    [Plugin] Selection Toys
    594 Posts 121 Posters 587.6k Views 121 Watching
    • brookefoxB
      brookefox
      Yes, a few. This is not current; I will update it soon.
      (eval):6094: compile error
      (eval):4921: syntax error, unexpected ',', expecting ')'
      if (n1.between? (n2 - interval), (n2 + interval))
                                  ^Error Loading File cd_power_extension_m.rb
                                  ^Error Loading File cd_power_m.rb
                                  ^no such file to load -- Projection/projection.rbError Loading File projection_extension.rb
      no such file to load -- Projection/projection.rbError Loading File protrude.rb
      no such file to load -- protrude/protrude.rbError Loading File vismap2_menu.rb
      can't convert nil into String
      ~ Brooke
        They refer to other plugins. You seem to have multiple issues though. You might want to consider starting from scratch..
        • brookefoxB
          brookefox
          Yes, I thought they referred to other plugins, but you were kind enough to ask. I think I would much rather try to ferret out the problems with a few than mess with the score(s) that seem to be OK. After addressing the apparent issues, the current load error msg. is:
          Error Loading File tt_selection_toys.rb
          undefined method `require_version' for TT_Lib:Module
          ~ Brooke
            hm... and you have the latest TT_Lib (version 1.x) ?
            Can you post a screen of the content of your TT_Lib folder?
            • brookefoxB
              brookefox
              Well, certainly, but I feel I have taken enough of your time and will try to re-DL and re-install in the likely event that I boobied somehow along the way...
              Either way I will be back.
              Thank you.
              ~ Brooke
                It looks like you have an old version of TT_Lib installed. The dates of the files, and the lack of many of the files from the latest version would suggest this. You can confirm by typing TT_Lib::Version into the Ruby Console and see what it returns.
                If you recently did download TT_Lib but did not get 1.2.0 then maybe you're getting a cached version.
                • brookefoxB
                  brookefox
                  @thomthom said:
                  TT_Lib::Version into the Ruby Console returns.
                  Results:
                  TT_Lib::Version
                  Error: #<NameError: (eval):2537: uninitialized constant TT_Lib::Version>
                  (eval):2537
                  Perhaps a cached version: that may let me off the stick a little for screwing things up.
                  I re-DLd and installed and will advise if fix fails.
                  Many thanks.
                  ~ Brooke
                    arjunmax09
                    I have sketchup pro 8 ..I've removed my old version of selection toys and downloaded the new one.I already have this 1.2.0 version of TT_lib. But everytime i start sketchup i get a dialog box saying ...Selection Toys requires a new version, 1.2.0, of TT_Lib. Sketchup pauses for a moment...then all the toolbars come in place and selection toys plugin works fine...what should i do to get rid of the dialog box??
                    when you fail at something....you haven't really failed...you've found one way the thing will not work out
                      What do you get when you enter TT_Lib::Version into the Ruby Console?
                        arjunmax09
                        I get this...
                        TT_Lib::Version
                        Error: #<NameError: (eval):2307: uninitialized constant TT_Lib::Version>
                        (eval):2307
                        wonder why i'm getting an error when selection toys plugin is working fine... 😒
                          what? you get that error but Selection Toys is still loaded?
                          Something is messed up here. Can you post a screenshot of your plugins folder?
                            @arjunmax09 said:
                            I get this...
                            TT_Lib::Version
                            (eval):2307
                            Sorry - it should be TT_Lib::VERSION - note the big capitals.
                              arjunmax09
                              here's my list of plugins...i also downloaded tt_lib 2 just in case it wd help..but the problem is still there..
                              uh..i'm getting this when i enter the required command in ruby console....
                              TT_Lib::VERSION
                              1.1.0
                              I removed the earlier version but don't know what's this all about
                                TT_Lib::VERSION
                                1.1.0
                                This seem to be the same as what brookefox had: http://forums.sketchucation.com/viewtopic.php?f=323&t=14975&start=315#p282763
                                Simply not updated TT_Lib version. Make sure you overwrite the old files.
                                TT_Lib2 won't have anything to do with Selection Toys.
                                  arjunmax09
                                  I already overwrote the old files..even deleted the old folders, redownloaded your ttlib plugin from SCF and unzipped them to the plugins library but the error still pops up... 😕
                                    Somehow you're not installing the latest. ...maybe when you download you are getting a cached version... tried clearing your browser cache?
                                      arjunmax09
                                      yup...i always clear up my browser cache using CCleaner..a freeware that clears up all the temporary files trash, etc...Can you mail me the recent version...is there any way to detect if I have a recent version or not??
                                        Download the TT_Lib zip file - extract to a temporary location can open up core.rb in Notepad. See if it says VERSION = '1.2.0' somewhere in there.
                                        Then you verify if it's a download problem or not.
                                          arjunmax09
                                          It is version 1.2.0..i checked it out in the core.rb file.
                                          CONSTANTS
                                          # TT_Lib version constant.
                                          # @since 1.0.0
                                          **VERSION = '1.2.0'**
                                          	# Array indexes for VERSION.split('.')
                                          	# @since 1.2.0
                                          	V_MAJOR = 0
                                          	V_MINOR = 1
                                          .. 😒 what should I do now?? It's not a download problem of ..what's wrong with my file then??
                                            I dunno... must be something in the way you copy the files to your plugins folder.
                                            Are you using an administrator account?
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 29
                                            • 30
                                            • 16 / 30
