    Office Interior "Building B" - SU + VfSU
    22 Posts 12 Posters 2.2k Views 12 Watching
      Something the interior designer put there... I don't ask too many questions. πŸ˜†
        Think it might be something to stick notes to...? At least it adds a bit of colour.
          'Bang head here' device maybe? every office needs one πŸ‘
            ...thought that was the monitor... πŸ˜•
              Roger
              Those are the latest Piet Mondrian Monitors.
              http://www.azcreative.com
              • I Offline
                IAN02
                sir can yu post your settings thank you
                • shuraS Offline
                  shura
                  Fantastic render Thomas!
                    I made the model originally with VfSU 1.05.30 - but now I use 1.48. Not sure if I would have needed tweaking, but here it is. (Require 1.48)
                    (Require VfSU 1.48)
                    • I Offline
                      IAN02
                      can you please post your setting sir i reaaly like the output very nice
                        I already did - after asked the first time. πŸ˜‰
                        • boofredlayB Offline
                          boofredlay
                          Nice work Thomas. Everything is so clean and wireless.
                          • honoluludesktopH Offline
                            honoluludesktop
                            @thomthom said:
                            .......I'm quite happy with the materials and lighting. There is a version with people - but they annoyed me.........
                            One of the walls could use a clock.
                            I felt the same in my "youth". Sigh!!!!!now I can't even recall when the sentiment changed. >_<
                            • RichardR Offline
                              Richard
                              VERY nice work mate!!! As always it must be said!
                              The flooring looks just a little flat though!
                              [BUILTBRAND.COM.AU](http://builtbrand.com.au/)
                              • I Offline
                                IAN02
                                can you post it in image form sir i only using vray for sketch up 6.. if you have time thank you.
                                  koipetta
                                  Yummy πŸ‘
                                  what are the yellow and red things?
                                  Computers screens!
                                  • andybotA Offline
                                    andybot
                                    Thomas,
                                    Nice clean look, everything is so crisp and coordinated. Nice work!
                                    One comment: I was looking more closely at your lighting and have a question about how you did your fluorescent fixtures. It looks like they are supposed to be direct-indirect, but there's a shadow on the ceiling above each one. Do you have a rectangle light under each fixture? You may want to disable shadows in the material you use for the interior of the lights to get rid if the dark areas.
                                    Andy
                                      JohanR
                                      Nice and clean πŸ‘
                                        @andybot said:
                                        Thomas,
                                        Andy
                                        I don't remember how the light was set up. Maybe my rectangular lights lit in both directions...
                                        • andybotA Offline
                                          andybot
                                          That's what I assumed - which is what I figure is the light source for the shadow. A light like that would be open on the top and would not have that shadow - which is why I noticed.
                                            steelers05
                                            Thomthom, I think this is very photo-realistic renderings and I like it. I dont mind the flooring material, I just think it would help if there were less of it in the foreground...cropping the image a bit more may help, because theres just too much of it and it takes away from all the detailed areas.
