    Office Interior "Building B" - SU + VfSU
    22 Posts 12 Posters 2.8k Views 12 Watching
      'Bang head here' device maybe? every office needs one πŸ‘
        ...thought that was the monitor... πŸ˜•
          Roger
          Those are the latest Piet Mondrian Monitors.
          http://www.azcreative.com
          • I Offline
            IAN02
            sir can yu post your settings thank you
            • shuraS Offline
              shura
              Fantastic render Thomas!
                I made the model originally with VfSU 1.05.30 - but now I use 1.48. Not sure if I would have needed tweaking, but here it is. (Require 1.48)
                (Require VfSU 1.48)
                • I Offline
                  IAN02
                  can you please post your setting sir i reaaly like the output very nice
                    I already did - after asked the first time. πŸ˜‰
                    • boofredlayB Offline
                      boofredlay
                      Nice work Thomas. Everything is so clean and wireless.
                      • honoluludesktopH Offline
                        honoluludesktop
                        @thomthom said:
                        .......I'm quite happy with the materials and lighting. There is a version with people - but they annoyed me.........
                        One of the walls could use a clock.
                        I felt the same in my "youth". Sigh!!!!!now I can't even recall when the sentiment changed. >_<
                        • RichardR Offline
                          Richard
                          VERY nice work mate!!! As always it must be said!
                          The flooring looks just a little flat though!
                          BUILTBRAND.COM.AU
                          • I Offline
                            IAN02
                            can you post it in image form sir i only using vray for sketch up 6.. if you have time thank you.
                              koipetta
                              Yummy πŸ‘
                              what are the yellow and red things?
                              Computers screens!
                              • andybotA Offline
                                andybot
                                Thomas,
                                Nice clean look, everything is so crisp and coordinated. Nice work!
                                One comment: I was looking more closely at your lighting and have a question about how you did your fluorescent fixtures. It looks like they are supposed to be direct-indirect, but there's a shadow on the ceiling above each one. Do you have a rectangle light under each fixture? You may want to disable shadows in the material you use for the interior of the lights to get rid if the dark areas.
                                Andy
                                  JohanR
                                  Nice and clean πŸ‘
                                    @andybot said:
                                    Thomas,
                                    Andy
                                    I don't remember how the light was set up. Maybe my rectangular lights lit in both directions...
                                    • andybotA Offline
                                      andybot
                                      That's what I assumed - which is what I figure is the light source for the shadow. A light like that would be open on the top and would not have that shadow - which is why I noticed.
                                        steelers05
                                        Thomthom, I think this is very photo-realistic renderings and I like it. I dont mind the flooring material, I just think it would help if there were less of it in the foreground...cropping the image a bit more may help, because theres just too much of it and it takes away from all the detailed areas.
