    ? Solid Works to SketchUp workflow ?
    13 Posts 5 Posters 1.1k Views 5 Watching
    • JClementsJ Offline
      JClements
      Hi:
      I realize that SimLabs has a plugin to import SW into SU.
      However, are there other methods to accomplish this by exporting from Solid Works to a format that SU can them import?
        dedmin
        http://forums.sketchucation.com/viewtopic.php?f=15&t=29822
        • W Offline
          watkins
          Dear John,
          I have in the past done the following, but from Inventor and not Solid Works.
          • export as .sat file
          • import into AutoCAD and scale up x100 (to take care of small features)
          • export from AutoCAD as .dxf file
          • import into SU
          • scale 0.01 to bring the model back to normal size
          In most case it works.
          Regards,
          Bob
            JClements
            Hi Bob, thanks:
            " ...export from AutoCAD as .dxf file" ?
            I thought it would have been DWG for the 3D attributes.
            Regards, John
            • W Offline
              watkins
              Maybe you are right. It has been a long time since I've done this. Give it a go.
              Bob
              • W Offline
                watkins
                Dear John,
                The attached file was exported from Inventor as a .sat file, and imported into AutoCAD (type Import at the Command line). I then scaled up x100 and exported as both a .dwg and a .dXf file (both attached). Try importing them into Sketchup. May sure the dimensions are set to millimetres, and retain the drawing origin.
                I tried with the .dxf file and it works just fine. It takes a few minutes to complete the import into SU, so be patient. The file is an assembly so contains lots of groups.
                THE SYSTEM WON'T LET ME ATTACH FILES WITH EXTENSIONS .DWG AND .DXF, AND SO I WILL EMAIL THEM TO YOU WITH THE ORIGINAL .SAT FILE
                Regards,
                Bob
                • W Offline
                  watkins
                  In trying to send you a PM I find that going that route also blocks .dwg and .dxf files. If you would like the files then please send me a PM with your email address.
                  Regards,
                  Bob
                  • Rich O BrienR Online
                    Try zipping them, that would allow you to upload.
                      Guys, we keep adding newer file types to the possible attachments but until all that is needed is added, you can always ZIP those files and attach that way.
                        Ha ha!
                        • W Offline
                          watkins
                          Zipped folder containing 4 files (.sat, .dwg, .dxf, and .skp)
                          Files.zip
                            JClements
                            Thanks, Bob.
                            I did notice a few things with the DWG import. I couldn't weld the 40-edges that form one of the small holes. I couldn't use the script to place a guidepoint at the center of the selected edges that form one of the small holes.
                            Also, for the repetitive elements, are there blocks/components in Solidworks and can they be exported so they come into AutoCAD and SU as such?
                            • W Offline
                              watkins
                              Dear John,
                              The .sat file was created using AutoDesk's Inventor 11.
                              If you want to weld the 40 segments of the circle, then soften the group first. After softening, Chris Fullmer's tool for finding the centre point can be used. Also note, the SU model needs to be scaled by 0.01 (I forgot to do this before posting).
                              Hope this helps.
                              Regards,
                              Bob
