    [plugin] realSection v0.6 Béta (Updated 9/8/2014)
    87 Posts 37 Posters 74.0k Views 37 Watching
    • U Offline
      unclex
      @unclex said:
      Can't Choose Materials...
      [attachment=0:ysvaku3o]<!-- ia0 -->webqq_app.jpg<!-- ia0 -->[/attachment:ysvaku3o]
      Did you use the demo file?
      The name of the materials that you will use for the section need to start with '_' like '_concrete'
      The materials are the standard SketchUp materials that are active in the model.
      I see you work with SU 7, at this moment realSection won't work with v7. I hope I can fix the problem with SU 7 very soon.
      thank u replied
      i use SU8Pro
      i can see the demo's section, but can't use it
      and ur plugin can't work with thearender4su plugin
        GWD
        @unclex said:
        [attachment=0:gu9cegbn]<!-- ia0 -->webqq_app.jpg<!-- ia0 -->[/attachment:gu9cegbn]
        thank u replied
        i use SU8Pro
        What do you mean with 'can't use it'?
        What do you mean with 'can't work with thearender4su plugin'?
        • U Offline
          unclex
          @unclex said:
          [attachment=0:26db8ugb]<!-- ia0 -->webqq_app.jpg<!-- ia0 -->[/attachment:26db8ugb]
          thank u replied
          i use SU8Pro
          Perhaps thearender4su plugin is not the reason
          sometimes " Define real.... ", it's grey, "can't work", i mean it
          sometimes " define real..." is grey, sometimes isn't, it's joking me?
          but i don't know, how to make section plug worked , i mean show the materials on the section.
            GWD
            Can you send me the model and some screenshots of the problem?
            • HumpmetwiceH Offline
              Humpmetwice
              I can't seem to get it to work right myself with the materials. Do you have to type in the name of the material that you want to use? A demo video would help to enjoy this plugin a whole lot more since I have been needing such a plugin for a while now! Thanks anyway, I guess I will figure it out one day?
              • E Offline
                errror404
                hello,
                I'm trying to test this great plugin, but I'm having some dificulties:
                1- I created a group (a simple solid object)
                2- Then I created a texture that started with "_"
                3- I assigned the material to the object using "Define realSection material"
                4- I created a section plane
                5- pressed "Make realSection" and gave it a name
                but nothing happens... and no new layers are created?!
                I'm using SketchUp 8 (free) on a windows machine (XP)
                  GWD
                  @errror404 said:
                  hello,
                  Can you send me the model?
                    GWD
                    I made a little movie to show how realSection works:
                    • ladcweiL Offline
                      ladcwei
                      I really like this plugs,however,it can't work at 7or8,waiting for its rebirth... 🎉
                        GWD
                        please give me some feedback why it's not working? It should work a SketchUp 8 english.
                        • E Offline
                          errror404
                          @errror404 said:
                          hello,
                          It was just a box...
                          It didn't work on your example model either (if I tried to make a new section)
                          I would try later at my home computer (SketchUp Pro)
                          Now, after looking at the video I did notice something diferent... when I make a section my model shows up hallow inside (before and after I pressed "Make realSection" )
                          http://img843.imageshack.us/img843/2551/sectionf.jpg
                          do I need to change some type of option in sketchup?
                          thanks!
                            Any chance you could actually tell us what you are doing in the video. It's difficult to read the menu items and so on due to the compression of the video.
                            I'm trying to follow your PDF instructions. When I choose Make realSection, I can give the section a name but there's no new layer created as stated in the instructions. I think there are enough folks having difficulty getting this to work that there must be a defect that needs to be fixed.
                              GWD
                              what's in the video:
                              make a solid
                              right click at select 'Define realSection material'
                              cancel the define realSection material
                              create a new SU material named '_newmaterial'
                              right click at select 'define realSection material'
                              select the new created material 'newmaterial'
                              define a sectionplane
                              right click selectionplane and select 'Make realSection'
                              realSection is created
                              select solid again and define an other material
                              show sectionplanes
                              select sectionplane
                              right click and select 'Update realSection'
                              realSection is updated
                              edit solid
                              show sectionplanes
                              select sectionplane
                                GWD
                                If I know what's going wrong then I can fix it. Can you open your ruby console when you are trying to run realSection and give me the errors that show up.
                                regards,
                                Guy
                                • E Offline
                                  errror404
                                  regards,
                                  Guy
                                  748115
                                  748123
                                  Error; #<NoMethodError; undefined method `hide_Outliner_MI' for RealSections;Module>
                                  (eval);614;in `updaterealSection'
                                  (eval);774
                                    At Define Material
                                    748115
                                    748123
                                    At Make realSection
                                    (eval);1722;in `updaterealSection'
                                    (eval);1882
                                    (eval);1722;in `call'
                                    (eval);1722
                                    At Show realSection
                                    748115
                                    748123
                                    At Update realSection
                                    748115
                                    748123
                                    (eval);1894
                                    (eval);1722
                                    FWIW, the Outliner wasn't open to begin with.
                                      GWD
                                      @dave r said:
                                      At Define Material
                                      748115
                                      > 748123
                                      At Make realSection
                                      > (eval);1882
                                      > (eval);1722
                                      At Show realSection
                                      748115
                                      > 748123
                                      748115
                                      > 748123
                                      > (eval);1894
                                      > (eval);1722
                                      Thanks I try to fix it asap
                                        GWD
                                        There was a small problem with version 0.3. This is now solved in realSection v0.4. I hope you will still enjoy realSection!
                                        I tested it on SU7 en SU8 and it should work on both version without a problem.
                                          Jim
                                          Is the problem because the plugin relies on Windows-specific libraries (Win32API.so) which are incompatible with Mac OS?
                                            GWD
                                            No plugin check if it's a PC or a MAC. But the problem should be fixed.
                                            • 2 / 5
