    [code] Win32 Moving/Showing/Hiding Toolbars and Dialogs
    91 Posts 8 Posters 20.8k Views 8 Watching
      hm....
      Are you receiving the data in the correct data type?
        Jim
        Turns out the negative return value is not a problem - I just wasn't using it right.
          Jim
          @thomthom said:
          Maybe the .show event of the dialog triggers as it's displayed? But I'm not sure if it wait for the HTML - which you do not want - as that will lag.
          And can you do anything before calling show? You need a handle to the window - how are you getting that at the moment?
          Using FindWindow - which is a basic search by window name and class.
            Jim
            For a WebDialog, I couldn't find a handle until it was shown. I used EnumWindows and EnumChildWidows to locate it.
            But I didn't see a lag when applying the ToolWIndow class immediately after .showing the webdialog.
              Neat! πŸ˜„
                Jim
                The Win32API.so file does not support the use of callbacks needed by EnumWindows and EnumChildWindows. So I have had to move to win32/api.so, which does support callbacks. But this will also allow more interesting things to be done, such as finding resizing Sketchup by its drawing area, and sending values to the Measurements box via a plugin.
                  When there is multiple SketchUp windows open - how do you find the one you want?
                    Jim
                    Hopefully, the window titles are different. If not, I'm not sure.
                      So you look for windows with "<filename> - SketchUp (Pro)"
                        Jim
                        Too fast... here's how to get the exact name. (But is_pro? is for windows 7+)
                        def su_window_name
                            pro = Sketchup.is_pro? ? " Pro" ; ""
                            if ((title = Sketchup.active_model.title).empty?)
                                return ("Untitled - SketchUp" + pro)
                            else
                                return (title += ".skp - SketchUp" + pro)
                          But when there is two untitled windows there could be problems?
                            Jim
                            Yes, but in that case how would any program know which one the user meant?
                            You can find all of the matching windows. It's just hard to know which the user meant to use.
                              If you'd created the window then you'd get the handle from there. (Would be nice if the API could expose the handles in the Ruby API)
                              I suppose that if it is possible to get an array of matching windows one could filter out the window you want by checking if one of them is the active - if it's the active SU window you want. (Assuming SU is the currently active window)
                              Or maybe by Z-Order? Assuming that the top most is the most recent - again if that is what you want...
                                In most cases you'd get the window the user is working on, right?
                                So how about
                                GetForegroundWindow - then, in case one of the toolbars or webdialogs are the active window, iterate down the hierarchy using GetParent - checking for matching window title?
                                • JD HillJ Offline
                                  JD Hill
                                  If you have an API which supports EnumWindows, you can use GetProcessId and GetWindowThreadProcessId to filter on windows in the current process.
                                  Developer - Bella Render
                                    You got a snippet of how you applied the ToolWindow style?
                                      'N' instead of 'L'?
                                      hm.. I'm a wee bit confused to exactly when to use what type...
                                        Jim
                                        From the pick-axe book:
                                        Strings n'' and l'' represent numbers,
                                        i'' represent integers, p'' represents pointers to data stored in a string
                                        ``v'' represents a void type (used for export parameters only).
                                        These strings are case-insensitive.
                                        So I guessed you just use the type that is the best match to the API call parameters. In other words, your guess is as good as mine.
                                          is N === L ? "Number" vs Integer? Number == Float?
                                            I got lots of errors when I tried the Toolwindow snippet in the first post. Seems that a few constants where missing from the snippet.
                                            I found them though, and I tried another way to get the window handle.
