    SketchyPhysics3.1
    85 Posts 37 Posters 70.1k Views 37 Watching
      Mr.K.1
      @hobbnob said:
      How do we go about using the sound function? I tried using the playSound script but it didn't work.
      Here's the file, please tell me what's wrong.
      It seem you didn't embed the sound, which this function needs because it doesn't play it directly from file, but from embedded sound data.
      What you do is go to Plugins -> SketchyPhysics -> Sound, and it should open up a simple UI to add/embed sound, and later on don't forget to save your model so the data get's saved with it.
        CPhillips
        Turns out the break example will bugsplat SU8. I have a fix but I am going to wait and see if there are any other issues before I release a new version.
          CPhillips
          @jblively said:
          On the self Connecting Joints Example, can you add a name of a slider in there, so there can be a way to control the joints via the control panel?
          ontouch{|t,s,p|
          connect(t,"servo")
          ontouch{}
          I didn't see it in this Definition: connect(child,type="ball",min=0,max=0,accel=0,damp=0,breakingForce=0)
          I'll never draw another dang joint again if this works ๐Ÿ˜‰
          Thats a bit harder than it sounds. But I will look into it.
            CPhillips
            Ah! Turns out to be easier than I thought. This will work in next version:
            !!!Example only. Will not work in Sept 27 version!!!
            ontouch{|t,s,p|
               @jnt=connect(t,"servo",0,90)
               ontouch{}
            ontick{
               if @jnt!=nil
                  @jnt.controllerValue=slider("position")
              CPhillips
              Updated the scripting reference. Not done yet, but more usable now.
              Google Code Archive - Long-term storage for Google Code Project Hosting.
              (code.google.com)
              • H Offline
                hobbnob
                Well on the whole this is a very much improved release, K's advice for embedding sounds worked fine and I've also tried out the destroy function, very useful for so many things.
                My WIP Thread:Here
                  jblively
                  Excellent!!!!!
                  Can't Wait ๐Ÿ˜„
                    jblively
                    (code.google.com)
                    WOW!
                    I know how it's not fun to doc (i've done my share) but I know we all will really appreciate this new format. Very readable and usable! Great Job!
                      CPhillips
                      Version delayed while I deal with a family issue.
                        Davidfi1
                        Wonderful Work !!!
                        Thank you.
                        the http://forums.sketchucation.com/viewtopic.php?f=61&t=24201#p206890 bug is not fixed yet but it is not that interesting
                          CPhillips
                          New version is up here:
                          http://code.google.com/p/sketchyphysics/downloads/list
                          Changes:
                          http://code.google.com/p/sketchyphysics/wiki/SP31Oct7
                          Once a few people verify it works I'll turn on the auto update feature.
                          Update:
                          I have enabled the autoupdate. Hopefully it works. Some of the first few people who downloaded may have to update again as I forgot to change the version.
                            phy
                            @cphillips said:
                            Update:
                            The auto update worked great.
                            Tableau de comparaison de Staxyn s'agit d'un mะ“ยฉdicament uniquement sur ordonnance.
                              jblively
                              Auto update works like a charm.
                              I have having a bit of troubles with the auto connecting Joints and the Slider. I can get the slider to show up, but I can't get it to react to the slide when I move it. I'm using a motor joint, maybe that's the issue?
                              I've attached a very simple sample, can you see what I might be doing wrong?
                              Here is the joint code I am using:
                              ontouch{|t,s,p|
                              @jnt=connect(t,"motor",0,0,1,0.5)
                              ontouch{}
                              ontick{
                              if @jnt!=nil
                              @jnt.controllerValue=slider("motor",0)
                              Thanks,
                              Joe
                              gears2.skp
                                CPhillips
                                Ah, i forgot about the motor joint. Ill fix in next version.
                                  jblively
                                  Thanks! Thought I was going a little crazy!
                                    reddoor
                                    Just having a little trouble loading this new version on Sketchup 8 Macintosh 10.5.8
                                    I get this error on startup:
                                    Error Loading File sketchyphysics.rb
                                    dlopen(/Library/Application Support/Google SketchUp 8/SketchUp/plugins/SketchyPhysics3/sdl/SDL.dylib, 9): no suitable image found. Did find:
                                    /Library/Application Support/Google SketchUp 8/SketchUp/plugins/SketchyPhysics3/sdl/SDL.dylib: unknown required load command 0x80000022
                                    Any suggestions?
                                      shareck
                                      Hi. Can somebody tell me how to use the camera function? is it possible to achieve the same thing as with the lazy script where you have a box with a camera "attached" to its centre?
                                      • W Offline
                                        willeykj
                                        @reddoor said:
                                        Any suggestions?
                                        I'm the developer of the Mac Port of SP3. Are you running on a Mac or a Hackintosh? Which CPU (has to be INTEL).
                                        This may be a case of the build being unique to 10.6 but I'm trying to dig in.
                                        Kevin
                                        • W Offline
                                          willeykj
                                          @willeykj said:
                                          @reddoor said:
                                          Any suggestions?
                                          Kevin
                                          Just got done working with Chris.
                                          The Mac port requires shared libraries for SDL to work just like the PC version.
                                          The libraries I generated for Chris last week had unintended linkages to a version of SDL I had installed on my machine.
                                          Therefore, if you didn't have SDL installed the libraries in the SketchyPhysics directory didn't work which was the cause of Reddoor's error.
                                          SP 3.1 uses the standard SDL library as well as the SDL_mixer extension for audio. On the PC these are 2 separate shared libraries. On the Mac, it didn't seem to make sense to have SDL_mixer statically linked to the complete SDL library if the SDL shared library was going to be needed anyway. All complicated by the fact that the SP3.1 plugin folder isn't a library load directory. SOOOO.....
                                          I've compiled a new "SDL_Special.dylib" which has the necessary object code from SDL and SDL_mixer merged. This file is undergoing testing as I type and everything looks good so far. I hope to deliver to Chris later tonight and we'll get past this hiccup with the Mac version
                                          Thanks for your patience.
                                          Kevin
                                            CPhillips
                                            I have the updated Mac files now and will release a new version in a few days.
                                            Thanks Kevin!!
                                            • 2 / 5
