    [code] Win32 Moving/Showing/Hiding Toolbars and Dialogs
    91 Posts 8 Posters 22.6k Views 8 Watching
      @jim said:
      Yes, but in that case how would any program know which one the user meant?
      If you'd created the window then you'd get the handle from there. (Would be nice if the API could expose the handles in the Ruby API)
      I suppose that if it is possible to get an array of matching windows one could filter out the window you want by checking if one of them is the active - if it's the active SU window you want. (Assuming SU is the currently active window)
      Or maybe by Z-Order? Assuming that the top most is the most recent - again if that is what you want...
        In most cases you'd get the window the user is working on, right?
        So how about
        GetForegroundWindow - then, in case one of the toolbars or webdialogs are the active window, iterate down the hierarchy using GetParent - checking for matching window title?
        • JD HillJ Offline
          JD Hill
          If you have an API which supports EnumWindows, you can use GetProcessId and GetWindowThreadProcessId to filter on windows in the current process.
          Developer - Bella Render
            @jim said:
            But I didn't see a lag when applying the ToolWIndow class immediately after .showing the webdialog.
            You got a snippet of how you applied the ToolWindow style?
              'N' instead of 'L'?
              hm.. I'm a wee bit confused to exactly when to use what type...
                Jim
                From the pick-axe book:
                Strings n'' and l'' represent numbers,
                i'' represent integers, p'' represents pointers to data stored in a string
                ``v'' represents a void type (used for export parameters only).
                These strings are case-insensitive.
                So I guessed you just use the type that is the best match to the API call parameters. In other words, your guess is as good as mine.
                  is N === L ? "Number" vs Integer? Number == Float?
                    I got lots of errors when I tried the Toolwindow snippet in the first post. Seems that a few constants where missing from the snippet.
                    I found them though, and I tried another way to get the window handle.
                    <span class="syntaxdefault"><br /></span><span class="syntaxcomment">#&nbsp;http://ruby-doc.org/docs/ProgrammingRuby/html/lib_windows.html#Win32API.new<br /><br /></span><span class="syntaxkeyword">require&nbsp;</span><span class="syntaxstring">'Win32API'<br /><br /></span><span class="syntaxdefault">WS_CAPTION&nbsp;&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">0x00C00000<br />WS_EX_TOOLWINDOW&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">0x00000080<br /><br />GWL_STYLE&nbsp;&nbsp;&nbsp;</span><span class="syntaxkeyword">=&nbsp;-</span><span class="syntaxdefault">16<br />GWL_EXSTYLE&nbsp;</span><span class="syntaxkeyword">=&nbsp;-</span><span class="syntaxdefault">20<br /><br /></span><span class="syntaxcomment">#&nbsp;SetWindowPos()&nbsp;flags<br /></span><span class="syntaxdefault">SWP_NOSIZE&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">0x0001<br />SWP_NOMOVE&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">0x0002<br />SWP_DRAWFRAME&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">0x0020<br />SWP_FRAMECHANGED&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">0x0020<br />SWP_NOREPOSITION&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">0x0200<br /><br /></span><span class="syntaxcomment">#&nbsp;Windows&nbsp;Functions<br />#FindWindow&nbsp;&nbsp;&nbsp;&nbsp;=&nbsp;Win32API.new("user32.dll"&nbsp;,&nbsp;"FindWindow"&nbsp;&nbsp;&nbsp;,&nbsp;'PP'&nbsp;,&nbsp;'L')<br />#FindWindowEx&nbsp;&nbsp;=&nbsp;Win32API.new("user32.dll",&nbsp;"FindWindowEx"&nbsp;,&nbsp;'LLPP',&nbsp;'L')<br /></span><span class="syntaxdefault">SetWindowPos&nbsp;&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">Win32API</span><span class="syntaxkeyword">.new(</span><span class="syntaxstring">"user32.dll"&nbsp;</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxstring">"SetWindowPos"&nbsp;</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxstring">'LLIIIII'</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxstring">'I'</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">SetWindowLong&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">Win32API</span><span class="syntaxkeyword">.new(</span><span class="syntaxstring">"user32.dll"&nbsp;</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxstring">"SetWindowLong"</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxstring">'LIL'</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxstring">'L'</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">GetWindowLong&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">Win32API</span><span