    [Plugin] Silhouette to Plane v1.1
    32 Posts 17 Posters 35.1k Views 17 Watching
    • CAntonisC Offline
      CAntonis
      Working great as always
      Thank U TIG
        Bertier
        sweet
        • H Offline
          Heven7_floor
          Thanks 😍 , it is great script for mechanic model favour, this plug-in shall mostly advance to project 3d model in STD plan,
          but I found some error happen, when I test by simple cylinder ,which was rotated a bit from origin , there are 1 error time of total 4 time
          I love this script , and hope it could been tune-up ,but I am begin to learn for SU plugin codding , shame to less helping 😳
          rotate cylinder model testing
          • JClementsJ Offline
            JClements
            TIG, not sure if this is how you intended the script to work or not.
            Using SU8. If I select a bunch of standalone geometry and a couple of groups, only the standalone geometry gets project to the working plane. Each group has to be selected individually to be projected.
              Everything should project I'll check into it...
              Do you get the same 'error' with components too ?
                JClements
                Hi TIG:
                Yes, the script works with SU8 and with components. However, the selection set seems to require that it include all of one type of geometry only, either: all loose geometry or all groups or all components.
                Attached is the test .skp I used.
                John
                Silhouette test (SU8, 07 Dec 2010).skp
                • N Offline
                  nektares
                  this could be extremely useful!! i will try it out later today! thanks Tig!
                    gnlmrc60b22f205v
                    With SU2018 cause the SU crash.
                    • I Offline
                      iandefazio
                      Any plan to make this work in newer versions? Anyone know of an alternative? I could use this on a daily basis for my work.
                        This is an ancient free plugin...
                        What error rep0rts do you get in the Ruby Console when using it ?
                        If it's something simple I could look at a fix - if it's more complex then... who's paying ? 😉
                        PS:
                        I just tested it [with WorkPlane] in v2020 and it seemed to work OK ?
                        What's the issues you get ?
                        • 2 / 2
