    Giving thickness to a shell
    6 Posts 2 Posters 377 Views 2 Watching
      Design1
      I am trying to create a helicopter canopy and have attached image. Is there a way to add thickness to it? It was created by being the reminant of a "boolean" of a scaled sphere and other geometry.
      • Rich O BrienR Online
        Fredo's Joint Push/Pull plugin allows you to thicken organic shapes like this. Head over to the plugins forum and check out either the plugin index thread or the visual index thread.
        Or you could use the search function.
        When using this tool just press the tab key to change the options from 'erase original' to 'thickening'
        Hope this helps
          Or click this
          http://forums.sketchucation.com/viewtopic.php?t=6708
            Design1
            Rich thanks v much for the response. Spot on downlaoded it and it did what it said on the box. Thank you! great plugin
              Don't thank me, thank Fredo!
              But glad it worked out for you πŸ‘
                Design1
                Thank's Fredo!! πŸ˜„ Great work must have a look at your other plugins, so easy to use, sooo Sketchup!
