    Compound miter
    19 Posts 6 Posters 2.8k Views 6 Watching
      mac1
      As with most SU models there are more than one way to "skin a deer".
      Lay out your platform & foot (4x4=> doing one will array copy the rest later) location in a plan view. Connect as many edges as you can without making coplanar edges, the location of the feet you can calculate based on the 20 'or make approximate to account for the end cut you will have to make then and movethe platform up to the height desired. You can the connect the bottom pole edges to the platform not connected before. Make the pole a component, measure one side width with the tape tool and scale to the design 4x4 ( Other wise it will be less than 4x4).This step must be done in context of the pole component or all the model will be scaled. Array copy around the rest of the platform and you are done => no intersections required 😄 and angle is automatic
      Update: Make sure when you move the platform up you lock the move to the blue axis( hold shift). Otherwise it will try to autofold on you.
        tspco
        I didn't think about the array, approach, thanks. You are close but it is not a deer stand, it is a fire lookout tower, when I get more of it done I will post a snapshot.
        SU make 2017, /Twilight Render Hobby
        Windows 10,64 bit,16GB ram, quad core Athlon 3.6 gHz proc. Anything else you want to know, ask me.
          mac1
          must be a prairie stand, my pines on the back lot are about 40'??
            tspco
            Well we have two grassland towers around here, both steel "Aermotors", and one closer in a forest. It is taller, than 40'more like 100'. I am also working on a 40 footer drawn from actual forest service drawings,from about 1954. If anyone s interested look here
              Cool link! Thanks.
                mac1
                LEGO set approach to "towers"
                BTW the design I was suggesting does not result in compound miter cuts. However, looking at your link there will be some plus the issue of building stairs. Suggest you should define the problem in total. I have seen many cases where people ask simple questions , get a simple answer but does not address the total problem and so there is a long drawn out process to come to a closed form solution 😞
                SU is very good at getting that type of info and is the reason I started using it when someone wanted non symmetrical ( ellipse with different base and frustrum axis lengths) speaker enclosures for a speed boat wake board bar. After trying twice with trig I decided a different approach was in order
                  tspco
                  Ok Done Did It, the legs in this tower have been edited, as I wanted. I decided to render it before posting here. so here it is.
                  http://img.photobucket.com/albums/v48/Earthshaker/SU and KT/lookout1205.jpg
                  enjoy
                  • mitcorbM Offline
                    mitcorb
                    Good work!
                    Always something satisfying with the completion of the model phase.
                      Nice work. Thanks for showing that.
                        mac1
                        Very, very nice. And thesego up high!
                        All the cross bracing will be compound miters did you get that figured out OK
