    Modulus
    6 Posts 5 Posters 1.5k Views 5 Watching
      parasbuy
      Hi folks.. newbee here... really, really great work on all the plugins! They have been extraordinarily helpful here and I've been more than happy to provide some of the donations. Keep up the good work!!
      Here's a thought for a new plugin that would be very helpful for me....
      I'm looking for a way to model deflection. For example,
      • when a load presses down on the end of a diving board or cantilever beam
      • when one body crashes into another and dents, breaks, or bounces off it
      • or my specific application where I'm designing a medical device clip that deforms and holds onto to something between its two arms. I'm trying to determine if the material I'm looking to use is going to be too brittle and crack, or will flex and work as needed for the patient.
      All of these examples could be analyzed just be changing the Modulus of Elasticity of the material that is being used for the geometric shape that has already been drawn via Sketchup. We can find the Modulus of pretty much every material out there off the web, but we don't have a way of inputting it or incorporating it into our design.
      Finally, a way to record the trajectory of the deflection for a spot on/in the geometric body.
      Thanks again!
      • mitcorbM Offline
        mitcorb
        I don't have the answer, just a thought. Deflection would be somewhat related to dynamics, which suggests Sketchyphysics, a plugin you may know about.
        Even though deflection is really part of Statics and Strength of Materials as engineering subjects, deflection does occur dynamically.
        Just trying to help out.
          parasbuy
          It's cool.. I appreciate the input. I have been looking at SketchyPhysics a lot. It doesn't seem like the latest version is stable yet, so definitely looking forward to installing it when it does... I'm using Mac OSX Snow Leopard. But I also thought SketchyPhysics would enable just the physical motion, such as turning of gears, etc., but assumed it wouldn't account for the actual material being used. Would be awesome if it did!
            pvbuero
            I think it's not an easy task to calculate finite elements and there's a lot of specialized software out there.
            Maybe someday in the future there will be a SU plugin to do such calculations but I didn 't find any tool yet...
            • bomastudioB Offline
              bomastudio
              I will start, as soon as possible, a tool for introduce into SU the FEM ... The project's name is TECLA.
              See here:
              https://sites.google.com/site/teclait/
              • W Offline
                watkins
                Perhaps something from here might help
                http://www.freebyte.com/cad/fea.htm
                The free versions are usually node limited (typically 300), but for small item might be useful.
                Regards,
                Bob
