[Plugin] Skelion (solar, shadows)
102 Posts 45 Posters 203.7k Views 45 Watching
    Juantxo
    Skelion, plugin to insert solar photovoltaics and thermal components
    Skelion plugin gives Sketchup the possibility to insert solar panels very fast and make fast renewable solar energy studies.
    A new free and commercial version have been released. Skelion 5.1.9 (Oct. 2015).
    Shadows projection and one and two axis solar tracking.
    [flash=560,349:3hf6qidy]http://www.youtube.com/v/k_tFwL_h-NE?version=3&hl=en_US[/flash:3hf6qidy]
    Automatic Shadows projections:
    http://skelion.com/images/forum/f1_shadowsprojection.jpg
    Insert components in non planar surafaces
    It can be used to curved sheds and ground mount systems:
    http://skelion.com/images/forum/f1_curved.jpg
    Curved surface
    http://skelion.com/images/forum/f2_curved.jpg
    Solar modules inserted in curved surface
    http://skelion.com/images/forum/f3_ground.jpg
    3D mesh
    http://skelion.com/images/forum/f4_ground.jpg
    Adaptation of Ground mount system to a 3D mesh, all solar components with same orientation.
    http://skelion.com/images/forum/f2_ground.jpg
    You can download the plugin at the web page:
    [DOWNLOAD Skelion 5.1.9 at http://www.skelion.com ](http://skelion.com )
    _
      Krisidious
      how awesome... that's pretty handy.
      By: Kristoff Rand
        CAntonis
        Very Nice
        I am sure it 'll come in handy! Haven 't tested yet but judging from the video seems you did some fine work!
        Thanks.
        CAntonis
        • topic:timeago-later,13 days
          stbovo
          I agree that this tool can prove extremely handy!! Thanks
          Unfortunately it does not work in Mac OSX, I hope for an update soon, that can resolve this issue...
          • topic:timeago-later,8 months
            Juantxo
            A new version has been released with some bugs fixed and a commercial version with more features.
              At the office we use Trend Micro security software and for some reason it blocks the site. It seem to have been black listed.
              Trend Micro Warning
                Juantxo
                http://skelion.netne.net/ is a free hosting. May be it is the reason.
                In the future I'll change the hosting if I'll see interest in the plugin, but not now.
                  Yea - it's a potential problem with shared hosting.
                  I'll have to check it out when I get home. I can't get around Trend's blocking. 😞
                  • W Offline
                    watkins
                    Dear Thomas,
                    Here is a zipped copy I downloaded from the site.
                    Regards,
                    Bob
                    skelion.zip
                    • topic:timeago-later,7 months
                      jwood2012
                      So when I unpack the skelion.zip file the the script files have file extension rbs not rbz
                      consequently the files are not recognized as Ruby scripts by Sketchup. When I change the
                      file extension to rbz sketchup recognizes the file but is unable to install it referring
                      me to the installation instructions which are
                      Download SKELION plugin "skelion.rbz" from the Download Button and save it
                      In Sketchup 8 M2 (last version): Go to Window - Preferences - Extensions - Install Extension
                      Select "skelion.rbz" and accept to install it.
                      Accept license and restart SketchUp
                      Activate SKELION toolbar [View/Toolbars/Skelion]
                      So can anyone help me with the installation?
                        Jim, RBZ is a new file format (with M2) and it is actually a renamed ZIP archive (RBZ = RuByZip). RBS is a scrambled RB ("RuBy") file and you need (and can) not do anything with it.
                        Either simply copy the RBS file into your plugins folder or rename the ZIP file to RBZ and use the new installer. It will know what to do with it (unpack, install etc.)
                          Installing Plugins for SketchUp
                          Update: June 2014 This article was written right before Google sold SketchUp to Trimble. Since then the instructions has changed slightly. In May 2013 SketchUp 2013 was released which included the …
                          Procrastinators Revolt! (www.thomthom.net)
                            Juantxo
                            Sorry jwood2012, you need to clear the cache of your browser to download current version.
                            The problem is you downloaded an older version.
                              Jim
                              Read this: http://forums.sketchucation.com/viewtopic.php?p=315127#p315127
                              which is the best guide to extracting and installing the contents of a .ZIP archive.
                              The .RB/.RBS file-types within a .ZIP or the extracted folder[s] are equivalent in their operation - it's just that you can't 'read' a .RBS file as it's been 'compiled'.
                              IF one day you should download a .RBZ you can install it in v8M2Pro via the menu item Window > Preferences > Extension > 'install archive' button...
                              IF you are brave enough to rename a .ZIP file suffix to .RBZ file you can then install it that way too.
                              Conversely if you have a .RBZ file you can make it into a .ZIP file by changing its suffix, and using the methods outlined for that archive type in the above link...
                              • H Offline
                                Hampson
                                I really like this plugin for SketchUp, had I'd known about it from the very beginning it would have helped me produce models quicker and easier.
                                Anyway, my main question regarding the plugin is how do I get it to maximise the full area when laying down solar panels? For example, I put a 16" offset from the edge of a residential roof. After selecting the now smaller area and when I have plugged in the tilt/azimuth, etc., the panels don't take up all the space available. They seem to work from the middle > out. I had to move them to one side to add an additional 2 rows within the same space.
                                Is this just in the free version or is it deliberately set up like this?
                                  Juantxo
                                  Please, send the model or an image please.
                                  Plugin insert panels in rows, from down to the top, and centering panels of each row from borders.
                                  Actually not maximize space in vertical. User must sometimes modify rows. May be in a future it will be improved.
                                  • H Offline
                                    Hampson
                                    I must have been entering something wrong as it seems to match it now on some of our previous models we've done.
                                    However, I did notice on the following attachment, that it doesn't seem to align itself along the roof edge and thus having an angled system from top left to bottom right.
                                    Judging by the measurements we can get two rows of panels aligned with the rooftop edge, but just wanted to throw this out to you.
                                    Cheers
                                    Not quite aligning itself along the roof edge
                                      Juantxo
                                      Thanks for your post. Some people have problems understanding how to insert panels. So I think it's necessary make a video to teach how to insert solar panels, co-planar or with some tilt, over the roof.
                                      With the plugin you can insert panels like you want, but it's necessary understand the concept of azimuth and tilt relative. This concept it's a bit dark...
                                      Selecting an edge and a face, and using the rights azimuth and tilt relative you can insert the panels in many ways.
                                      We'll try to make a video...
                                      • topic:timeago-later,11 days
                                        Juantxo
                                        Finally, last version of Skelion runs on MAC.
                                        Thanks to Dan Rathbun, driven and thomthom for their help in the task.
                                          driven
                                          Oddly, a friend asked me yesterday if I could draw up some solar panels on his house.
                                          and the mac version arrives...
                                          however, I only get one grey button, with no functionality, and no errors in ruby console.
                                          As I can't see the script, I can't see what paths are expected.
                                          Sketchup installed [via the rbz] into my ~/Library/ path, not not the normal HD/Library path.
                                          The html for the license and one blank toolbar is all I got...
                                          Possibly a paths issue.
                                          does it have any dependencies? or require statements?
                                          • 1 / 6
                                          1 / 6
