    [plugin] realSection v0.6 Béta (Updated 9/8/2014)
    87 Posts 37 Posters 75.4k Views 37 Watching
    • kenK
      ken
      Well, thomthom, that was it. The compatibility folder had the files stored there. When I removed these files, the plugin is gone. And of course the compatibility folder does not show up in the regular Windows Explorer view.
      It was my understanding that the "compatibility" of Windows 7 was for program installation. It never dream on me it would hide extracted zip files.
      However, that explains to me why extracting the files did not seem to work. I couldn't find the files after the first extraction, but the during the second extraction, the process ask if it could write over the files. To get the files showing up in the plugin folder, I had to copy the files. So Windows 7 was giving me a hint, but I just didn't understand what was happening.
      Hope, this helps other.
      thomthom, again thank you.
      Ken
        Good to hear it worked out. 👍
        • U
          unclex
          @unclex said:
          Can't Choose Materials...
          [attachment=0:ysvaku3o]<!-- ia0 -->webqq_app.jpg<!-- ia0 -->[/attachment:ysvaku3o]
          Did you use the demo file?
          The name of the materials that you will use for the section need to start with '_' like '_concrete'
          The materials are the standard SketchUp materials that are active in the model.
          I see you work with SU 7, at this moment realSection won't work with v7. I hope I can fix the problem with SU 7 very soon.
          thank u replied
          i use SU8Pro
          i can see the demo's section, but can't use it
          and ur plugin can't work with thearender4su plugin
          • G
            GWD
            @unclex said:
            [attachment=0:gu9cegbn]<!-- ia0 -->webqq_app.jpg<!-- ia0 -->[/attachment:gu9cegbn]
            thank u replied
            i use SU8Pro
            What do you mean with 'can't use it'?
            What do you mean with 'can't work with thearender4su plugin'?
            • U
              unclex
              @unclex said:
              [attachment=0:26db8ugb]<!-- ia0 -->webqq_app.jpg<!-- ia0 -->[/attachment:26db8ugb]
              thank u replied
              i use SU8Pro
              Perhaps thearender4su plugin is not the reason
              sometimes " Define real.... ", it's grey, "can't work", i mean it
              sometimes " define real..." is grey, sometimes isn't, it's joking me?
              but i don't know, how to make section plug worked , i mean show the materials on the section.
              • G
                GWD
                Can you send me the model and some screenshots of the problem?
                • HumpmetwiceH
                  Humpmetwice
                  I can't seem to get it to work right myself with the materials. Do you have to type in the name of the material that you want to use? A demo video would help to enjoy this plugin a whole lot more since I have been needing such a plugin for a while now! Thanks anyway, I guess I will figure it out one day?
                  • E
                    errror404
                    hello,
                    I'm trying to test this great plugin, but I'm having some dificulties:
                    1- I created a group (a simple solid object)
                    2- Then I created a texture that started with "_"
                    3- I assigned the material to the object using "Define realSection material"
                    4- I created a section plane
                    5- pressed "Make realSection" and gave it a name
                    but nothing happens... and no new layers are created?!
                    I'm using SketchUp 8 (free) on a windows machine (XP)
                    • G
                      GWD
                      @errror404 said:
                      hello,
                      Can you send me the model?
                      • G
                        GWD
                        I made a little movie to show how realSection works:
                        • ladcweiL
                          ladcwei
                          I really like this plugs,however,it can't work at 7or8,waiting for its rebirth... 🎉
                          • G
                            GWD
                            please give me some feedback why it's not working? It should work a SketchUp 8 english.
                            • E
                              errror404
                              @errror404 said:
                              hello,
                              It was just a box...
                              It didn't work on your example model either (if I tried to make a new section)
                              I would try later at my home computer (SketchUp Pro)
                              Now, after looking at the video I did notice something diferent... when I make a section my model shows up hallow inside (before and after I pressed "Make realSection" )
                              http://img843.imageshack.us/img843/2551/sectionf.jpg
                              do I need to change some type of option in sketchup?
                              thanks!
                                Any chance you could actually tell us what you are doing in the video. It's difficult to read the menu items and so on due to the compression of the video.
                                I'm trying to follow your PDF instructions. When I choose Make realSection, I can give the section a name but there's no new layer created as stated in the instructions. I think there are enough folks having difficulty getting this to work that there must be a defect that needs to be fixed.
                                • G
                                  GWD
                                  what's in the video:
                                  make a solid
                                  right click at select 'Define realSection material'
                                  cancel the define realSection material
                                  create a new SU material named '_newmaterial'
                                  right click at select 'define realSection material'
                                  select the new created material 'newmaterial'
                                  define a sectionplane
                                  right click selectionplane and select 'Make realSection'
                                  realSection is created
                                  select solid again and define an other material
                                  show sectionplanes
                                  select sectionplane
                                  right click and select 'Update realSection'
                                  realSection is updated
                                  edit solid
                                  show sectionplanes
                                  select sectionplane
                                  • G
                                    GWD
                                    If I know what's going wrong then I can fix it. Can you open your ruby console when you are trying to run realSection and give me the errors that show up.
                                    regards,
                                    Guy
                                    • E
                                      errror404
                                      regards,
                                      Guy
                                      748115
                                      748123
                                      Error; #<NoMethodError; undefined method `hide_Outliner_MI' for RealSections;Module>
                                      (eval);614;in `updaterealSection'
                                      (eval);774
                                        At Define Material
                                        748115
                                        748123
                                        At Make realSection
                                        (eval);1722;in `updaterealSection'
                                        (eval);1882
                                        (eval);1722;in `call'
                                        (eval);1722
                                        At Show realSection
                                        748115
                                        748123
                                        At Update realSection
                                        748115
                                        748123
                                        (eval);1894
                                        (eval);1722
                                        FWIW, the Outliner wasn't open to begin with.
                                        • G
                                          GWD
                                          @dave r said:
                                          At Define Material
                                          748115
                                          > 748123
                                          At Make realSection
                                          > (eval);1882
                                          > (eval);1722
                                          At Show realSection
                                          748115
                                          > 748123
                                          748115
                                          > 748123
                                          > (eval);1894
                                          > (eval);1722
                                          Thanks I try to fix it asap
                                          • G
                                            GWD
                                            There was a small problem with version 0.3. This is now solved in realSection v0.4. I hope you will still enjoy realSection!
                                            I tested it on SU7 en SU8 and it should work on both version without a problem.
                                            • 2 / 5
