    [Plugin] BezierSpline - v2.2a - 22 Apr 21
    460 Posts 183 Posters 2.0m Views 183 Watching
      The Bezier curves you see in Illustrator and similar are series of Bezier curves connected together. While the splines in this plugin are all one segment.
      It would be interesting to see a variant like you describe, would allow for better local control.
        tfdesign
        This is a brilliant plugin. Thanks Fredo6! When I've got some money again, I'll send you a donation πŸ˜„
        (In fact I'll send donations to all whose plugins I use, once the work gets flowing again! 😳 πŸ˜„ ).
          Scott M
          @gaieus said:
          efw? I have never seen that. Maybe try to rename it to rb (or rbs)?
          Also, Bezier Spline may need to be enabled under Window > Preferences > Extensions (and then you find a whole toolbar for it under View > Toolbars)
          If you go to the download link clik on save it will show the file type as a EFW file. When I save it too my desk top it is a EFW file. I then clck on send too zip folder.Then extract all into plugin folder. It showes up in this folder as a EFW file type.Am I doing something wrong.
          https://www.youtube.com/user/ecabinetstips
            When you click the "BezierSpline 1.4 - 02 Sep 10.zip" link you get an .eft file?
            That is odd. Are you using some download manager that might be interfering?
            When I click I get the expected "BezierSpline 1.4 - 02 Sep 10.zip" file...
              Scott M
              When I clik on the download link this is what I see.
              File Download
              Do you want to open or save
              Name:BezierSpline 1[1].4-02 Sep 10.1.321C02.efw
              type:unknown File Type,108MB
                108MB! 😲 That is just wrong. You either got a download manager interfering, or a virus/malware. Something is not right there.
                Can you try with a different browser? Or from a different machine?
                  Here's what I found in regard to EFW files:
                  http://knightknetwork.com/2008/01/31/fix-your-efw-file-problems/
                  http://discuss.extremetech.com/forums/thread/1004400807.aspx
                    Scott M
                    Thanks went to the first link and fixed the problem it was my ca settings every thing worked this time thanks again
                    • fredo6F Offline
                      NEW RELEASE 07 Nov 2010
                      This release mainly fixes a performance issue with the contextual menu in models having a huge number of elements, whether you use BezierSpline or not (see discussion at http://forums.sketchucation.com/viewtopic.php?f=180&t=31788#p280335).
                      Download new release at [url=http://forums.sketchucation.com/viewtopic.php?f=323&t=13563&p=100509#p100509:2ep6sbf2]main post[/url:2ep6sbf2]
                      • utilerU Offline
                        utiler
                        Thank you Fredo, Thank you, thank you, thank you.....
                        Just Curious...
                        • fredo6F Offline
                          @oxer said:
                          Hi Fredo!
                          Thanks for the plugin, i have introduced the spanish language to the BezierSpline v1.4 - 07 Nov10, i upload it here for share with all users.
                          Oxer,
                          I have published an update with the Spanish translation integrated.
                          see main post
                          Could please edit the previous post and remove the attachment (actually, there are some issues with the files you posted).
                          • fredo6F Offline
                            NEW RELEASE 1.4e - 10 Nov 2010
                            This release just integrates a Spanish translation kindly provided by Oxer
                            Download new release at main post
                            • OxerO Offline
                              Oxer
                              Hi Fredo!
                              Thanks for the plugin, i have introduced the spanish language to the BezierSpline v1.4 - 07 Nov10.
                                theark
                                Thank for your sharing.Great work. πŸ‘ πŸ‘
                                  poohnut
                                  thankssssss 😍 πŸ˜›
                                    Krypt
                                    Thank you very much for this. πŸ‘
                                    • Q Offline
                                      queti2000
                                      Fredo6,Thank You very much!
                                      • ElibjrE Offline
                                        Elibjr
                                        Thank you very much! 😍
                                          aswas
                                          HThe link for this [Plugin]is not working, is there a reason for this? I would realy like to try the bezier tool.
                                            Hi aswas,
                                            The link does work for me. What do you see in place of the download link to the zip archive under that big, yellow, download label?
                                            • 22
                                            • 23
                                            • 6 / 23
