    Unsolid Component???
    4 Posts 3 Posters 363 Views 3 Watching
      Dik Harrison
      I have a face that when I extrude it, I don't get a solid. Any idea how I can find the "gap" or what ever is stopping it from making a solid? I'm running ver. 8.
      When you extrude the face in this model, and create a component from the result, the component is not solid.
      Have fun...
      Dik
        Edit: beaten by Jeff... πŸ˜’
        Hi Dik,
        Check out ThomThom's Solid inspector plugin. I found a couple of flaws with it (there are edges that do not extrude with your shape)
        • jeff hammondJ Offline
          use thomthom's solid inspector found here:
          http://forums.sketchucation.com/viewtopic.php?t=30504
          [tip]- when using the script, i find it best to use x-ray view then use the tab key to cycle through the errors..
            Dik Harrison
            Thanks, I haven't been on the forum in quite a while, guess I need to visit more often...
            Have fun...
            Dik