                                            <span class="syntaxdefault"><br /></span><span class="syntaxcomment">#&nbsp;http://ruby-doc.org/docs/ProgrammingRuby/html/lib_windows.html#Win32API.new<br /><br /></span><span class="syntaxkeyword">require&nbsp;</span><span class="syntaxstring">'Win32API'<br /><br /></span><span class="syntaxdefault">WS_CAPTION&nbsp;&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">0x00C00000<br />WS_EX_TOOLWINDOW&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">0x00000080<br /><br />GWL_STYLE&nbsp;&nbsp;&nbsp;</span><span class="syntaxkeyword">=&nbsp;-</span><span class="syntaxdefault">16<br />GWL_EXSTYLE&nbsp;</span><span class="syntaxkeyword">=&nbsp;-</span><span class="syntaxdefault">20<br /><br /></span><span class="syntaxcomment">#&nbsp;SetWindowPos()&nbsp;flags<br /></span><span class="syntaxdefault">SWP_NOSIZE&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">0x0001<br />SWP_NOMOVE&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">0x0002<br />SWP_DRAWFRAME&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">0x0020<br />SWP_FRAMECHANGED&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">0x0020<br />SWP_NOREPOSITION&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">0x0200<br /><br /></span><span class="syntaxcomment">#&nbsp;Windows&nbsp;Functions<br />#FindWindow&nbsp;&nbsp;&nbsp;&nbsp;=&nbsp;Win32API.new("user32.dll"&nbsp;,&nbsp;"FindWindow"&nbsp;&nbsp;&nbsp;,&nbsp;'PP'&nbsp;,&nbsp;'L')<br />#FindWindowEx&nbsp;&nbsp;=&nbsp;Win32API.new("user32.dll",&nbsp;"FindWindowEx"&nbsp;,&nbsp;'LLPP',&nbsp;'L')<br /></span><span class="syntaxdefault">SetWindowPos&nbsp;&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">Win32API</span><span class="syntaxkeyword">.new(</span><span class="syntaxstring">"user32.dll"&nbsp;</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxstring">"SetWindowPos"&nbsp;</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxstring">'LLIIIII'</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxstring">'I'</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">SetWindowLong&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">Win32API</span><span class="syntaxkeyword">.new(</span><span class="syntaxstring">"user32.dll"&nbsp;</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxstring">"SetWindowLong"</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxstring">'LIL'</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxstring">'L'</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">GetWindowLong&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">Win32API</span><span class="syntaxkeyword">.new(</span><span class="syntaxstring">"user32.dll"&nbsp;</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxstring">"GetWindowLong"</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxstring">'LI'&nbsp;</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxstring">'L'</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">GetActiveWindow&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">Win32API</span><span class="syntaxkeyword">.new(</span><span class="syntaxstring">"user32.dll"</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxstring">"GetActiveWindow"</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxstring">''</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxstring">'L'</span><span class="syntaxkeyword">)<br /></span><span class="syntaxcomment">#GetForegroundWindow&nbsp;=&nbsp;Win32API.new("user32.dll",&nbsp;"GetForegroundWindow",&nbsp;'',&nbsp;'L')<br /></span><span class="syntaxdefault">GetWindowText&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">Win32API</span><span class="syntaxkeyword">.new(</span><span class="syntaxstring">"user32.dll"</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxstring">"GetWindowText"</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxstring">'LPI'</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxstring">'I'</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">GetWindowTextLength&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">Win32API</span><span class="syntaxkeyword">.new(</span><span class="syntaxstring">"user32.dll"</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxstring">"GetWindowTextLength"</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxstring">'L'</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxstring">'I'</span><span class="syntaxkeyword">)<br /><br /><br /></span><span class="syntaxdefault">def&nbsp;create_toolbar_window<br />&nbsp;&nbsp;window&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">UI</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">WebDialog</span><span class="syntaxkeyword">.new(</span><span class="syntaxstring">'My&nbsp;Test&nbsp;Window'</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">false</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;</span><span class="syntaxdefault">window</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">set_html</span><span class="syntaxkeyword">(</span><span class="syntaxstring">'<br />&nbsp;&nbsp;<html><br />&nbsp;&nbsp;<head><br />&nbsp;&nbsp;<style&nbsp;type="text/css"><br />&nbsp;&nbsp;&nbsp;&nbsp;html&nbsp;{<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;font;&nbsp;caption;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;background;&nbsp;ButtonFace;<br />&nbsp;&nbsp;&nbsp;&nbsp;}<br />&nbsp;&nbsp;&nbsp;&nbsp;hr&nbsp;{<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;border;&nbsp;none;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;border-top;&nbsp;1px&nbsp;solid&nbsp;ThreeDShadow;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;border-bottom;&nbsp;1px&nbsp;solid&nbsp;ThreeDHighlight;<br />&nbsp;&nbsp;&nbsp;&nbsp;}<br />&nbsp;&nbsp;</style><br />&nbsp;&nbsp;</head><br />&nbsp;&nbsp;<body><br />&nbsp;&nbsp;&nbsp;&nbsp;<b>My&nbsp;very&nbsp;own&nbsp;window</b><br />&nbsp;&nbsp;&nbsp;&nbsp;<hr&nbsp;/><br />&nbsp;&nbsp;&nbsp;&nbsp;Neato!