    Compound miter
    19 Posts 6 Posters 2.8k Views 6 Watching
      tspco
      I watched the video the user appears to be using a plugin, but since I don't speak read of write French, I can't find out what plugin is being used.
      I will try to explain my problem again, OK I have a square pole 20' long it is tilted in the red axis AND the green axis, this pole is 1 of 4 acting as supports, and tilted toward the center of a square, and support a smaller raised platform, the best way to make the posts I have found is with a line drawn, from the bottom corners up to the top platform's corners, and use follow me. Now by doing this the end faces are perpendicular to the faces along the pole, but,they need to be parallel to the ground platform, and the upper platform, to look right, I am picky that way. Yes I can draw the end faces manually, but I would rather have a plug in to do this for me, (it would save a lot of time)
      SU make 2017, /Twilight Render Hobby
      Windows 10,64 bit,16GB ram, quad core Athlon 3.6 gHz proc. Anything else you want to know, ask me.
      • bmikeB Offline
        bmike
        Intersect with model, or use the solid tools in Pro 8.
        Here's a video on using intersect: (no audio)
        Use a dummy block where your platform is.
        Edit the 'pole' component.
        Select all the faces and lines.
        Right click > Intersect with model.
        Close component.
        Delete dummy block.
        Edit component - delete unwanted faces.
        Using the solid tools, or the BoolTools plugin is faster.
          I agree with Mike and if your legs are all instances of the same component, you only need to edit one of them anyway.
          • mitcorbM Offline
            mitcorb
            This must be the basis for a deer stand?
            I will try to attach an image of what I thought you said.
            I did not use any plugins, and it took about 10 minutes to do this.
              Funny. I was thinking of a deer stand, too.
              Lopping off the top of the leg component is a few seconds of very basic work in SU. Seems hardly worth a plugin. And if you need to do this more than once, save the leg component for future use.
                mac1
                As with most SU models there are more than one way to "skin a deer".
                Lay out your platform & foot (4x4=> doing one will array copy the rest later) location in a plan view. Connect as many edges as you can without making coplanar edges, the location of the feet you can calculate based on the 20 'or make approximate to account for the end cut you will have to make then and movethe platform up to the height desired. You can the connect the bottom pole edges to the platform not connected before. Make the pole a component, measure one side width with the tape tool and scale to the design 4x4 ( Other wise it will be less than 4x4).This step must be done in context of the pole component or all the model will be scaled. Array copy around the rest of the platform and you are done => no intersections required 😄 and angle is automatic
                Update: Make sure when you move the platform up you lock the move to the blue axis( hold shift). Otherwise it will try to autofold on you.
                  tspco
                  I didn't think about the array, approach, thanks. You are close but it is not a deer stand, it is a fire lookout tower, when I get more of it done I will post a snapshot.
                    mac1
                    must be a prairie stand, my pines on the back lot are about 40'??
                      tspco
                      Well we have two grassland towers around here, both steel "Aermotors", and one closer in a forest. It is taller, than 40'more like 100'. I am also working on a 40 footer drawn from actual forest service drawings,from about 1954. If anyone s interested look here
                        Cool link! Thanks.
                          mac1
                          LEGO set approach to "towers"
                          BTW the design I was suggesting does not result in compound miter cuts. However, looking at your link there will be some plus the issue of building stairs. Suggest you should define the problem in total. I have seen many cases where people ask simple questions , get a simple answer but does not address the total problem and so there is a long drawn out process to come to a closed form solution 😞
                          SU is very good at getting that type of info and is the reason I started using it when someone wanted non symmetrical ( ellipse with different base and frustrum axis lengths) speaker enclosures for a speed boat wake board bar. After trying twice with trig I decided a different approach was in order
                            tspco
                            Ok Done Did It, the legs in this tower have been edited, as I wanted. I decided to render it before posting here. so here it is.
                            http://img.photobucket.com/albums/v48/Earthshaker/SU and KT/lookout1205.jpg
                            enjoy
                            • mitcorbM Offline
                              mitcorb
                              Good work!
                              Always something satisfying with the completion of the model phase.
                                Nice work. Thanks for showing that.
                                  mac1
                                  Very, very nice. And thesego up high!
                                  All the cross bracing will be compound miters did you get that figured out OK
