's SectionCutFace seems to do it exactly right every time.
                                    GWD
                                    Dave, now it's in the right spot like TIG's SectionCutFace. But also TIG plugin is moved a little bit.
                                    • E Offline
                                      errror404
                                      I would like to report that the issues that I was having early are now gone (since the new update).
                                      • ladcweiL Offline
                                        ladcwei
                                        Thinks for GWydouw's hardwork,this plugin works now.
                                        But I think there is a problem remaining :sometimes when I zoom out ,the realsection layer would disppear like this:
                                        I guess the reason of this should be the realsection layer and the section plan at the same plan,then when I zoom out ,the section plan works......
                                        • ladcweiL Offline
                                          ladcwei
                                          And I find this version only works for groups in Su7,if the section plan goes through the components,there is no result......
                                            schnydix
                                            hi i tried aut your plugin real section
                                            if i open the test file it works fine
                                            but my own solids would never shown a real section i Played around with 4 hours
                                            I make a solid right click on it and i have NO Dropdown (Arrow) menu. What make i wrong?
                                            Win xp su8
                                            can i make my own Hatching and rename it later in a version?
                                            And Thank you for the great idea and the work
                                            • 2 / 5
