    [code] Win32 Moving/Showing/Hiding Toolbars and Dialogs
    91 Posts 8 Posters 26.8k Views 8 Watching
      In most cases you'd get the window the user is working on, right?
      So how about
      GetForegroundWindow - then, in case one of the toolbars or webdialogs are the active window, iterate down the hierarchy using GetParent - checking for matching window title?
      • JD HillJ
        JD Hill
        If you have an API which supports EnumWindows, you can use GetProcessId and GetWindowThreadProcessId to filter on windows in the current process.
        Developer - Bella Render
          @jim said:
          But I didn't see a lag when applying the ToolWIndow class immediately after .showing the webdialog.
          You got a snippet of how you applied the ToolWindow style?
            'N' instead of 'L'?
            hm.. I'm a wee bit confused to exactly when to use what type...
              Jim
              From the pick-axe book:
              Strings n'' and l'' represent numbers,
              i'' represent integers, p'' represents pointers to data stored in a string
              ``v'' represents a void type (used for export parameters only).
              These strings are case-insensitive.
              So I guessed you just use the type that is the best match to the API call parameters. In other words, your guess is as good as mine.
                is N === L ? "Number" vs Integer? Number == Float?
                  I got lots of errors when I tried the Toolwindow snippet in the first post. Seems that a few constants where missing from the snippet.
                  I found them though, and I tried another way to get the window handle.
                  <span class="syntaxdefault"><br /></span><span class="syntaxcomment">#&nbsp;http://ruby-doc.org/docs/ProgrammingRuby/html/lib_windows.html#Win32API.new<br /><br /></span><span class="syntaxkeyword">require&nbsp;</span><span class="syntaxstring">'Win32API'<br /><br /></span><span class="syntaxdefault">WS_CAPTION&nbsp;&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">0x00C00000<br />WS_EX_TOOLWINDOW&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">0x00000080<br /><br />GWL_STYLE&nbsp;&nbsp;&nbsp;</span><span class="syntaxkeyword">=&nbsp;-</span><span class="syntaxdefault">16<br />GWL_EXSTYLE&nbsp;</span><span class="syntaxkeyword">=&nbsp;-</span><span class="syntaxdefault">20<br /><br /></span><span class="syntaxcomment">#&nbsp;SetWindowPos()&nbsp;flags<br /></span><span class="syntaxdefault">SWP_NOSIZE&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">0x0001<br />SWP_NOMOVE&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">0x0002<br />SWP_DRAWFRAME&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">0x0020<br />SWP_FRAMECHANGED&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">0x0020<br />SWP_NOREPOSITION&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">0x0200<br /><br /></span><span class="syntaxcomment">#&nbsp;Windows&nbsp;Functions<br />#FindWindow&nbsp;&nbsp;&nbsp;&nbsp;=&nbsp;Win32API.new("user32.dll"&nbsp;,&nbsp;"FindWindow"&nbsp;&nbsp;&nbsp;,&nbsp;'PP'&nbsp;,&nbsp;'L')<br />#FindWindowEx&nbsp;&nbsp;=&nbsp;Win32API.new("user32.dll",&nbsp;"FindWindowEx"&nbsp;,&nbsp;'LLPP',&nbsp;'L')<br /></span><span class="syntaxdefault">SetWindowPos&nbsp;&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">Win32API</span><span class="syntaxkeyword">.new(</span><span class="syntaxstring">"user32.dll"&nbsp;</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxstring">"SetWindowPos"&nbsp;</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxstring">'LLIIIII'</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxstring">'I'</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">SetWindowLong&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">Win32API</span><span class="syntaxkeyword">.new(</span><span class="syntaxstring">"user32.dll"&nbsp;</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxstring">"SetWindowLong"</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxstring">'LIL'</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxstring">'L'</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">GetWindowLong&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">Win32API</span><span class="syntaxkeyword">.new(</span><span class="syntaxstring">"user32.dll"&nbsp;</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxstring">"GetWindowLong"</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxstring">'LI'&nbsp;</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxstring">'L'</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">GetActiveWindow&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">Win32API</span><span