    [Req]Align XYZ
    11 Posts 5 Posters 1.0k Views 5 Watching
      sus4
      m1
      First, there are spheres
      m2
      Select the polygon
      m3
      Y-axis aligned
      Next. there are bars
      b1
      Different lengths
      Selectใ€€multi polygon
      b2
      Y-axis aligned
      Polygons will be alignment based on the first
      I hope ๐Ÿ˜†
      Thank.
      • PixeroP Offline
        Pixero
        You can try my Align script that comes in two flavors:
        Either my original version (which has some more options than the one below):
        http://www.pixero.com/files/jsAlign.zip
        ...or Cad Fathers toolbar version of my script that is quick and easy to use for most things:
        http://forums.sketchucation.com/viewtopic.php?t=20233
          sus4
          wow..so nice plugin ๐Ÿ˜ณ ๐Ÿ˜ณ
          • ntxdaveN Offline
            ntxdave
            I am having some minor problems when the jsAlign plugin loads with SU 2014
            Here is a screen capture of the error message I get.
            Press F1...thank me later
            • TIGT Online
              Line #60 of the jsAlign.rb file reads:
              results = inputbox (prompts, values, enums, "Align Settings")
              If you open it in Notepad and edit it to:
              results = inputbox(prompts, values, enums, "Align Settings")
              Then it'll work in v2014 too...
              Ruby v2.0 is more picky about poor syntax like having a space between the method and the opening ( around its arguments...
              I ought to leave it to the original author to correct it and republish.
              [I'll help if Jan/Pixero asks nicely ๐Ÿ˜‰ ]
              • PixeroP Offline
                Pixero
                Does this help?
                Pleease!
                • TIGT Online
                  OK, I'll update the PluginStore entry - but you fix your site's version from that - I'll call it v1.6...
                  • TIGT Online
                    SketchUp v2014 compatible jsAlign v1.6 is now available in the PluginStore http://sketchucation.com/pluginstore?pln=jsAlign
                    If you are using it in conjunction with a 'toolbar' install it only after the toolbar is installed, to ensure you get the latest version.
                    • PixeroP Offline
                      Pixero
                      • TIGT Online
                        You grovel so well ๐Ÿ˜‰
                          Align & distribute by Sdmitch ? ๐Ÿ˜„
