    Frank Wright Chair
    23 Posts 7 Posters 3.3k Views 7 Watching
    • massimoM Offline
      massimo Moderator
      Nice model Troy πŸ‘
      Here is a quick Thea render... πŸ˜„
      • troyhomeT Offline
        troyhome
        I like the render, Massimo. I used a CRF and white balance that made mine look very warm. It's nice to see the unadulterated colors πŸ˜„
        IOviz.com
        SU Pro 2024 PC
        • massimoM Offline
          massimo Moderator
          Well, I've changed all the materials. πŸ˜‰
          • troyhomeT Offline
            troyhome
            are you able to share them? they look great!
            IOviz.com
            SU Pro 2024 PC
            • troyhomeT Offline
              troyhome
              Here's another overall render
              IOviz.com
              SU Pro 2024 PC
                Nice looking model and renders. My brother and I were discussing that very chair. He's seen the original which is made of cherry and is apparently very rough with screw heads sticking out all over the place. The backrest would be a difficult thing. 1/2" thick and unsupported over most of its length. It would cup like a soup bowl unless it was quarter sawn but quarter sawn cherry isn't very pretty.
                Thanks for link, too.
                • massimoM Offline
                  massimo Moderator
                  Sure. πŸ˜„
                  The wood...
                  diffuse map
                  normal map
                  specular map
                  • massimoM Offline
                    massimo Moderator
                    ...and the leather.
                    For the render was used a quite articulated material with scratches made with two different diffuse textures and some layer. Anyway here you have the "base" mat I've made with Pixplant. It's half size in resolution.
                    diffuse map
                    normal map
                    specular map
                      jsteacy
                      Troyhome, thanks for posting the model, it looks great. Especially the render of the whole model πŸ˜‰
                      Massimo, the render is awesome and the posting the materials, wow! thank you! Give you give a little insight into your render? I'm learning thea and I'd love to be able to do similar furniture renders like this.
                      • troyhomeT Offline
                        troyhome
                        Thank you, Massimo, for sharing these!!
                        here's a little pp i did in a cute program called Toycamera Analogcolor.
                        IOviz.com
                        SU Pro 2024 PC
                        • troyhomeT Offline
                          troyhome
                          I have never seen the original- how funny that it is so roughed up. I can't imagine the backrest would hold up to much; FLW was moving from architecture for people in a direction that has since taken many architects to a place where architecture itself is the formal end.
                          Thanks for looking πŸ˜„
                          IOviz.com
                          SU Pro 2024 PC
                          • N Offline
                            notareal
                            Nice model. I like this Toycamera mood. Wonder if it's available for win (did not find it)...
                            • troyhomeT Offline
                              troyhome
                              See- you model something and it teaches you more than you could have anticipated! Thanks for all the FLW lore and rendering insights πŸ˜„
                              IOviz.com
                              SU Pro 2024 PC
                              • massimoM Offline
                                massimo Moderator
                                Nothing special jsteacy. I've used the screen that comes with Troy's model, just adjusted a bit the chair's position. In this case was used only an HDRI called Dining room of the Ennis-Brown House rotated and tuned a bit in intensity. Rendered with TR1.
                                P.S. Btw, as you probably know, the Ennis-Brown House is by Frank Lloyd Wright!!! β˜€ πŸ˜†
                                  jsteacy
                                  Massimo, thanks for the insight, as I am an aspiring renderer I wanted to see if I could create a similar image to yours. I hope you don't take it the wrong way. Then I took it a step farther and wanted to create a metallic version of the chair. It doesn't look as metallic as I was hoping but I like it either way. I used the arctic HDRi from that link you posted. Both rendered with Thea.
                                  Troyhome, I agree with you, I didn't even model the chair and I've learned a few things.
                                  • massimoM Offline
                                    massimo Moderator
                                    I prefer the first. πŸ‘
                                    • HieruH Offline
                                      Hieru
                                      I have to say I much prefer your 'metallic' version of the chair to the original design.
                                      Nice work!
                                      www.davidhier.co.uk
                                      • troyhomeT Offline
                                        troyhome
                                        I like the wood chair best but the design lends itself to steel, if you consider the chair's back. Either way, glad to see more experiments! I love seeing people get into rendering.
                                        IOviz.com
                                        SU Pro 2024 PC
                                          Troy, I was surprised about the rough construction of the original pieces of furniture. My guess is they were built sort of as proofs of concept. I'd guess if sheetrock screws had existed at the time, he'd have used them.
                                          From what I've read and seen, FLW was a great architect but not such a great engineer. I've heard that in preparation for a visit by House Beautiful or some other magazine to his house at Taliesin, he decided the bedroom wasn't big enough. He and his students tore out a load bearing wall and put on an addition. Evidently it wasn't long before the addition was all but falling off the house. They did a major restoration there a few years ago and fixing that addition was a major project.