class="syntaxkeyword">.new(</span><span class="syntaxstring">"user32.dll"</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxstring">"GetActiveWindow"</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxstring">''</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxstring">'L'</span><span class="syntaxkeyword">)<br /></span><span class="syntaxcomment">#GetForegroundWindow&nbsp;=&nbsp;Win32API.new("user32.dll",&nbsp;"GetForegroundWindow",&nbsp;'',&nbsp;'L')<br /></span><span class="syntaxdefault">GetWindowText&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">Win32API</span><span class="syntaxkeyword">.new(</span><span class="syntaxstring">"user32.dll"</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxstring">"GetWindowText"</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxstring">'LPI'</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxstring">'I'</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">GetWindowTextLength&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">Win32API</span><span class="syntaxkeyword">.new(</span><span class="syntaxstring">"user32.dll"</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxstring">"GetWindowTextLength"</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxstring">'L'</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxstring">'I'</span><span class="syntaxkeyword">)<br /><br /><br /></span><span class="syntaxdefault">def&nbsp;create_toolbar_window<br />&nbsp;&nbsp;window&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">UI</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">WebDialog</span><span class="syntaxkeyword">.new(</span><span class="syntaxstring">'My&nbsp;Test&nbsp;Window'</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">false</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;</span><span class="syntaxdefault">window</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">set_html</span><span class="syntaxkeyword">(</span><span class="syntaxstring">'<br />&nbsp;&nbsp;<html><br />&nbsp;&nbsp;<head><br />&nbsp;&nbsp;<style&nbsp;type="text/css"><br />&nbsp;&nbsp;&nbsp;&nbsp;html&nbsp;{<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;font;&nbsp;caption;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;background;&nbsp;ButtonFace;<br />&nbsp;&nbsp;&nbsp;&nbsp;}<br />&nbsp;&nbsp;&nbsp;&nbsp;hr&nbsp;{<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;border;&nbsp;none;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;border-top;&nbsp;1px&nbsp;solid&nbsp;ThreeDShadow;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;border-bottom;&nbsp;1px&nbsp;solid&nbsp;ThreeDHighlight;<br />&nbsp;&nbsp;&nbsp;&nbsp;}<br />&nbsp;&nbsp;</style><br />&nbsp;&nbsp;</head><br />&nbsp;&nbsp;<body><br />&nbsp;&nbsp;&nbsp;&nbsp;<b>My&nbsp;very&nbsp;own&nbsp;window</b><br />&nbsp;&nbsp;&nbsp;&nbsp;<hr&nbsp;/><br />&nbsp;&nbsp;&nbsp;&nbsp;Neato!<br />&nbsp;&nbsp;</body><br />&nbsp;&nbsp;</html><br />&nbsp;&nbsp;'</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;</span><span class="syntaxdefault">window</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">show<br />&nbsp;&nbsp;<br />&nbsp;&nbsp;</span><span class="syntaxcomment">#&nbsp;Find&nbsp;the&nbsp;new&nbsp;window&nbsp;-&nbsp;should&nbsp;get&nbsp;it&nbsp;by&nbsp;GetActiveWindow&nbsp;since&nbsp;wd.show&nbsp;brings<br />&nbsp;&nbsp;#&nbsp;the&nbsp;window&nbsp;to&nbsp;front.<br />&nbsp;&nbsp;</span><span class="syntaxdefault">hwnd&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">GetActiveWindow</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">call<br />&nbsp;&nbsp;</span><span class="syntaxcomment">#hwnd&nbsp;=&nbsp;GetForegroundWindow.call<br />&nbsp;&nbsp;#hwnd&nbsp;=&nbsp;FindWindow.call(DIALOG_CLASS,&nbsp;window_title)<br />&nbsp;&nbsp;</span><span class="syntaxdefault">p&nbsp;hwnd<br /><br />&nbsp;&nbsp;puts&nbsp;</span><span class="syntaxstring">'Check&nbsp;Window&nbsp;Text'<br />&nbsp;&nbsp;</span><span class="syntaxdefault">buf_len&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">GetWindowTextLength</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">call</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">hwnd</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;</span><span class="syntaxdefault">str&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxstring">'&nbsp;'&nbsp;</span><span class="syntaxkeyword">*&nbsp;(</span><span class="syntaxdefault">buf_len&nbsp;</span><span class="syntaxkeyword">+&nbsp;</span><span class="syntaxdefault">1</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;</span><span