    How to reverse edge
    4 Posts 4 Posters 630 Views 4 Watching
    • N
      Nask
      Hello all,
      I have selected a array of edges that are all connected
      edge1 from point A to B
      edge2 from point B to C
      edge3 from point D to C
      edge4 from point D to A
      I like to change the edge3.end and edge3.start so edge3 is going from point C to D.
      I tried with reverse! and manually changing the edge3.end.position.x Y and z coordinates, but this doesnt work.
      I hope somebody can help me out.
      Background: I need to change the direction because in the rest of the code I animate something along these edges. If the 3rd edge is as it is now, animation is not OK.
        If it's a curve its vertices are returned in order, if it's a loop around a face ditto, so there's no need to 'sort' them ?
        However, assuming we can't do that...
        If you make the pairs of points (as [start.position, end.position]) into arrays you can match them and reverse them if needed - the 'hash' of the edges...
        edge1=[pA, pB] edge2=[pB, pC] edge3=[pD, pC] edge4=[pD, pA]
        Take first one ' edge1', we know that its ' points' array - points[0] is pA and points[1] is pB.
        Next we iterate through the rest of the hash and see if each item's points[0]==pB, if so be break the iteration as that's the next edge to use.
        If there's no match we know that maybe the next line's points are 'backwards', so we re-iterate the rest of the hash and this time see if item's points[1]==pB, if so be break the iteration as that is the next edge to use. In this example the ' edge3' points array is backwards and so it needs to be 'reversed' - using points.reverse! and then points[0] is pC and points[1] is pD...
        It there's still no match we have a line with no next line [an 'end']... ❓
          If your edge is a line you can make
          menu edit / group it
          a rotation of 180° by the middle
          explode
          💚 sorry i have not seen that i was in section developer 😳
            You want a sorting routine for connected edges?
            I got one on disk at home - but I'm currently in Germany on a field trip...
