    [Plugin] Silhouette to Plane v1.1
    32 Posts 17 Posters 32.8k Views 17 Watching
    • JClementsJ Offline
      JClements
      TIG:
      When I click on the script's download button the #SilhoutteTpoPlane.rb downloads. I put the script in the plugins directory of SU8. When I open SU8 I get the following error:
      %(#FF0000)[Error Loading File #SilhouetteToPlane.rb
      no such file to load -- #WorkPlane.rb
      Should #WorkPlane.rb also have been downloaded?
      Regards, John
        @jclements said:
        TIG:
        Regards, John
        John
        IF you had read the notes you'd see that you need 'WorkPlane.rb'... because you must first make and then select a 'WorkPlane' with your other parts you want to project - that's how it knows what plane to project its result on to... ๐Ÿ˜’
        • CAntonisC Offline
          CAntonis
          Working great as always
          Thank U TIG
            Bertier
            sweet
            • H Offline
              Heven7_floor
              Thanks ๐Ÿ˜ , it is great script for mechanic model favour, this plug-in shall mostly advance to project 3d model in STD plan,
              but I found some error happen, when I test by simple cylinder ,which was rotated a bit from origin , there are 1 error time of total 4 time
              I love this script , and hope it could been tune-up ,but I am begin to learn for SU plugin codding , shame to less helping ๐Ÿ˜ณ
              rotate cylinder model testing
                JClements
                TIG, not sure if this is how you intended the script to work or not.
                Using SU8. If I select a bunch of standalone geometry and a couple of groups, only the standalone geometry gets project to the working plane. Each group has to be selected individually to be projected.
                  Everything should project I'll check into it...
                  Do you get the same 'error' with components too ?
                    JClements
                    Hi TIG:
                    Yes, the script works with SU8 and with components. However, the selection set seems to require that it include all of one type of geometry only, either: all loose geometry or all groups or all components.
                    Attached is the test .skp I used.
                    John
                    Silhouette test (SU8, 07 Dec 2010).skp
                    • N Offline
                      nektares
                      this could be extremely useful!! i will try it out later today! thanks Tig!
                        gnlmrc60b22f205v
                        With SU2018 cause the SU crash.
                        • I Offline
                          iandefazio
                          Any plan to make this work in newer versions? Anyone know of an alternative? I could use this on a daily basis for my work.
                            This is an ancient free plugin...
                            What error rep0rts do you get in the Ruby Console when using it ?
                            If it's something simple I could look at a fix - if it's more complex then... who's paying ? ๐Ÿ˜‰
                            PS:
                            I just tested it [with WorkPlane] in v2020 and it seemed to work OK ?
                            What's the issues you get ?
                            • 2 / 2
