    [REQ] urgent maple
    20 Posts 7 Posters 3.2k Views 7 Watching
      dedmin
      I have this in 3508 x 4961 px
      Not tillable.
      • massimoM
        massimo Moderator
        Quickly made your texture seamless. Hope it's good enough...
        • soloS
          Thanks dedmin, thats a great texture, however the surface I need to cover is 7x5 ft, I will be saving this as it's awesome and will be used very soon.
          Massimo, thank you mate, you may have saved my day and hair as I've been pulling it out from frustration. How in God's name did you do that? I tried Imagesynth and Pixplant without success, so please oh please make a tutorial as I need to learn this or call on you for every texture I need seamless from now to eternity. πŸ˜„
          • numbthumbN
            numbthumb
            Have you tried WoodWorkshop? http://www.spiralgraphics.biz/ww_overview.htm 😳
            Comfortably numb...
              dedmin
              Here is the full size
              H1727_ST15.part1.rar
              H1727_ST15.part2.rar
              • massimoM
                massimo Moderator
                Just a couple of iterations with the tiler plugin (play a bit with settings) and then sharpened in photoshop. πŸ˜‰
                • soloS
                  oooH cool site!!
                  Okay now for Pete the noobie to emerge.
                  I have just recently (read last week) downloaded a trial version of Adobe CS5 and as of yet just learned curves and content aware fill. I'm a seasoned Paintshop user but kinda out of my depth with Photoshop, so can you explain where you put this preset and how you access it in PS.
                    dedmin
                    When You download tiler there is a text file inside the archive with instructions.
                    • soloS
                      I read that and installed it accordingly, however it goes on to say you can select that in the plugin menu...where is that in CS5? I do not have anything there called plugins, I have filters and effects but no plugins.
                        dedmin
                        Filter > Richard Rosenman > tiler
                        • massimoM
                          massimo Moderator
                          Pete the noobie ( πŸ˜† ) I have Ps CS5 64-bit now, so that plugin doesn't work. I've installed it in XN-view: just put it in a folder called "8bf" and find it under "filters"-->"adobe photoshop plugin". If you have PS 32 bit I assume you can put that in the plugin-->filter folder and find it under "filter" menu.
                          • soloS
                            So where is the plugin menu?
                            • soloS
                              AHA!! so I'm not going mad.
                              • massimoM
                                massimo Moderator
                                As I said I don't have it in PS, sorry, but could you try under "filter-->other" maybe?
                                  Jim
                                  Just fyi, those filters work just fine in Irfanview.
                                  • boofredlayB
                                    boofredlay
                                    Pete, install it here:
                                    C:\Program Files\Adobe\Photoshop 7.0\Plug-Ins\Filters
                                    You should see it here:
                                      ScottPara
                                      Pete,
                                      Have you seen Arroways new vaneers? I bought both and they are fantstic
                                      404 Not Found
                                      (www.arroway-textures.com)
                                      404 Not Found
                                      Scott
                                      Love the fact that some HATE my avatar.....
                                      • soloS
                                        Scott, I have those also, I bought them for this in the hopes they would work, but just not close enough to clients samples.
                                          ScottPara
                                          Damn clients
