    Problem with Vray
    renderpluginsextensions
    8 Posts 2 Posters 992 Views 2 Watching
    • I Offline
      iakram
      Hello everyone...
      Thanks in advance, and if I am placing this topic in the wrong place then I am sorry and feel free to move it.
      Anyways, I have recently started using vray for sketchup and I am following the manual on the website to learn it, however I am having a problem from the very first render.
      http://www.vray.com/vray_for_sketchup/manual/vray_for_sketchup_manual/render_options_for_vray_for_sketchup/vray_for_sketchup_render_options_5.jpg
      This is how the manual says it should look like, and this is what I get
      http://i1097.photobucket.com/albums/g355/akram1990/Failure.png
      I am using default settings as used in the manual and haven't changed anything, any help would be appreciated.
      Thanks.
        What version of VfSU are you using?
        The manual and that sample scene was made during the original VfSU version - some behaviour and default settings are now different etc.
        • I Offline
          iakram
          That's probably the problem, however I need to know what settings do I need to adjust to have a similar output, since going on with the manual, and after adjusting some settings as said, the render becomes very bright and almost white... The manual I am talking about is the one on the vray website by the way, and since I am completely new to using vray I could really use the help.
          Thanks.
            Don't know to be honest. What version are you using?
            Since the various versions behave differently it's easier to give an answer if we know what versions we're talking about.
            • I Offline
              iakram
              Sorry, I should have posted that before...
              Says here version is RS 1.5 something.
                Does the about section say 1.05.30 ?
                • I Offline
                  iakram
                  Yes, that's the one.
                  Anyways, I've tried something else, instead of restoring it to default I loaded "sketchup default" preset, it looks very similar now except that I can't get over that sepia tone.
                  http://www.vray.com/vray_for_sketchup/manual/vray_for_sketchup_manual/render_options_for_vray_for_sketchup/vray_for_sketchup_render_options_10.jpg
                  http://i1097.photobucket.com/albums/g355/akram1990/3.png
                    I think you can adjust that if you go into Camera and adjust the colour filter. (Or what that property was called...)
