    [Plugin] Axes Tools
    63 Posts 20 Posters 94.4k Views 20 Watching
      rv1974
      One more thing:
      Could this script stick to the current model axes not absolute world?
        @rv1974 said:
        One more thing:
        It doesn't rotate the axis, it simply moves the origin of the components - the insertion point.
        Though, it could be made to also rotate the axis to match the current model axis.
          rv1974
          That's exactly what I meant
            diegog321
            thank you thom
            This plugin saved my life about five minutes ago!
            Diego
              daniel266
              OHH my GOD !! GEnius i have a dwg file that moves all along the place and i need to explode to make it stop this just solved everything!!
              SO much THX!
                Ruturaj
                Hello sir,
                This plugin is very good & handful .....
                but when i was applying following Settings :
                X (Red) : Right
                y (Green): Back
                z (Blue): Top
                selected any group or component its work
                but when i was applying again it on another group or component, it will not reset to the default settings ....?
                I was changing default MODULE
                ### MODULE VARIABLES ### -------------------------------------------------
                	# Preference
                	@settings = TT;;Settings.new('Axes editor tool')
                	@settings[;x, 'Left']
                	@settings[;y, 'Front']
                	@settings[;z, 'Bottom']
                How to reset ......?
                Thank you,
                Ruturaj
                Thanks,
                RuturaJ
                  I remembers the last values you used. Just select what you want from the drop down menus. The "defaults" you refer to is only defaults for the very first time the plugin runs.
                    Ruturaj
                    oh......... ok..... πŸ‘
                    Thanks,
                    RuturaJ
                    • utilerU
                      utiler
                      Hey Thomas, love this little gem.....! So simple yet so powerful!
                      I have a question.
                      See the attached images of a plan view:
                      And a perspective view:
                      Say I want to set my axis to the rear of the couch, centered and at the bottom. When I followed your axis tool to achieve this I have to input these settings:
                      Instead of 'X' back, 'Y' centre', 'Z' bottom.
                      It appears that the options in the dialogue box should be reversed. Don't you think that the 'X' options should be Front/Centre/Right and 'Y' options should be Left/Centre/Right instead of the other way around? It would just make sense according to how you view a model after all from an axis green is naturally north/south or vertical on the page or screen and red is east /west or horizontal......
                      Love your work!!
                      PS: Skippy attached FYI.
                      couch.skp
                      Just Curious...
                        utiler: Front/Back, Left/Right, Top/Bottom is determined by the components internal axis - not the model axis.
                        note that this plugin does not change the orientation of the component axis, but just the axis origin.
                        • utilerU
                          utiler
                          Sure, Thomas but whether the internal axis is the same as the model axis the 'X' is still horizontal and so any alignment is either north [front] or south [back]....
                          I just don't see how you can nominate left or right of a red axis unless the red axis is vertically aligned; which it isn't....
                          Just Curious...
                            The way I view axis:
                            The way that SketchUp, and most other 3d modelling apps, display the workspace with axis in default scenes.
                            How can something vertical be considered left/right?
                            • utilerU
                              utiler
                              I see. I get it.
                              I guess I was thinking in orthogonal [plan view] rather than the 3D environment. In plan the green axis would be vertical and hence anything to the right of it would be 'right and visa versa.....
                              I won't argue your understanding of SU or any other program.... I'm happy with your explanation.
                              cheers,
                              πŸ‘
                              Just Curious...
                                Jim
                                It might be a nice option to be able to set the axis in relation to a sub-component. Like a arm, which might have a upper_arm, lower_arm, and shoulder_joint sub-components. Select the Arm, then move it's insertion point to the center of the shoulder, or pivot point.
                                http://i.min.us/jb0gja.png
                                  Good idea.
                                  Is that just a visual mock-up - or you got such a code working?
                                    Jim
                                    It's not a mock-up, but it's not working either. More like a hack-up.
                                    Another option could be to modify your Pivot Gizmo to be able to use an axis of any of a selection of Instances.
                                    The Pivot Gizmo, along with a Rest Rotations would make posing much easier than currently.
                                      Yea - I've wanted a plugin that allows you to set custom joints and would also moved linked instances when moved.
                                      Weren't you working on such a system? Or am I confusing it with the concept you showed where things snapped to each other?
                                      • E
                                        errror404
                                        Pretty cool plugin!!... If I could add anything, it would be a 4th option: (Front, Back, Center, or leave it unchanged)
                                        Lets say I'm working on a component like a window... and I modified the window to be twice as long in the red axis. I want to center the red axis, but I don't want to change the green axis (it has a cutting plane and it's not located either Front, Back, or Center).
                                        thanks!
                                          Another good idea! ❗ πŸ‘
                                          • demD
                                            dem
                                            Excuse me, how can I create a button with
                                            "cmd = UI::Command.new () {}", for this tool? πŸ’š
                                            • 2 / 4