class="syntaxkeyword">.new(</span><span class="syntaxstring">"user32.dll"&nbsp;</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxstring">"GetWindowLong"</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxstring">'LI'&nbsp;</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxstring">'L'</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">GetActiveWindow&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">Win32API</span><span class="syntaxkeyword">.new(</span><span class="syntaxstring">"user32.dll"</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxstring">"GetActiveWindow"</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxstring">''</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxstring">'L'</span><span class="syntaxkeyword">)<br /></span><span class="syntaxcomment">#GetForegroundWindow&nbsp;=&nbsp;Win32API.new("user32.dll",&nbsp;"GetForegroundWindow",&nbsp;'',&nbsp;'L')<br /></span><span class="syntaxdefault">GetWindowText&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">Win32API</span><span class="syntaxkeyword">.new(</span><span class="syntaxstring">"user32.dll"</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxstring">"GetWindowText"</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxstring">'LPI'</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxstring">'I'</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">GetWindowTextLength&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">Win32API</span><span class="syntaxkeyword">.new(</span><span class="syntaxstring">"user32.dll"</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxstring">"GetWindowTextLength"</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxstring">'L'</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxstring">'I'</span><span class="syntaxkeyword">)<br /><br /><br /></span><span class="syntaxdefault">def&nbsp;create_toolbar_window<br />&nbsp;&nbsp;window&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">UI</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">WebDialog</span><span class="syntaxkeyword">.new(</span><span class="syntaxstring">'My&nbsp;Test&nbsp;Window'</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">false</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;</span><span class="syntaxdefault">window</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">set_html</span><span class="syntaxkeyword">(</span><span class="syntaxstring">'<br />&nbsp;&nbsp;<html><br />&nbsp;&nbsp;<head><br />&nbsp;&nbsp;<style&nbsp;type="text/css"><br />&nbsp;&nbsp;&nbsp;&nbsp;html&nbsp;{<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;font;&nbsp;caption;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;background;&nbsp;ButtonFace;<br />&nbsp;&nbsp;&nbsp;&nbsp;}<br />&nbsp;&nbsp;&nbsp;&nbsp;hr&nbsp;{<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;border;&nbsp;none;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;border-top;&nbsp;1px&nbsp;solid&nbsp;ThreeDShadow;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;border-bottom;&nbsp;1px&nbsp;solid&nbsp;ThreeDHighlight;<br />&nbsp;&nbsp;&nbsp;&nbsp;}<br />&nbsp;&nbsp;</style><br />&nbsp;&nbsp;</head><br />&nbsp;&nbsp;<body><br />&nbsp;&nbsp;&nbsp;&nbsp;<b>My&nbsp;very&nbsp;own&nbsp;window</b><br />&nbsp;&nbsp;&nbsp;&nbsp;<hr&nbsp;/><br />&nbsp;&nbsp;&nbsp;&nbsp;Neato!<br />&nbsp;&nbsp;</body><br />&nbsp;&nbsp;</html><br />&nbsp;&nbsp;'</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;</span><span class="syntaxdefault">window</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">show<br />&nbsp;&nbsp;<br />&nbsp;&nbsp;</span><span class="syntaxcomment">#&nbsp;Find&nbsp;the&nbsp;new&nbsp;window&nbsp;-&nbsp;should&nbsp;get&nbsp;it&nbsp;by&nbsp;GetActiveWindow&nbsp;since&nbsp;wd.show&nbsp;brings<br />&nbsp;&nbsp;#&nbsp;the&nbsp;window&nbsp;to&nbsp;front.<br />&nbsp;&nbsp;</span><span class="syntaxdefault">hwnd&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">GetActiveWindow</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">call<br />&nbsp;&nbsp;</span><span class="syntaxcomment">#hwnd&nbsp;=&nbsp;GetForegroundWindow.call<br />&nbsp;&nbsp;#hwnd&nbsp;=&nbsp;FindWindow.call(DIALOG_CLASS,&nbsp;window_title)<br />&nbsp;&nbsp;</span><span class="syntaxdefault">p&nbsp;hwnd<br /><br />&nbsp;&nbsp;puts&nbsp;</span><span class="syntaxstring">'Check&nbsp;Window&nbsp;Text'<br />&nbsp;&nbsp;</span><span class="syntaxdefault">buf_len&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">GetWindowTextLength</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">call</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">hwnd</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;</span><span class="syntaxdefault">str&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxstring">'&nbsp;'&nbsp;</span><span class="syntaxkeyword">*&nbsp;(</span><span class="syntaxdefault">buf_len&nbsp;</span><span