<br />&nbsp;&nbsp;</body><br />&nbsp;&nbsp;</html><br />&nbsp;&nbsp;'</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;</span><span class="syntaxdefault">window</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">show<br />&nbsp;&nbsp;<br />&nbsp;&nbsp;</span><span class="syntaxcomment">#&nbsp;Find&nbsp;the&nbsp;new&nbsp;window&nbsp;-&nbsp;should&nbsp;get&nbsp;it&nbsp;by&nbsp;GetActiveWindow&nbsp;since&nbsp;wd.show&nbsp;brings<br />&nbsp;&nbsp;#&nbsp;the&nbsp;window&nbsp;to&nbsp;front.<br />&nbsp;&nbsp;</span><span class="syntaxdefault">hwnd&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">GetActiveWindow</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">call<br />&nbsp;&nbsp;</span><span class="syntaxcomment">#hwnd&nbsp;=&nbsp;GetForegroundWindow.call<br />&nbsp;&nbsp;#hwnd&nbsp;=&nbsp;FindWindow.call(DIALOG_CLASS,&nbsp;window_title)<br />&nbsp;&nbsp;</span><span class="syntaxdefault">p&nbsp;hwnd<br /><br />&nbsp;&nbsp;puts&nbsp;</span><span class="syntaxstring">'Check&nbsp;Window&nbsp;Text'<br />&nbsp;&nbsp;</span><span class="syntaxdefault">buf_len&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">GetWindowTextLength</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">call</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">hwnd</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;</span><span class="syntaxdefault">str&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxstring">'&nbsp;'&nbsp;</span><span class="syntaxkeyword">*&nbsp;(</span><span class="syntaxdefault">buf_len&nbsp;</span><span class="syntaxkeyword">+&nbsp;</span><span class="syntaxdefault">1</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;</span><span class="syntaxdefault">p&nbsp;GetWindowText</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">call</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">hwnd</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">str</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">str</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">length</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;</span><span class="syntaxdefault">p&nbsp;str<br />&nbsp;&nbsp;p&nbsp;str</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">strip<br />&nbsp;&nbsp;<br />&nbsp;&nbsp;</span><span class="syntaxcomment">#&nbsp;Change&nbsp;Window&nbsp;Style<br />&nbsp;&nbsp;</span><span class="syntaxdefault">style&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">GetWindowLong</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">call</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">hwnd</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">GWL_EXSTYLE</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;</span><span class="syntaxdefault">p&nbsp;style<br />&nbsp;&nbsp;p&nbsp;SetWindowLong</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">call</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">hwnd</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">GWL_EXSTYLE</span><span class="syntaxkeyword">,&nbsp;&nbsp;</span><span class="syntaxdefault">style&nbsp;</span><span class="syntaxkeyword">|&nbsp;</span><span class="syntaxdefault">WS_EX_TOOLWINDOW</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;</span><span class="syntaxdefault">p&nbsp;SetWindowPos</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">call</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">hwnd</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">0</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">0</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">0</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">0</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">0</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">SWP_FRAMECHANGED</span><span class="syntaxkeyword">|</span><span class="syntaxdefault">SWP_NOSIZE</span><span class="syntaxkeyword">|</span><span class="syntaxdefault">SWP_NOMOVE</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">end<br /></span>
                                            The code needs error checking and such.
                                            (maybe it's because I'm not error checking yet that I some times experience that the window automatically closes after a few seconds. it has happened only sporadically...)
                                            win32.rb
                                            • 2 / 5
