    Corner rounding script
    4 Posts 3 Posters 671 Views 3 Watching
      revelever
      I've just started using Fredo's corner rounding script and I must say it's quite amazing. I was wondering if anyone has a good work around for one of the known issues with this script, namely when you has an instance of a triple inside corner. I have a model which contains many of these. It doesn't need to be resolved per se, as these parts are not visible, but rather worked around. thank you.
      • charly2008C Offline
        charly2008
        Hi Revel,
        I hadn't noticed this mistake before. Perhaps this is a solution. I marked only two edges and rounded it. Some faces will be destroyed and have to be repaired. Then I marked the missing edges and rounded it. Don't forget this small edge which i marked with an arrow.
        Charly
        • massimoM Offline
          massimo Moderator
          This is a well known issue. See this post and Fredo's reply below.
            revelever
            Thank you I appreciate the response guys, both were very helpful. Cheers!
