    [NEW]Sketchup 2 Vue
    extensions
    164 Posts 28 Posters 47.2k Views 28 Watching
    • KrisidiousK Offline
      Krisidious
      well if you look at my screenshots above... my model is quite large and complex. I think that when you remove all materials from your model you'll find it imports fine into Vue... leading me to the conclusion that some materials are not welcome in Vue.
      the model I posted has projected materials on the turrets
      By: Kristoff Rand
        dburdick
        @nomo81 said:
        the left one was exported with the sketchup 2 vue plug, material issue,
        the right one was exported with 3dmax way., no material issue.
        regards
        nacho
        Hi Nacho. Can you send me the SU file of your test here and I will try and see what the problem is. Send the model to:
        dburdick@e-onsoftware.com
          d12dozr
          What atmosphere type, if any, do you guys find works best for architectural rendering?
          http://goo.gl/f7ooYh
            d12dozr
            I asked this on the Cornucopia forum but no response yet over there...
            I'm having some trouble, hopefully just beginner's ignorance...
            1. My Sketchup scenes are not translating to Vue cameras. I made sure to unlock the camera height and uncheck "Sun face camera" in Vue like the Sketchup2Vue manual says. I am opening the model in Vue using the Python loader script.
            2. the imported model comes in partially below the ground in Vue, even though it is above ground in Sketchup.
            I'm using Vue 8 Complete and SU 8 free for the Vue export.
              dburdick
              We discovered the problem on this one. In Vue, go to Options-->General Preferences and then uncheck "Preserve size of natural elements at creation"
              This is a legacy option that auto-adjusts scaling to Vue Units on imports. It should be off by default, but apparently on Vue 8 it's on - so just uncheck this.
                d12dozr
                πŸ‘ That does it!
                Thanks, Dave.
                  miikka1978
                  Has anybody experienced similar problem when using Sketchup models in Vue? I have exported my Sketchup model into Vue with the new plugin. But, when I move the model in Vue it is not complete component. There is separate SingleSidedFacesGroup that I have not created in Sketchup.
                  http://img535.imageshack.us/img535/1109/modelproblem.jpg
                    dburdick
                    You have to move the model as a whole. The single sided faces group consists of all of the faces which have materials on both sides. If you just grab the whole model and move it, all of the sub-components will move with it -- including the single-sided faces group.
                      miikka1978
                      Thanks for explaining dburdick. Anyway, it seems that there are many other faces with material on both sides in my crane model. But, export doesn't create "loose geometry" in these cases. Based on this, I believe that the problem arises when there is material on both sides of face and these materials are different.
                      Is there is any way/plugin to examine Sketchup models and geometries in order to find out if there are faces with different materials on the sides of the same face?
                        d12dozr
                        Here is one by TIG: http://forums.sketchucation.com/viewtopic.php?p=264134#p264134
                          dburdick
                          The SUVueExporter creates either:
                          1. double-sided faces - where the materials are the same on both sides or if one of the sides uses the default material
                          2. single-sided faces - where the face uses a different material on each side and neither of the sides is the default material
                          The reason for isolating the single-sided faces is that these faces are created as a single-sided mesh in Vue (e.g. where each polygon is treated as having a unique material on each side).
                          • Bob JamesB Offline
                            Bob James
                            I am unable to load a SketchUp model of a house into Vue 9. I'm attempting to use the SU2Vue ruby script in Sketchup 8 Pro.
                            Upon completion of export from Sketchup, I get a .vob file and a folder with an .xml file, a .py file and many .jpg and .png files.
                            I have set the Camera Height to unlocked and Point Sun at Camera disabled.
                            I've also unchecked "Preserve size of natural elements at creation"
                            If I use the Automation -> Run Python Script all I get is a large ball as the model.
                            If I try to use File -> Load Object I get an error statement saying that it can't find the .tga file xxxxxx.tga. If I say no to it's query to look for it, Vue crashes.
                            A truly distressing introduction to Vue 😒 πŸ˜’
                            Error received when trying to load .obj file
                            This is supposed to be a house!!! Results from Automation -> Run Python
                              Krisidious
                              I have been using the Import option... not load or even Python...
                              try that and report back... are you using 9? because I am using 8.5... this may be a 9 bug.
                              By: Kristoff Rand
                                d12dozr
                                Bob,
                                I use the Automation -> Run Python Script and it works for me, like Kris, I'm also using Vue 8.
                                TGA is an image file, like JPG. Maybe you could try finding and deleting/replacing that material in the Sketchup file before exporting, see if that helps.
                                  Krisidious
                                  save a copy of your model and remove all materials, then try importing it into Vue. report back
                                  By: Kristoff Rand
                                    Bob James
                                    None of the materials exported are .tga: they are all .png or .jpg.
                                    When I try to import the .vob file I get the errors looking for 191_tx01_402.tga, etc. (there are eight of them - I have no idea what material/texture they are linked to).
                                    So I've tried:
                                    1. Automation -> Run Python Script [All that appears is a large sphere]
                                    2. File -> Load Object [asks for .tga, cancel->Vue crash]
                                    3. Import .vob [asks for .tga, cancel->Vue crash]
                                    Edit: I also have Vue 8 Complete and I get the same result with it. As a matter of fact, I get the error messages when I use Automation -> Run!!!
                                    I'm at a loss
                                      Bob James
                                      How do I do that: it's a big model with over 80 different materials 😲
                                        Bob James
                                        I made a simple model: cube with cylinder on top - no color/material/texture.
                                        When I import it by any of the three methods all I get is a sphere!
                                        But at least I don't get the .tga error messages.
                                        Not very encouraging 😞
                                          Bob James
                                          @krisidious said:
                                          do you have the new version or the update to the plugin?
                                          What is the latest version of the plugin? I got mine along with Vue 8 Complete back in October.
                                          I opened the ruby, but there is no date in it. I see a lot of \win32\ in it: I'm using 64-bit Win 7 Professional. Is that a problem?
                                            d12dozr
                                            64 bit should not be a problem, I'm using 64 bit.
                                            FWIW, I made a simple model of a cube, textured it with a .tga image, and it imported into Vue just fine.
                                            Bob, I can't think of anything else...have you tried emailing Dave Burdick? He posted his email address near the top of the previous page.
                                            • 5 / 9