class="syntaxkeyword">+&nbsp;</span><span class="syntaxdefault">1</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;</span><span class="syntaxdefault">p&nbsp;GetWindowText</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">call</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">hwnd</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">str</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">str</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">length</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;</span><span class="syntaxdefault">p&nbsp;str<br />&nbsp;&nbsp;p&nbsp;str</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">strip<br />&nbsp;&nbsp;<br />&nbsp;&nbsp;</span><span class="syntaxcomment">#&nbsp;Change&nbsp;Window&nbsp;Style<br />&nbsp;&nbsp;</span><span class="syntaxdefault">style&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">GetWindowLong</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">call</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">hwnd</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">GWL_EXSTYLE</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;</span><span class="syntaxdefault">p&nbsp;style<br />&nbsp;&nbsp;p&nbsp;SetWindowLong</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">call</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">hwnd</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">GWL_EXSTYLE</span><span class="syntaxkeyword">,&nbsp;&nbsp;</span><span class="syntaxdefault">style&nbsp;</span><span class="syntaxkeyword">|&nbsp;</span><span class="syntaxdefault">WS_EX_TOOLWINDOW</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;</span><span class="syntaxdefault">p&nbsp;SetWindowPos</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">call</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">hwnd</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">0</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">0</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">0</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">0</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">0</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">SWP_FRAMECHANGED</span><span class="syntaxkeyword">|</span><span class="syntaxdefault">SWP_NOSIZE</span><span class="syntaxkeyword">|</span><span class="syntaxdefault">SWP_NOMOVE</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">end<br /></span>
                    The code needs error checking and such.
                    (maybe it's because I'm not error checking yet that I some times experience that the window automatically closes after a few seconds. it has happened only sporadically...)
                    win32.rb
                      Removing the maximize and minimize button: (Addition to the code in my previous post)
                      <span class="syntaxdefault"><br />&nbsp;&nbsp;WS_MAXIMIZEBOX&nbsp;</span><span class="syntaxkeyword">=&nbsp;&nbsp;</span><span class="syntaxdefault">0x10000<br />&nbsp;&nbsp;WS_MINIMIZEBOX&nbsp;</span><span class="syntaxkeyword">=&nbsp;&nbsp;</span><span class="syntaxdefault">0x20000<br />&nbsp;&nbsp;WS_SIZEBOX&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxkeyword">=&nbsp;&nbsp;</span><span class="syntaxdefault">0x40000<br /><br />&nbsp;&nbsp;</span><span class="syntaxcomment">#&nbsp;Remove&nbsp;Buttons<br />&nbsp;&nbsp;#&nbsp;http://support.microsoft.com/kb/137033<br />&nbsp;&nbsp;</span><span class="syntaxdefault">style&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">GetWindowLong</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">call</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">hwnd</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">GWL_STYLE</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;</span><span class="syntaxdefault">p&nbsp;style<br />&nbsp;&nbsp;style&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">style&nbsp;</span><span class="syntaxkeyword">&&nbsp;~</span><span class="syntaxdefault">WS_MINIMIZEBOX<br />&nbsp;&nbsp;style&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">style&nbsp;</span><span class="syntaxkeyword">&&nbsp;~</span><span class="syntaxdefault">WS_MAXIMIZEBOX<br />&nbsp;&nbsp;</span><span class="syntaxcomment">#style&nbsp;=&nbsp;style&nbsp;&&nbsp;~WS_SIZEBOX<br />&nbsp;&nbsp;</span><span class="syntaxdefault">p&nbsp;SetWindowLong</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">call</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">hwnd</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">GWL_STYLE</span><span class="syntaxkeyword">,&nbsp;&nbsp;</span><span class="syntaxdefault">style</span><span class="syntaxkeyword">)<br />&nbsp;</span><span class="syntaxdefault"></span>
                      This prevents the window from maximising when double-clicking. Seems to introduce some frame flicker.
