    [Plugin] Zorro
    53 Posts 34 Posters 69.8k Views 34 Watching
    • W Offline
      wheay
      pls help me. i need this tool badly. it wont work for me. how do you install this. i just put it in to the plugins folder just like the others. but this dont work. pls. help this is what i need. thanks.
      "i try to learn everyday"
      http://designerslandmark.blogspot.com/
      • W Offline
        Whaat
        Did you check your 'tools' menu? πŸ˜„
        • W Offline
          wheay
          oppsssss! stupid me. 🀣
          i thought it was on the view toolbar. sorry for that. thanks.
          i love this one. 😍
            kjc
            I'm happy to find this tool, realy nice! I have no idea how you create such impressive things, respect.
            This tool could be even better if it could work in parallel projection. Are youstill working on it or not?
            • W Offline
              Whaat
              My commercial script 'Subdivide and Smooth' http://www.smustard.com/script/SubdivideAndSmooth
              has a tool identical to Zorro but it also works in parallel projection mode (and it snaps to axis)
              I hope to release an update to Zorro sometime in 2009 that works in parallel projection mode, but you might be waiting quite awhile.
              Dale
              • CadFatherC Offline
                CadFather
                Hi Dale - that would be great!
                • W Offline
                  Whaat
                  Be on the lookout for an update to Zorro coming very soon...
                  It's gonna be good.... πŸ˜‰ πŸ˜„
                    CadFather
                    can't wait to see what diego de la vega has been up to...
                    cheers Whaat!
                    • E Offline
                      evrnaidu
                      It's great! It will be more useful if the divided parts are grouped so that unwanted portion could be deleted easily. Of course it is difficult to make it as two parts when components are nested. If that is the case, grouping may be done within the components.
                        Hi Evr (and welcome),
                        Check out Zorro 2 then:
                        http://forums.sketchucation.com/viewtopic.php?t=16038
                        • It "resides" in the context (right click) menu of a section plane (so easy to set up)
                        • It will actually cut through all nested groups/components
                        • Finally it actually deletes what is behind (invisibly) the section plane.
                          %(#BF0000)[So be extra careful to only use it
                          on a copy of your model!]
                        • E Offline
                          evrnaidu
                          Thank you Mr. Gaius. It really works fantastically.
                            Now combine it with SectionCutFace and you can fill in those ugly holes.
                            http://forums.sketchucation.com/viewtopic.php?t=20564
                              How do you use the section Cut face with this sort of inclined cut face?
                              Cut first with Zorro2, then ?
                              Pilou.skp
                                magpie
                                Thanks Dale, really like the plugin and for simple geometry no problem, but on a more complex model I use zorro2 and it either bugsplats or sketchup simply disappears from my screen πŸ˜•
                                Any modelling errors I should be careful of? It's a model made in skp8 and exported to skp6...any help appreciated.
                                  magpie
                                  hey, grouping and locking has done the trick! thanks!(note to self: read ALL of the posts beforehand)
                                  • Z Offline
                                    zunkian
                                    Hello everyone!
                                    I'm trying to cut off the top section of this whole floor area (please see attached) Ground floorB.jpgbut zorro always crashes my sketchup. A bugsplat always comes up in the middle of the "cutting" process.
                                    It seems it cannot cut complicated models or with models with several polygons.
                                    Please advice me on what to do to solve this problem.
                                    I have to meet a client deadline this week and zorro is no cooperating very well.
                                    Please help!
                                    zun kian
                                    • mitcorbM Offline
                                      mitcorb
                                      Hi, zun kian:
                                      If you are in a hurry, perhaps create a large rectangular plane group bigger than the foot print of your model. Position the plane at the vertical elevation at which you wish to cut. Intersect plane with model. Delete all above plane. Of course, some of this model may be components, and this would be another level of complexity to deal with. I would probably save the model as a new version and work on that one.
                                      • Z Offline
                                        zunkian
                                        @mitcorb said:
                                        Hi, zun kian:
                                        Thanks mitcorb will try that if that's the only way it would help!
                                        zunkian
                                        • 3 / 3
