    Make all same components?
    13 Posts 5 Posters 1.2k Views 5 Watching
      404 Not Found
      (forums.sketchucation.com)
      haven't tried it?
      • soloS
        Okay, I was able to create groups from faces, but when I tried to great components from groups I ended up with 2756 unique components...I actually only wanted one component and 2756 instances of it.
        Any ideas?
          Thomthom's Component Dropper woulder require you to select 2755 components then run Component Dropper to swap the 2755 with the 1
          • soloS
            Got a link?
              Lazy.....
              404 Not Found
              • mariochaM
                mariocha
                Tried selecting all the groups but the #1 and right-click that #1 in the Component manager to Replace Selected. πŸ˜„
                %(#008000)[Mario C.
                • soloS
                  I tried that initially but it then changes the orientaion of all the components to that of the one I selected.
                  • mariochaM
                    mariocha
                    Oh darn it, they do not have their axes on the same relative spot. 😞
                    Maybef the plugin that made the groups could be tweaked.
                    🀣 I just read your signature. 🀣
                    %(#008000)[Mario C.
                      How about Component Comparison`?
                        autarchos
                        component comparison and matt666's component/groups plugin should do the trick without altering component axes. see my previous post on converting xfrog leaves:
                        404 Not Found
                        the [xfrog] leaves are identical geometry - just a simple rectangle. at least with the models i have. i converted the leaves of a young birch to identical components with matt666's component/groups plugin:
                        404 Not Found
                        it is quite slow, the plugin and the process - took me several hours: select 200-300 leaves at a time, select faces only with thomthom's selection tools, use matt666's plug to convert entities to components, and then run component comp to make them all the same. don't explode the leaf groups until you've converted them all to components, then it takes only seconds.
