Corner rounding script
I've just started using Fredo's corner rounding script and I must say it's quite amazing. I was wondering if anyone has a good work around for one of the known issues with this script, namely when you has an instance of a triple inside corner. I have a model which contains many of these. It doesn't need to be resolved per se, as these parts are not visible, but rather worked around. thank you.
Hi Revel,
I hadn't noticed this mistake before. Perhaps this is a solution. I marked only two edges and rounded it. Some faces will be destroyed and have to be repaired. Then I marked the missing edges and rounded it. Don't forget this small edge which i marked with an arrow.
Charly
This is a well known issue. See this post and Fredo's reply below.
Thank you I appreciate the response guys, both were very helpful. Cheers!