class="syntaxdefault">p&nbsp;GetWindowText</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">call</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">hwnd</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">str</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">str</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">length</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;</span><span class="syntaxdefault">p&nbsp;str<br />&nbsp;&nbsp;p&nbsp;str</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">strip<br />&nbsp;&nbsp;<br />&nbsp;&nbsp;</span><span class="syntaxcomment">#&nbsp;Change&nbsp;Window&nbsp;Style<br />&nbsp;&nbsp;</span><span class="syntaxdefault">style&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">GetWindowLong</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">call</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">hwnd</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">GWL_EXSTYLE</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;</span><span class="syntaxdefault">p&nbsp;style<br />&nbsp;&nbsp;p&nbsp;SetWindowLong</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">call</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">hwnd</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">GWL_EXSTYLE</span><span class="syntaxkeyword">,&nbsp;&nbsp;</span><span class="syntaxdefault">style&nbsp;</span><span class="syntaxkeyword">|&nbsp;</span><span class="syntaxdefault">WS_EX_TOOLWINDOW</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;</span><span class="syntaxdefault">p&nbsp;SetWindowPos</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">call</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">hwnd</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">0</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">0</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">0</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">0</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">0</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">SWP_FRAMECHANGED</span><span class="syntaxkeyword">|</span><span class="syntaxdefault">SWP_NOSIZE</span><span class="syntaxkeyword">|</span><span class="syntaxdefault">SWP_NOMOVE</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">end<br /></span>
                  The code needs error checking and such.
                  (maybe it's because I'm not error checking yet that I some times experience that the window automatically closes after a few seconds. it has happened only sporadically...)
                  win32.rb
                    Removing the maximize and minimize button: (Addition to the code in my previous post)
                    <span class="syntaxdefault"><br />&nbsp;&nbsp;WS_MAXIMIZEBOX&nbsp;</span><span class="syntaxkeyword">=&nbsp;&nbsp;</span><span class="syntaxdefault">0x10000<br />&nbsp;&nbsp;WS_MINIMIZEBOX&nbsp;</span><span class="syntaxkeyword">=&nbsp;&nbsp;</span><span class="syntaxdefault">0x20000<br />&nbsp;&nbsp;WS_SIZEBOX&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxkeyword">=&nbsp;&nbsp;</span><span class="syntaxdefault">0x40000<br /><br />&nbsp;&nbsp;</span><span class="syntaxcomment">#&nbsp;Remove&nbsp;Buttons<br />&nbsp;&nbsp;#&nbsp;http://support.microsoft.com/kb/137033<br />&nbsp;&nbsp;</span><span class="syntaxdefault">style&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">GetWindowLong</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">call</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">hwnd</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">GWL_STYLE</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;</span><span class="syntaxdefault">p&nbsp;style<br />&nbsp;&nbsp;style&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">style&nbsp;</span><span class="syntaxkeyword">&&nbsp;~</span><span class="syntaxdefault">WS_MINIMIZEBOX<br />&nbsp;&nbsp;style&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">style&nbsp;</span><span class="syntaxkeyword">&&nbsp;~</span><span class="syntaxdefault">WS_MAXIMIZEBOX<br />&nbsp;&nbsp;</span><span class="syntaxcomment">#style&nbsp;=&nbsp;style&nbsp;&&nbsp;~WS_SIZEBOX<br />&nbsp;&nbsp;</span><span class="syntaxdefault">p&nbsp;SetWindowLong</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">call</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">hwnd</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">GWL_STYLE</span><span class="syntaxkeyword">,&nbsp;&nbsp;</span><span class="syntaxdefault">style</span><span class="syntaxkeyword">)<br />&nbsp;</span><span class="syntaxdefault"></span>
                    This prevents the window from maximising when double-clicking. Seems to introduce some frame flicker.
                    Can GWL_STYLE and GWL_EXSTYLE changes be combines into one call?