                      Can GWL_STYLE and GWL_EXSTYLE changes be combines into one call?
                        As implemented in TT_Lib2 with error checking:
                        <span class="syntaxdefault"><br />  </span><span class="syntaxcomment"># Call after webdialog.show to change the window into a toolwindow. Spesify the<br /></span><span class="syntaxdefault">  </span><span class="syntaxcomment"># window title so the method can verify it changes the correct window.<br /></span><span class="syntaxdefault">  </span><span class="syntaxcomment">#<br /></span><span class="syntaxdefault">  </span><span class="syntaxcomment"># @param [String] window_title<br /></span><span class="syntaxdefault">  </span><span class="syntaxcomment">#<br /></span><span class="syntaxdefault">  </span><span class="syntaxcomment"># @return [Nil]<br /></span><span class="syntaxdefault">  </span><span class="syntaxcomment"># @since 2.5.0<br /></span><span class="syntaxdefault">  def self</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">make_toolwindow_frame</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">window_title</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">    </span><span class="syntaxcomment"># Retrieves the window handle to the active window attached to the calling<br /></span><span class="syntaxdefault">    </span><span class="syntaxcomment"># thread's message queue. <br /></span><span class="syntaxdefault">    hwnd </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> GetActiveWindow</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">call<br />    return nil if hwnd</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">nil</span><span class="syntaxkeyword">?<br /></span><span class="syntaxdefault">    <br />    </span><span class="syntaxcomment"># Verify window text as extra security to ensure it's the correct window.<br /></span><span class="syntaxdefault">    buf_len </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> GetWindowTextLength</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">call</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">hwnd</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">    return nil if buf_len </span><span class="syntaxkeyword">==</span><span class="syntaxdefault"> 0<br />    <br />    str </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> </span><span class="syntaxstring">' '</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">*</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">(</span><span class="syntaxdefault">buf_len </span><span class="syntaxkeyword">+</span><span class="syntaxdefault"> 1</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">    result </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> GetWindowText</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">call</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">hwnd</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> str</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> str</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">length</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">    return nil if result </span><span class="syntaxkeyword">==</span><span class="syntaxdefault"> 0<br />    <br />    return nil unless str</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">strip </span><span class="syntaxkeyword">==</span><span class="syntaxdefault"> window_title</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">strip<br />    <br />    </span><span class="syntaxcomment"># Set frame to Toolwindow<br /></span><span class="syntaxdefault">    style </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> GetWindowLong</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">call</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">hwnd</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> GWL_EXSTYLE</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">    return nil if style </span><span class="syntaxkeyword">==</span><span class="syntaxdefault"> 0<br />    <br />    result </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> SetWindowLong</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">call</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">hwnd</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> GWL_EXSTYLE</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> style </span><span class="syntaxkeyword">|</span><span class="syntaxdefault"> WS_EX_TOOLWINDOW</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">    return nil if result </span><span class="syntaxkeyword">==</span><span class="syntaxdefault"> 0<br />    <br />    </span><span class="syntaxcomment"># Remove and disable minimze and maximize<br /></span><span class="syntaxdefault">    </span><span class="syntaxcomment"># http://support.microsoft.com/kb/137033<br /></span><span class="syntaxdefault">    style </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> GetWindowLong</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">call</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">hwnd</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> GWL_STYLE</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">    return nil if style </span><span class="syntaxkeyword">==</span><span class="syntaxdefault"> 0<br />    <br />    style </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> style </span><span class="syntaxkeyword">&</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">~</span><span class="syntaxdefault">WS_MINIMIZEBOX<br />    style </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> style </span><span class="syntaxkeyword">&</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">~</span><span class="syntaxdefault">WS_MAXIMIZEBOX<br />    result </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> SetWindowLong</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">call</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">hwnd</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> GWL_STYLE</span><span class="syntaxkeyword">,</span><span class="syntaxdefault">  style</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">    return nil if result </span><span class="syntaxkeyword">==</span><span class="syntaxdefault"> 0<br />    <br />    </span><span class="syntaxcomment"># Refresh the window frame<br /></span><span class="syntaxdefault">    result </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> SetWindowPos</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">call</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">hwnd</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> 0</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> 0</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> 0</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> 0</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> 0</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> SWP_FRAMECHANGED</span><span class="syntaxkeyword">|</span><span class="syntaxdefault">SWP_NOSIZE</span><span class="syntaxkeyword">|</span><span class="syntaxdefault">SWP_NOMOVE</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">    result </span><span class="syntaxkeyword">!=</span><span class="syntaxdefault"> 0<br />  end<br /></span>
                          Can we have code blocks that expand similar to when you click on images?
