    Layer Material
    22 Posts 5 Posters 4.6k Views 5 Watching
    • AdamBA Offline
      AdamB
      @thomthom said:
      But how would different plugins wanting to implement this handle this? multiple plugins extending the layer class?
      So I'm simply going to conditionally add some methods if they're not already there. Because I can't return the material in any useful way, I'll collapse the method calling sequence into 1 name. So:
      Sketchup.active_model.active_layer.material_color
      Sketchup.active_model.active_layer.material_texture
      Adam
        My layer-color=.rb used a convoluted work around to import a dxf with a new layer of the same name etc colored as required and the old layer deleted. It only copes with color NOT material.
        You could work this in reverse - export a dxf of a series of faces, each on a layer; then parse the dxf to find each layer and it's color - using a lookup-table you can at least then convert the colors to RGB values - you won't easily get any textures or the material's alpha though ???
        It shouldn't be that difficult to simply have a method layer.material or layer.material="red" !!! 😒
          And what does the methods return? array of colour values? and for the texture?
          And is there a way to set the material?
          • AdamBA Offline
            AdamB
            If thats what Sir wants. πŸ˜„
              neat'o!
              Can I have fries with that?
              So, is the voodoo you're using also able to rename materials? (instead of the current workaround of recreating the material with a new one with the new name and replace the material property for all entities in the model?)
                What became of this great idea ???
                • Dan RathbunD Offline
                  Dan Rathbun
                  Dittos!
                  Never saw this 3 year old thread.
                  Spent a while yesterday posting a request for this in the API Wishlist forum.
                  Did I cover everything? Any feature I left out?
                  http://forums.sketchucation.com/viewtopic.php?f=180&t=13666&p=253272
                  I'm not here much anymore.
                    bump ?
                    • AdamBA Offline
                      AdamB
                      Had another look at this, this morning.
                      There doesn't seem to be any way of setting the Layer properties, the COM API just doesn't offer that functionality.
                      Adam
                        But one can get?
                        The COM API - is it the SkpReader in the SDK?
                          re-bump
                          • jiminy-billy-bobJ Offline
                            jiminy-billy-bob
                            So Adam never published this ?
                            So sad 😞
                            • AdamBA Offline
                              AdamB
                              I'm sitting in Provence and it is pissing down! So I pulled the code from the UK and it looks fine (don't even have to build for PowerPC anymore!) - I'll package it up for Mac and Windows next week.
                              Adam
                                jiminy-billy-bob
                                😍 Great News ! Thanks a lot !
                                Too bad, the sun is shining here in Normandie πŸ˜„
                                  πŸŽ‰ πŸŽ‰
                                    Will it be just the binaries or is there any chance we can see the source - making for a nice small tutorial? ...even though the old C++ SDK is deprecated...
                                      jiminy-billy-bob
                                      Up ?