                      As implemented in TT_Lib2 with error checking:
                      <span class="syntaxdefault"><br />  </span><span class="syntaxcomment"># Call after webdialog.show to change the window into a toolwindow. Spesify the<br /></span><span class="syntaxdefault">  </span><span class="syntaxcomment"># window title so the method can verify it changes the correct window.<br /></span><span class="syntaxdefault">  </span><span class="syntaxcomment">#<br /></span><span class="syntaxdefault">  </span><span class="syntaxcomment"># @param [String] window_title<br /></span><span class="syntaxdefault">  </span><span class="syntaxcomment">#<br /></span><span class="syntaxdefault">  </span><span class="syntaxcomment"># @return [Nil]<br /></span><span class="syntaxdefault">  </span><span class="syntaxcomment"># @since 2.5.0<br /></span><span class="syntaxdefault">  def self</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">make_toolwindow_frame</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">window_title</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">    </span><span class="syntaxcomment"># Retrieves the window handle to the active window attached to the calling<br /></span><span class="syntaxdefault">    </span><span class="syntaxcomment"># thread's message queue. <br /></span><span class="syntaxdefault">    hwnd </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> GetActiveWindow</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">call<br />    return nil if hwnd</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">nil</span><span class="syntaxkeyword">?<br /></span><span class="syntaxdefault">    <br />    </span><span class="syntaxcomment"># Verify window text as extra security to ensure it's the correct window.<br /></span><span class="syntaxdefault">    buf_len </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> GetWindowTextLength</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">call</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">hwnd</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">    return nil if buf_len </span><span class="syntaxkeyword">==</span><span class="syntaxdefault"> 0<br />    <br />    str </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> </span><span class="syntaxstring">' '</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">*</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">(</span><span class="syntaxdefault">buf_len </span><span class="syntaxkeyword">+</span><span class="syntaxdefault"> 1</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">    result </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> GetWindowText</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">call</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">hwnd</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> str</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> str</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">length</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">    return nil if result </span><span class="syntaxkeyword">==</span><span class="syntaxdefault"> 0<br />    <br />    return nil unless str</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">strip </span><span class="syntaxkeyword">==</span><span class="syntaxdefault"> window_title</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">strip<br />    <br />    </span><span class="syntaxcomment"># Set frame to Toolwindow<br /></span><span class="syntaxdefault">    style </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> GetWindowLong</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">call</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">hwnd</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> GWL_EXSTYLE</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">    return nil if style </span><span class="syntaxkeyword">==</span><span class="syntaxdefault"> 0<br />    <br />    result </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> SetWindowLong</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">call</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">hwnd</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> GWL_EXSTYLE</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> style </span><span class="syntaxkeyword">|</span><span class="syntaxdefault"> WS_EX_TOOLWINDOW</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">    return nil if result </span><span class="syntaxkeyword">==</span><span class="syntaxdefault"> 0<br />    <br />    </span><span class="syntaxcomment"># Remove and disable minimze and maximize<br /></span><span class="syntaxdefault">    </span><span class="syntaxcomment"># http://support.microsoft.com/kb/137033<br /></span><span class="syntaxdefault">    style </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> GetWindowLong</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">call</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">hwnd</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> GWL_STYLE</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">    return nil if style </span><span class="syntaxkeyword">==</span><span class="syntaxdefault"> 0<br />    <br />    style </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> style </span><span class="syntaxkeyword">&</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">~</span><span class="syntaxdefault">WS_MINIMIZEBOX<br />    style </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> style </span><span class="syntaxkeyword">&</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">~</span><span class="syntaxdefault">WS_MAXIMIZEBOX<br />    result </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> SetWindowLong</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">call</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">hwnd</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> GWL_STYLE</span><span class="syntaxkeyword">,</span><span class="syntaxdefault">  style</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">    return nil if result </span><span class="syntaxkeyword">==</span><span class="syntaxdefault"> 0<br />    <br />    </span><span class="syntaxcomment"># Refresh the window frame<br /></span><span class="syntaxdefault">    result </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> SetWindowPos</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">call</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">hwnd</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> 0</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> 0</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> 0</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> 0</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> 0</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> SWP_FRAMECHANGED</span><span class="syntaxkeyword">|</span><span class="syntaxdefault">SWP_NOSIZE</span><span class="syntaxkeyword">|</span><span class="syntaxdefault">SWP_NOMOVE</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">    result </span><span class="syntaxkeyword">!=</span><span class="syntaxdefault"> 0<br />  end<br /></span>
                        Can we have code blocks that expand similar to when you click on images?
                        • P
                          Pout
                          What are possible advantages of using toolwindows instead of webdialogs?
                          And is the communication between SU and the toolwindow still done in the same way?