                            Pout
                            What are possible advantages of using toolwindows instead of webdialogs?
                            And is the communication between SU and the toolwindow still done in the same way?
                              It's not different windows - it's just different window frames. The code examples changes the window frame of webdialogs to toolwindows - which takes up less space and look neater.
                                Jim
                                Thanks for following (and cleaning) up the example. Will some this be getting into TT_Lib at some point?
                                  TT_Lib2, yes.
                                  I already got a wrapper to create toolwindows.
                                  <span class="syntaxdefault"><br />&nbsp;&nbsp;&nbsp;&nbsp;def&nbsp;show_toolbar<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;options&nbsp;</span><span class="syntaxkeyword">=&nbsp;{<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;;</span><span class="syntaxdefault">title&nbsp;</span><span class="syntaxkeyword">=>&nbsp;</span><span class="syntaxstring">'Bezier&nbsp;Surface'</span><span class="syntaxkeyword">,<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;;</span><span class="syntaxdefault">pref_key&nbsp;</span><span class="syntaxkeyword">=>&nbsp;</span><span class="syntaxstring">"#{TT;;Plugins;;BPatch;;ID}_Toolbar"</span><span class="syntaxkeyword">,<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;;</span><span class="syntaxdefault">width&nbsp;</span><span class="syntaxkeyword">=>&nbsp;</span><span class="syntaxdefault">128</span><span class="syntaxkeyword">,<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;;</span><span class="syntaxdefault">height&nbsp;</span><span class="syntaxkeyword">=>&nbsp;</span><span class="syntaxdefault">52</span><span class="syntaxkeyword">,<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;;</span><span class="syntaxdefault">resizable&nbsp;</span><span class="syntaxkeyword">=>&nbsp;</span><span class="syntaxdefault">false</span><span class="syntaxkeyword">,<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;;</span><span class="syntaxdefault">scrollable&nbsp;</span><span class="syntaxkeyword">=>&nbsp;</span><span class="syntaxdefault">false<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxkeyword">}<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;@</span><span class="syntaxdefault">toolbar&nbsp;</span><span class="syntaxkeyword">||=&nbsp;</span><span class="syntaxdefault">TT</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">GUI</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">ToolWindow</span><span class="syntaxkeyword">.new(&nbsp;</span><span class="syntaxdefault">options&nbsp;</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;@</span><span class="syntaxdefault">toolbar</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">show_window<br />&nbsp;&nbsp;&nbsp;&nbsp;end<br /></span>
                                  (Extract from a work in progress project.)
                                    Wonder if one can hook into windows like this under OSX...
                                      Jim
                                      For some windows, if it is a Toolwindow it will not show up in the Alt-Tab list. But this is normal for SketchUp dialog windows anyway, so there should be no difference there.
                                        Jim
                                        It's just getting GC'd. window is a local variable referencing the WebDialog, and the variable no longer exists after the method exits. Since the WebDialog no longer has any references, it is GC'd.
                                        Maybe - the "styles" are just bits but at different offset (one is -16, the other -20). If you meant is there a win32api function for setting both simultaneously then I don't know.
                                        Hehe, the php highlighter work OK on Ruby. 👍
                                          Oh... that's a gotcha I didn't think of. You need to keep a reference to the WD for the duration of its lifespan.
                                          The thing is - today, I don't really see any lag... 😕 😒
                                          What's nice about having toolwindows is that now I can make my custom toolbar. 😄
                                            Just came across a nice API call that will be useful for creating webdialog toolbars:
                                            http://social.msdn.microsoft.com/forums/en/csharpgeneral/thread/e7fef568-2c0b-41eb-9785-304f84d03819/#bf79c87e-ef49-456f-a485-aa767d841d20
                                            One can use WS_EX_NOACTIVATE to prevent a window from catching focus - but from what I understand it'll still allow interaction events. I'll try it out as soon as I get home.
                                            • 2 / 5
