    Follow Me and Dangling Line in Component
    13 Posts 4 Posters 1.8k Views 4 Watching
      This happens in v7 and v8 ! It seems associated with the extruded face having edges used by other faces and therefore not being removed - even when it's no longer needed!
      There is a work around - other than Xray-mode + Erase dangler! Use a 'diagonal' bottom edge...Capture.PNG
      • ChiefwoodworkerC Offline
        Chiefwoodworker
        Tig, that is not really a work around because it does not produce a Solid Component, simply component. The real problem here is that the Follow Me tool degrades a Solid Component to Component. In order to subsequently operate on these components with Solids tools in the Pro version they need to be Solid Components. With this bug you have to hunt around to find the extra pieces and correct them before you can use Solids tools.
        The method you propose makes matters worse. It leaves extra lines and faces which keep the part from being a Solid Component.
        Joe....
        http://www.srww.com
          After making the arced-face you would of course remove the 'inner edges' [forming the 'rebate'] to leave the loose top rectangle separated from the joined sides/bottom... before doing the followme on the arced-face which would then form a 'solid'.
          It agreed that it would simply be better if followme worked properly i the first place... but there are work around that avoid erasing spare bits afterwards πŸ€“
            Or separate the follow me face from the rest of the model (component itself) by moving it away a bit (see attached file; the modified component in the scene window).
            Simply select the top face then click on the face. No matter it is not on the path, the follow me works perfectly, leaving you with a solid component (and the face also "disappears")
            Follow Me & Solid Component.skp
              Chiefwoodworker
              Gaieus,
              Thanks, I like that work around better. Leaves a clean solid component.
              By the way, is this the official SU bug report site? Does Google monitor this site and are these kinds of bugs likely to get fixed?
              Joe....
              http://www.srww.com
                I often do te Follow me operation this way even without the solid requirement (especially with more complex models where faces like that gen stick to all sorts of places).
                Well, a more "official" bug report form would be here:
                http://sketchup.google.com/support/bin/request.py?contact_type=bug
                however most confirmed bugs sooner or later get through to Google via various channels. This one (more exactly the one this is also part of) was reported back with SU 7 by me particularly.
                πŸ˜„
                  Chiefwoodworker
                  Thanks Gai,
                  Actually, I have been doing it that way for some time because of other anomalies with Follow Me i.e.separating the shape from the selected path or face of the part. But I just noticed this anomaly in the last few days and its implication for Solids. Sounds like it may not get fixed real quick, but thanks for the work around.
                  Joe....
                  http://www.srww.com
                    Jim
                    This is a little practiced, but just an idea.
                    http://i.min.us/jdDc5q.gif
                      Chiefwoodworker
                      Jim,
                      That works too, though I don't know if you can always judiciously find the right place to anchor the shape to avoid leaving dangling lines. But it does have the advantage of aiding you in forming the shape. Gai's solution may be more general but does require creating the shape away from the part. On the other hand, it is always good to have several workarounds.
                      Joe....
                      http://www.srww.com
                        Jim
                        There's as many different ways as there are people doing it.
                        This method did however produce a solid without any cleanup. But only 6 segments from the the 1/4 circle,as opposed to the default 12 an Arc would have used.
                        You're right if the corners weren't square it wouldn't work so neatly.
                          Well what I did was to temporarily group your face (until I moved away) then exploded it. So you can actually make the profile "in situ" initially.