                            It's not different windows - it's just different window frames. The code examples changes the window frame of webdialogs to toolwindows - which takes up less space and look neater.
                              Jim
                              Thanks for following (and cleaning) up the example. Will some this be getting into TT_Lib at some point?
                                TT_Lib2, yes.
                                I already got a wrapper to create toolwindows.
                                <span class="syntaxdefault"><br />&nbsp;&nbsp;&nbsp;&nbsp;def&nbsp;show_toolbar<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;options&nbsp;</span><span class="syntaxkeyword">=&nbsp;{<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;;</span><span class="syntaxdefault">title&nbsp;</span><span class="syntaxkeyword">=>&nbsp;</span><span class="syntaxstring">'Bezier&nbsp;Surface'</span><span class="syntaxkeyword">,<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;;</span><span class="syntaxdefault">pref_key&nbsp;</span><span class="syntaxkeyword">=>&nbsp;</span><span class="syntaxstring">"#{TT;;Plugins;;BPatch;;ID}_Toolbar"</span><span class="syntaxkeyword">,<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;;</span><span class="syntaxdefault">width&nbsp;</span><span class="syntaxkeyword">=>&nbsp;</span><span class="syntaxdefault">128</span><span class="syntaxkeyword">,<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;;</span><span class="syntaxdefault">height&nbsp;</span><span class="syntaxkeyword">=>&nbsp;</span><span class="syntaxdefault">52</span><span class="syntaxkeyword">,<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;;</span><span class="syntaxdefault">resizable&nbsp;</span><span class="syntaxkeyword">=>&nbsp;</span><span class="syntaxdefault">false</span><span class="syntaxkeyword">,<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;;</span><span class="syntaxdefault">scrollable&nbsp;</span><span class="syntaxkeyword">=>&nbsp;</span><span class="syntaxdefault">false<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxkeyword">}<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;@</span><span class="syntaxdefault">toolbar&nbsp;</span><span class="syntaxkeyword">||=&nbsp;</span><span class="syntaxdefault">TT</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">GUI</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">ToolWindow</span><span class="syntaxkeyword">.new(&nbsp;</span><span class="syntaxdefault">options&nbsp;</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;@</span><span class="syntaxdefault">toolbar</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">show_window<br />&nbsp;&nbsp;&nbsp;&nbsp;end<br /></span>
                                (Extract from a work in progress project.)
                                  Wonder if one can hook into windows like this under OSX...
                                    Jim
                                    For some windows, if it is a Toolwindow it will not show up in the Alt-Tab list. But this is normal for SketchUp dialog windows anyway, so there should be no difference there.
                                      Jim
                                      It's just getting GC'd. window is a local variable referencing the WebDialog, and the variable no longer exists after the method exits. Since the WebDialog no longer has any references, it is GC'd.
                                      Maybe - the "styles" are just bits but at different offset (one is -16, the other -20). If you meant is there a win32api function for setting both simultaneously then I don't know.
                                      Hehe, the php highlighter work OK on Ruby. 👍
                                        Oh... that's a gotcha I didn't think of. You need to keep a reference to the WD for the duration of its lifespan.
                                        The thing is - today, I don't really see any lag... 😕 😒
                                        What's nice about having toolwindows is that now I can make my custom toolbar. 😄
                                          Just came across a nice API call that will be useful for creating webdialog toolbars:
                                          http://social.msdn.microsoft.com/forums/en/csharpgeneral/thread/e7fef568-2c0b-41eb-9785-304f84d03819/#bf79c87e-ef49-456f-a485-aa767d841d20
                                          One can use WS_EX_NOACTIVATE to prevent a window from catching focus - but from what I understand it'll still allow interaction events. I'll try it out as soon as I get home.
                                            hm....
                                            The WS_EX_NOACTIVATE value for dwExStyle prevents foreground activation by the system. To prevent queue activation when the user clicks on the window, you must process the WM_MOUSEACTIVATE message appropriately. To bring the window to the foreground or to activate it programmatically, use SetForegroundWindow or SetActiveWindow. Returning FALSE to WM_NCACTIVATE prevents the window from losing queue activation. However, the return value is ignored at activation time.
                                            http://msdn.microsoft.com/en-us/library/ms632680%28v=vs.85%29.aspx
                                            "queue activation"?
                                            • 2 / 5
