    Ruby - find a model's maximum height
    3 Posts 2 Posters 365 Views 2 Watching
    • T
      Thaje
      Hello, I have searched google tirelessly for the past two hours and have not found anything remotely like I am trying to do, so I appeal to the great minds of sketchucation.
      I started ruby programming tonight so know very little. I am trying to create a ruby script which finds and saves the maximum height, length, and width of a complicated model (eg. The statue of liberty, or something) to a text file. Sounds simple, and I think it is, but I have no idea were to start.
      If someone could point me in the right direction I would be very grateful.
      Thaje
        =begin
        (c) TIG 2010
        Copy/Paste code into ../Plugins/modelXYZ.rb
        Usage; type 'modelXYZ' in Ruby Console
        =end
        require 'sketchup.rb'
        def modelXYZ()
          model = Sketchup.active_model
          bb = model.bounds
          ### NB; 'bounds' xyz values do NOT follow model axes logic
          x = bb.width.to_s
          y = bb.height.to_s
          z = bb.depth.to_s
          ### message in Ruby Console
          puts("X = " + x)
          puts("Y = " + y)
          puts("Z = " + z)
          ### text into File
          if model.path != "" ### SKP was saved
            filepath = File.dirname(model.path)
            filename = model.title + "_XYZ.txt"
            file = File.join(filepath, filename).tr("\\","/")
            f = File.new(file, "w")
            f.puts(x)
            f.puts(y)
            f.puts(z)
            f.close
            ### Tip; to make a 'spreadsheet' file change suffix to ".csv" or ".tsv"
            ### and then 'puts' one line only, thus; f.puts(x+","+y+","+z)
            puts("XYZ values written to file;")
            puts(file)
          else ### SKP is not yet saved
            UI.beep
            puts("Save this SKP to write these XYZ values to a file...")
          end#if
          puts()
        end#def
        • T
          Thaje
          @tig said:
          =begin
          > (c) TIG 2010
          > =end
          > def modelXYZ()
          >   bb = model.bounds
          >   x = bb.width.to_s
          >   y = bb.height.to_s
          >   z = bb.depth.to_s
          >   puts("X = " + x)
          >   puts("Y = " + y)
          >   puts("Z = " + z)
          >   ### text into File
          >     f.puts(x)
          >     f.puts(y)
          >     f.puts(z)
          >     f.close
          >     puts(file)
          >     UI.beep
          >   end#if
          >   puts()
          > end#def
          Thanks man, this looks exactly like what I'm after. Now I just have to work through and understand it...
